TFT library alters values in a struct
Hello,
I have the following code.
Serial.println("sensorUIInfo->airTemp MAIN C");
 getAirTemp();  //Air Temp = 23
  //Draw pH value
  myGLCD.printNumF(sensorUIInfo->phLevel, 1, 20, 120);
  Serial.println("sensorUIInfo->airTemp MAIN D");
 getAirTemp();  //Air Temp = 32
The reason is that printNumF, if I do printNumI or nothing it's OK. Somehow that printF alters the value.
The struct is like this:
//All the data from the HW sensors.
    struct SENSOR{
    float phLevel;
    float eCLevel;
    int airTemp;
    int waterTemp;
SENSOR* sensorUIInfo;
And I update from the engine to the UI like this:
void HydroponicsUI::updateInfoFromSensors( SENSOR* sensorInformation )
 Serial.println("sensorInformation->airTemp");
 Serial.println(sensorInformation->airTemp);
 sensorUIInfo->phLevel = sensorInformation->phLevel;
 sensorUIInfo->eCLevel = sensorInformation->eCLevel;
 sensorUIInfo->airTemp = sensorInformation->airTemp;
 sensorUIInfo->waterTemp =  sensorInformation->waterTemp;
The controller does the update like this:
//Update the UI of the latest Sensor Info
   Hydro_UI.updateInfoFromSensors( Hydro_Eng.getSensorInformation() );
Is this an error in my code?
Thanks.
Also:
If I pass by reference it is working OK. Any ideas what mistake I made when using those pointers? Are pointers the correct way to do it here?
