Testing multiple PING)))
Hello All
I couldn't find what I was looking to accomplish my end result. I have a project where all my PING)) sensors (4 sensors) are firing simultaneously (I found a code written by mjmcondor in the forum that accomplished most of what I needed)
Now what i need to do is to have a red light and a green light (led's) come on at a given distance, and tell me which sensor was triggered.
I'm using the "if/else" at the bottom of the code to trigger the red led if it's less that 5 inches
then have both led's come on everything at 6 to 9 inches,
and only the green led at anything above 10 inches.
I have played with this different variation of this code, and only made matters worse, so I took it back to where it was working. However, only the "Rear right" Ping seems to trigger the LED's. I'm assuming because it is the last value entered.
What I need help with;
  1. having the LED's fire at the right time (and as fast as possible)
  2. any suggestions as to how i can indicate which ping sensor is being triggered?
    I was thinking of simply having 4 red LED's and 4 GREEN and just placing them respectively to the sensors, but I'm hoping there's a simpler method that I haven't thought of.
All help welcomed, I am very new to this.
Thank you
int ultraSoundSignalPins[] = {6,8,9,12}; // Front Left (6),Front Right(8), Rear Left(9), & Rear Right(12) Ultrasound signal pins
char *pingString[] = {"Front Left ","Front Right ", "Rear Left ", "Rear Right "}; // just something to print to indicate direction
const int redPin = 10;
const int greenPin = 11;
//Ping function
unsigned long ping(int index)
 unsigned long echo;
 pinMode(ultraSoundSignalPins[index], OUTPUT); // Switch signalpin to output
 digitalWrite(ultraSoundSignalPins[index], LOW); // Send low pulse
 delayMicroseconds(2); // Wait for 2 microseconds
 digitalWrite(ultraSoundSignalPins[index], HIGH); // Send high pulse
 delayMicroseconds(5); // Wait for 5 microseconds
 digitalWrite(ultraSoundSignalPins[index], LOW); // Holdoff
 pinMode(ultraSoundSignalPins[index], INPUT); // Switch signalpin to input
 digitalWrite(ultraSoundSignalPins[index], HIGH); // Turn on pullup resistor
 echo = pulseIn(ultraSoundSignalPins[index], HIGH); //Listen for echo
 //return (echo / 58.138); //convert to CM
 return (echo / 58.138) * .39; //convert to CM then to inches
 unsigned long ultrasoundValue;
 for(int i=0; i < 4; i++){
   ultrasoundValue = ping(i);
   Serial.print(pingString[i]);
   Serial.print(ultrasoundValue);
   //Serial.print("CM, ");
   Serial.print("in, ");
   delay(50);
 if ( ultrasoundValue <= 5){
    digitalWrite(redPin,LOW);
  else {
    digitalWrite(redPin,HIGH);
if ( ultrasoundValue >= 10){
    digitalWrite(greenPin,LOW);
  else {
    digitalWrite(greenPin,HIGH);
 delay(200);
Your first problem can be solved by including all the "if (ultrasound..)" clauses within the for loop rather than after it- this is why it only responds to the last value.
However if you do this you will find its pretty confusing as the LED's will be flashing on and off faster than you can really concentrate on as each distance is read out several times each second.
If you want real-time readouts in all four directions you are probably going to have to implement separate sets of LED's for each sensor.
