TFT RA8875 Capacitive Touch Not working
Hello,
I'm having some issues with the capacitive touch not working on the display. First thing first, I have purchased the display from Purchased Screen. I also purchased the shield that they offer. Currently the panel start up no problem and runs until it gets to the point to test the capacitive touch. Then I notice that a green dot appears up at the top left of the screen. Then the position reads 0,0. It currently is not detecting any inputs. I'm not sure where to start troubleshooting this issue. I have attached the code, which is an example from the bottom of thier website. The libraries that I am using come directly from thier website as well.
When I do touch the screen, there is something being detected in the serial monitor.
Readout from Serial monitor
RA8875 start
Origin X,Y = 514, 514
Width X,Y = 514, 514
periodMonitor = 2
lib version length is zero
firmware ID = 2
Found RA8875
Status: 0
Waiting for touch events ...
RA8875 start
periodMonitor = 2
firmware ID = 2
Found RA8875
Status: 0
Touch:
number of hit points = 2
Time delta = 3445, dist = 0
Locations:
//Web: http://www.buydisplay.com
EastRising Technology Co.,LTD
Examples for ER-TFTM070-5 with Capacitive Touch Panel
Display is Hardward SPI 4-Wire SPI Interface and 5V Power Supply
Capacitive Touch Panel is I2C Interface
Tested and worked with:
Works with Arduino 1.6.0 IDE
#include <stdint.h>
#include <SPI.h>
#include <Wire.h>
uint8_t addr  = 0x35;
#include "Adafruit_GFX.h"
#include "Adafruit_RA8875.h"
//LCD:hardware SPI  CTP:hardware IIC
//Arduino DUE,Arduino mega2560,Arduino UNO
#define RA8875_INT 4
#define RA8875_CS 10
#define RA8875_RESET 9
#define FT5206_WAKE 6
#define FT5206_INT   7
Adafruit_RA8875 tft = Adafruit_RA8875(RA8875_CS, RA8875_RESET);
uint16_t tx, ty;
enum {
  eNORMAL = 0,
  eTEST   = 0x04,
  eSYSTEM = 0x01
struct TouchLocation
  uint16_t x;
  uint16_t y;
TouchLocation touchLocations[5];
uint8_t readFT5206TouchRegister( uint8_t reg );
uint8_t readFT5206TouchLocation( TouchLocation * pLoc, uint8_t num );
uint8_t readFT5206TouchAddr( uint8_t regAddr, uint8_t * pBuf, uint8_t len );
uint32_t dist(const TouchLocation & loc);
uint32_t dist(const TouchLocation & loc1, const TouchLocation & loc2);
bool sameLoc( const TouchLocation & loc, const TouchLocation & loc2 );
uint8_t buf[30];
  Wire.beginTransmission(addr);
  Wire.write( reg );  // register 0
  uint8_t retVal = Wire.endTransmission();
  uint8_t returned = Wire.requestFrom(addr, uint8_t(1) );    // request 6 uint8_ts from slave device #2
  if (Wire.available())
    retVal = Wire.read();
  return retVal;
  Wire.write( regAddr );  // register 0
  uint8_t returned = Wire.requestFrom(addr, len);    // request 1 bytes from slave device #2
  uint8_t i;
  for (i = 0; (i < len) && Wire.available(); i++)
    pBuf[i] = Wire.read();
  return i;
  uint8_t retVal = 0;
  uint8_t i;
  uint8_t k;
  do
    if (!pLoc) break; // must have a buffer
    if (!num)  break; // must be able to take at least one
    uint8_t status = readFT5206TouchRegister(2);
    static uint8_t tbuf[40];
    if ((status & 0x0f) == 0) break; // no points detected
    uint8_t hitPoints = status & 0x0f;
    Serial.print("number of hit points = ");
    Serial.println( hitPoints );
    readFT5206TouchAddr( 0x03, tbuf, hitPoints*6);
    for (k=0,i = 0; (i < hitPoints*6)&&(k < num); k++, i += 6)
      pLoc[k].x = (tbuf[i+0] & 0x0f) << 8 | tbuf[i+1];
      pLoc[k].y = (tbuf[i+2] & 0x0f) << 8 | tbuf[i+3];
    retVal = k;
  } while (0);
  return retVal;
void writeFT5206TouchRegister( uint8_t reg, uint8_t val)
  Wire.write( val );  // value
void readOriginValues(void)
  writeFT5206TouchRegister(0, eTEST);
  delay(1);
  //uint8_t originLength = readFT5206TouchAddr(0x08, buf, 8 );
  uint8_t originXH = readFT5206TouchRegister(0x08);
  uint8_t originXL = readFT5206TouchRegister(0x09);
  uint8_t originYH = readFT5206TouchRegister(0x0a);
  uint8_t originYL = readFT5206TouchRegister(0x0b);
  uint8_t widthXH  = readFT5206TouchRegister(0x0c);
