I've just converted all my TellyMate examples to work with Arduino 1.0.
They're all available for download on the TellyMate Shield examples page.
I thought I'd take this opportunity to re-post a video of my favourite - a performance of the closing credits from 'Portal':
"Still Alive" will actually work just fine without a TellyMate (one line to comment out in the source), but you'll need to watch the output on the serial monitor rather than your TV screen :o) (I'm still hoping that someone will hook it up to something like a serial dasiywheel printer and video the result!)
Very few changes were actually required to move to Arduino 1.0; two main things:
Functionality has changed in
Serial.print*
Previously, calling -
Serial.print( my_byte )*
would transmit the raw byte, but under Arduino 1.0, it converts it to a decimal string.
The fix is to simply call -
Serial.write( my_byte )*
There's now a transmit buffer on Serial.
This caused some timing issues when listening for responses from the TellyMate - very often I'd start listening before the command had even been sent!
The solution is to simply call -
Serial.flush()*
before waiting for a response. That guarantees that all the TX buffer is sent.
