Tensorflow Lite On Teensy Microcontroller 4.1
Hi, I am trying to convert my tensorflow lite model of C source file over to run on my teensy 4.1 microcontroller on arduino. I just want to know if it is possible and if anyone could guide my code.
#include <SPI.h>
#include <SD.h>
#include <EloquentTinyML.h>
#include <eloquent_tinyml/tensorflow.h>
#define N_INPUTS 1
#define N_OUTPUTS 1
#define TENSOR_ARENA_SIZE 2*1024
uint8_t *loadedModel;
Eloquent::TinyML::TfLite<N_INPUTS, N_OUTPUTS, TENSOR_ARENA_SIZE> tf;
!cat {MODEL_TFLITE_MICRO}
void loadModel(void);
SPI.begin();
delay(3000);
if (!SD.begin(4)) {
    Serial.println("Cannot init SD");
    delay(60000);
loadModel();
// init Tf from loaded model
if (!tf.begin(loadedModel)) {
    Serial.println("Cannot inialize model");
    Serial.println(ml.errorMessage());
    delay(60000);
// pick up a random x and predict its sine
float x = 3.14 * random(100) / 100;
float y = sin(x);
float input[1] = { x };
float predicted = tf.predict(input);
Serial.print("sin(");
Serial.print(x);
Serial.print(") = ");
Serial.print(y);
Serial.print("\t predicted: ");
Serial.println(predicted);
  • Load model from SD
    void loadModel() {
    File file = SD.open("/sine.bin", FILE_READ);
    size_t modelSize = file.size();
    Serial.print("Found model on filesystem of size ");
    Serial.println(modelSize);
    // allocate memory
    loadedModel = (uint8_t*) malloc(modelSize);
    // copy data from file
    for (size_t i = 0; i < modelSize; i++)
    loadedModel[i] = file.read();
    file.close();
The Teensy 4.1 is not in the list of supported platforms:
It might still work if the Teensy 4.1 uses a processor that is the same as a supported platform.
Teensy 4.1 uses ARM Cortex - M7 Which is based on Arm Cortex-M Series architecture.