  uint8_t widthXL  = readFT5206TouchRegister(0x0d);
  uint8_t widthYH  = readFT5206TouchRegister(0x0e);
  uint8_t widthYL  = readFT5206TouchRegister(0x0f);
  //if (originLength)
    Serial.print("Origin X,Y = ");
    Serial.print( uint16_t((originXH<<8) | originXL) );
    Serial.print(", ");
    Serial.println( uint16_t((originYH<<8) | originYL) );
    Serial.print("Width X,Y = ");
    Serial.print( uint16_t((widthXH<<8) | widthXL) );
    Serial.print(", ");
    Serial.println( uint16_t((widthYH<<8) | widthYL) );
// 1234567890
  Serial.println("RA8875 start");
  Wire.begin();        // join i2c bus (address optional for master)
  readOriginValues();
  pinMode     (FT5206_WAKE, INPUT);
  digitalWrite(FT5206_WAKE, HIGH );
  writeFT5206TouchRegister(0, eNORMAL); // device mode = Normal
  uint8_t periodMonitor = readFT5206TouchRegister(0x89);
  Serial.print("periodMonitor = ");
  Serial.println( periodMonitor, HEX );
  uint8_t  lenLibVersion = readFT5206TouchAddr(0x0a1, buf, 2 );
  if (lenLibVersion)
    uint16_t libVersion = (buf[0] << 8) | buf[1];
    Serial.print("lib version = ");
    Serial.println( libVersion, HEX);
    Serial.println("lib version length is zero");
  uint8_t firmwareId = readFT5206TouchRegister( 0xa6 );
  Serial.print("firmware ID = ");
  Serial.println( firmwareId);
    /* Initialise the display using 'RA8875_480x272' or 'RA8875_800x480' */
  //if (!tft.begin(RA8875_800x480))
  //  Serial.println("RA8875 Not Found!");
  //  while (1);
  while (!tft.begin(RA8875_800x480))
    delay(100);
  Serial.println("Found RA8875");
  tft.displayOn(true);
  tft.GPIOX(true);      // Enable TFT - display enable tied to GPIOX
  tft.PWM1config(true, RA8875_PWM_CLK_DIV1024); // PWM output for backlight
  tft.PWM1out(255);
  // With hardware accelleration this is instant
  tft.fillScreen(RA8875_WHITE);
      tft.textMode();
      tft.textSetCursor(0,0);
      tft.textColor(RA8875_RED, RA8875_BLACK);
      tft.textWrite("www.buydiplay.com  Backlight brightness adjustment test ");
      tft.graphicsMode();
  // Play with PWM
  for (uint8_t i=255; i!=0; i-=5 )
    tft.PWM1out(i);
    delay(10);
  for (uint8_t i=0; i!=255; i+=5 )
    tft.PWM1out(i);
    delay(10);
  tft.PWM1out(255);
  tft.fillScreen(RA8875_RED);
  tft.fillScreen(RA8875_YELLOW);
  tft.fillScreen(RA8875_GREEN);
  tft.fillScreen(RA8875_CYAN);
  tft.fillScreen(RA8875_MAGENTA);
  tft.fillScreen(RA8875_BLACK);
  // Try some GFX acceleration!
  tft.drawCircle(100, 100, 50, RA8875_BLACK);
  tft.fillCircle(100, 100, 49, RA8875_GREEN);
  tft.fillRect(11, 11, 700, 400, RA8875_BLUE);
  tft.drawRect(10, 10, 400, 200, RA8875_GREEN);
  tft.fillRoundRect(200, 10, 200, 100, 10, RA8875_RED);
  tft.fillRoundRect(480, 100, 300, 200, 10, RA8875_RED);
  tft.drawPixel(10,10,RA8875_BLACK);
  tft.drawPixel(11,11,RA8875_BLACK);
  //tft.drawLine(10, 10, 200, 100, RA8875_RED);
  tft.drawTriangle(200, 15, 250, 100, 150, 125, RA8875_BLACK);
  //tft.fillTriangle(200, 16, 249, 99, 151, 460, RA8875_YELLOW);
  tft.drawEllipse(300, 100, 100, 40, RA8875_BLACK);
  tft.fillEllipse(300, 100, 98, 38, RA8875_GREEN);
  // Argument 5 (curvePart) is a 2-bit value to control each corner (select 0, 1, 2, or 3)
  tft.drawCurve(50, 100, 80, 40, 2, RA8875_BLACK);
  tft.fillCurve(50, 100, 78, 38, 2, RA8875_WHITE);
  pinMode     (FT5206_INT, INPUT);
  //digitalWrite(FT5206_INT, HIGH );
  tft.touchEnable(false);
  Serial.print("Status: "); Serial.println(tft.readStatus(), HEX);
  Serial.println("Waiting for touch events ...");
  randomSeed(analogRead(0));
  uint32_t retVal = 0;
  uint32_t x = loc.x;
  uint32_t y = loc.y;
  retVal = x*x + y*y;
  return retVal;
  uint32_t x = loc1.x - loc2.x;
  uint32_t y = loc1.y - loc2.y;
  retVal = sqrt(x*x + y*y);
  return retVal;
  return dist(loc,loc2) < 50;
  static uint16_t total = 256;
  static uint16_t w = tft.width();
  static uint16_t h = tft.height();
  float xScale = 1024.0F/w;
  float yScale = 1024.0F/h;
  uint8_t attention = digitalRead(FT5206_INT);
