Template not found
Hello, when I follow the setup instructions, I click on go to templates after having attached two Modulinos together and I get the error "Template not found."
I can find the templates for the individual Modulinos under the "plug-and-make" kit category in general, but not for any combinations. Also from the templates page, when I click on "Plug and Make Getting Started" I get the Template not found error. I was expecting there to be templates for combinations of Modulinos but because I get this error I think I can't see them.
It seems to be fixed now.
I have the same problem/ How did you fix it?
The templates can be found as part of the content which you can find here https://courses.arduino.cc/plugandmake/
I just tried provisioning a few more times and the third time it successfully redirected to the temple instead of returning the 404. I don't know what the difference was.
Thank you. I haven't given up yet. I will keep trying.
Hello - I'm encountering the same issue described in this thread. When I follow the link from the plug-and-make course page to load my first template, I get the error "Template Not Found" then I'm redirected to the Templates page on my cloud account. I've tried a dozen times or so, but it's not working.
I'm trying to follow the training in the right order - is it possible to skip that step, or will I miss enough that I won't be able to do later things without problems?
@tom-akana We are investigating the root cause of this issue, in the meantime you can access the templates here (https://app.arduino.cc/templates?tab=arduino) and filter on the top of the page by plug and make kit.
The templates will give you the ground to start building your project
Hi, my uncle recently buy me a Arduino, and I have the same problem. The template not found. I go to the page that say that are the template and its the same. Say the template not found. I intent to go ahead whit the others templates like the modulino buttons but say not enough resources and cant use the template button to go ahead. I afraid its becose that can do the IoT Templates phase. Please help. Thanks.
@chechonauta is this issue still happening?
No the problem persist.
No, the problem persist.
No, when I hit "Go to template" I get the message "Template not found", and I inmediatelly got redirected to the Home/Template menu. And that´s it. This is for me my first time working with Arduino, so I have little understanding. I am just following the instructions, starting from the box and then following the website instructions. Any help to start my projects will be very much appreciated, REGARDS!
Hello,
I’m sorry to hear you’re encountering this issue. Could you please try clearing your browser’s cookies and cache, and then access the site again? Additionally, testing in incognito mode or using a different browser may help isolate the issue.
If the problem persists, please reach out to technical support through the following form so we can assist you with further troubleshooting steps: Contact us.
