Hi Everyone,
This is on a Arduino UNO R3
I noticed something acting quirky while testing some code so I decided to test the pins using the code below and I noticed that on pins 9 and up without plugging in the jumper it would start transmitting on its own as if the jumper cable was plugged in and sending a bunch of garbage to the serial monitor.
Is this chip toast?
Is it worth replacing just the chip or just toss it and replace entire board?
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
See also FAQ - Arduino Forum for general rules on forum behaviour and etiquette.
Hello,
Welcome to the Arduino Forum.
This guide explains how to get the best out of this forum. Please read and follow the instructions below.
Being new here you might think this is having rules for the sake of rules, but that is not the case. If you don’t follow the guidelines all that happens is there is a long exchange of posts while we try to get you to tell us what we need in order to help you, which is fru…
The question was not about the code but as to the board.
But you posted code, hence the request to use code tags to make it easier to read and copy if necessary
Serial.print without Serial.begin ???
//Edit
Missed that it was in loop()
Serial.begin(131200);
That's a strange baud rate. Try 115200 instead and make sure the Serial Monitor has the same rate. Also, move it to setup()
As soon as we have the code and baud rate sorted we can start looking and commenting on the board.
system
Closed
April 4, 2023, 6:45pm
8