  static uint8_t oldAttention = 1;
  uint32_t thisTouchTime = millis();
  uint8_t i=0;
  static
  uint32_t lastTouchTime = thisTouchTime;
    while(total!=0)
    total--;
    if ((total & 0x3ff) == 0)
      //Serial.println(total);
    // void    fillRect(int16_t x, int16_t y, int16_t w, int16_t h, uint16_t color);
    int16_t x  = random(w);
    int16_t y  = random(h);
    int16_t x1 = random(w);
    int16_t y1 = random(h);
    int16_t x2 = random(w);
    int16_t y2 = random(h);
    uint16_t c  = (((random(64)<<6)|random(64))<<6)|random(31);
    uint16_t bg = (((random(64)<<6)|random(64))<<6)|random(31);
    int16_t th = random(h);
    int16_t tw = random(w);
    int16_t op = random(9);
    int16_t en = random(8);
    switch( op )
    default:
    case 0:
      tft.fillRect(x,y, tw, th, c);
    case 1:
      tft.fillEllipse(x,y,tw/2,th/2,c);
    case 2:
      tft.fillCircle(x,y,tw/2,c);
    case 3:
      tft.fillTriangle(x,y,x1,y1,x2,y2,c);
    case 4:
      tft.textMode();
      tft.textSetCursor(x,y);
      tft.textColor(c,bg);
      tft.textEnlarge(en);
      tft.textWrite("Hallowell",9);
      tft.graphicsMode();
    case 5:
      tft.drawRect(x,y, tw, th, c);
    case 6:
      tft.drawEllipse(x,y,tw/2,th/2,c);
    case 7:
      tft.drawCircle(x,y,tw/2,c);
    case 8:
      tft.drawTriangle(x,y,x1,y1,x2,y2,c);
     if(total==0)
       {  tft.fillScreen(RA8875_BLACK);
         tft.textMode();
         tft.textEnlarge(0);
        tft.textWrite("www.buydiplay.com  Capacitive touch screen test.Please touch the screen!");
     /* Wait around for touch events */
    if (!attention && oldAttention )
      Serial.println("Touch: ");
      uint8_t count = readFT5206TouchLocation( touchLocations, 5 );
      //static uint8_t lastCount = count;
     if (count)
        static TouchLocation lastTouch = touchLocations[0];
        if (((thisTouchTime - lastTouchTime) > 10000) && sameLoc( touchLocations[0],lastTouch ) )
        Serial.print("Time delta = ");
        Serial.print(thisTouchTime - lastTouchTime);
        Serial.print(", dist = ");
        Serial.println( dist(touchLocations[0],lastTouch) );
        Serial.println("Locations: ");
        for (i = 0; i < count; i++)
          //Serial.print(i);
          //Serial.print(": ");
          //Serial.print(touchLocations[i].x);
          //Serial.print(", ");
          //Serial.print(touchLocations[i].y);
          //Serial.println(".");
          tft.textMode();
         tft.textEnlarge(0);
          //tft.textSetCursor(touchLocations[i].x,touchLocations[i].y);
          tft.textSetCursor(380,380+16*i);
          tft.textColor(RA8875_WHITE, RA8875_BLACK);
          tft.textEnlarge(0);
          snprintf((char*)buf,sizeof(buf),"(%3d,%3d)",touchLocations[i].x,touchLocations[i].y);
          tft.textWrite((const char *)buf,9);
        tft.graphicsMode();
        if(i==0)  tft.fillCircle(touchLocations[i].x,touchLocations[i].y, 5, RA8875_RED);
        else if(i==1)  tft.fillCircle(touchLocations[i].x,touchLocations[i].y, 5, RA8875_GREEN);
        else if(i==2)  tft.fillCircle(touchLocations[i].x,touchLocations[i].y, 5, RA8875_BLUE);
        else if(i==3)  tft.fillCircle(touchLocations[i].x,touchLocations[i].y, 5, RA8875_CYAN);
         else if(i==4)  tft.fillCircle(touchLocations[i].x,touchLocations[i].y, 5, RA8875_MAGENTA);
//      for (; i < 5; i++)
//       tft.textMode();
//        //tft.textSetCursor(touchLocations[i].x,touchLocations[i].y);
//        tft.textSetCursor(380,380+16*i);
//        tft.textColor(RA8875_WHITE, RA8875_BLACK);
//        tft.textEnlarge(0);
//        snprintf((char*)buf,sizeof(buf),"         ");
//        tft.textWrite((const char *)buf,9);
      //lastCount = count;
  //    if (tft.touched())  // USB
  //      Serial.print("Touch: ");
  //      tft.touchRead(&tx, &ty);
  //      Serial.print(tx); Serial.print(", "); Serial.println(ty);
  //      /* Draw a circle */
  //      tft.fillCircle((uint16_t)(tx/xScale), (uint16_t)(ty/yScale), 4, RA8875_WHITE);
    oldAttention = attention;
