The Attention It Deserves
The name of this thread is courtesy of @EmilyJane, based on a thread that fits in the "I always try my hardest to answer a post when..." Bar Sport discussion of fame.
What follows is a continuation of an Arduino project in the thread that brought me to post this one and is intended to help those who refuse to read the "How to Get The Best of The Forum" post.
The sketch includes the fine code revisions of @evanmars, likewise generous in their attempt to bring clarity and harmony to the chaotic universe.
I will cc @camsysca , @alto777 , @docdoc , @ruilviana , @TomGeorge , @kmin @xfpd , @outbackhut who know what I'm blathering about and who exhibit everlasting patience. You are all Royalty amongst commoners like me. If your name isn't here but you feel it should be, I apologize. Either I missed it or, like JohnLincoln, it was not mentioned due to 10 mention per post forum limit. What kind of party is that, Arduino Forum?
Without further ado and using frickin' CODE TAGS, I humbly present the following sketch for your consideration:
Set Serial monitor to 9000 baud, no line ending
Circuit: Just an Arduino Uno R3
By hallowed31, June 20, 2025
Adapted from evanmars's code based on hallowed31's OG 1.0
Working as intended.
Update (v2.0) -- yeah, right! Skipped to be awesomer. Straight to v3.0 for the kid here
Future update (v∞AndBeyond)
  TODO: achieve forum Nirvana
char inChar;
byte mode = 0;
byte scriptCounter = 0;
unsigned long ma, lastMa;
  twentyBlankLines();
  Serial.println(F("How to use the <CODE/> button in the forums super deluxe vTHREE.0"));
  Serial.println(F("Press SPACE BAR + Enter to begin your spiritual journey into logic and reason...\n\n"));
  while (inChar != ' ') {
    if (Serial.available() > 0) {
      inChar = Serial.read();
      if (inChar == ' ') break;
  showMenu();
  if (scriptCounter == 1) mode = 4;
    char switchMode = Serial.read();
    switch (switchMode) {
      case ' ':    // space bar
        mode = 1;  //menu
      case 'h':
        scriptCounter = 0;
        mode = 2;  // hallowed31
      case 'e':
        scriptCounter = 0;
        mode = 3;  // evanmars
  switch (mode) {
    case 1:
      showMenu();
    case 2:
      if (scriptCounter == 0) {
        twentyBlankLines();
        Serial.println(F("the hallowed31 Contention:\n"));
        theHallowed31Contention();
        scriptCounter = 1;
    case 3:
        twentyBlankLines();
        Serial.println(F("the evanmars Dialectic:\n"));
        theEvanMarsDialectic();
        scriptCounter = 1;
    case 4:
      splash();
void theHallowed31Contention() {
  // for loop repacked to function and called in state machine
  Serial.println(F("How to use the <CODE/> button in the forums v1.0"));
  Serial.println(F("1. Copy your auto formatted code to your clipboard with CTRL + C"));
  Serial.println(F("2. In the forum window, click the <CODE/> button"));
  Serial.println(F("3. Without deleting the six little ` marks..."));
  Serial.println(F("4. ... highlight the line that says: paste your code here, then"));
  Serial.println(F("5. paste your code between those marks using CTRL + V"));
  Serial.println(F("Optional: use your arrow key down to go past the code to protect ``` "));
void theEvanMarsDialectic() {
  /* note, for loop removed from evanmars orig. Should not alter spirit of orig text.
      I mean, this isn't the Bible, after all.
      Or is it? [insert spooky musical internal monologue here] */
  // what follows is all verbatim from orig scrolls
  Serial.println("How to post code in the forums v1.0");
  Serial.println("1. Copy your auto formatted code Ctrl-Shift-C");
  Serial.println("2. In the forum window, click the Ctrl-V");
  Serial.println("3. DO NOT delete the six little ` marks...");
  Serial.println("Optional: use your arrow key down to go past the code to protect ``` ");
void showMenu() {
  Serial.println(F("Key Commands: "));
  Serial.println(F("  e to view evanmars Dialectic"));
  Serial.println(F("  h to view hallowed31 Contention\n\n"));
  Serial.println(F("                             Type X to return"));
  Serial.println(F("then Space bar + Enter during the feature discussion to review menu options\n\n"));
  while (!Serial.available()) {
    char escape = Serial.read();
    switch (escape) {
      case 'h':
        scriptCounter = 0;
        mode = 2;
      case 'H':
        scriptCounter = 0;
        mode = 2;
      case 'e':
        scriptCounter = 0;
        mode = 3;
      case 'E':
        scriptCounter = 0;
        mode = 3;
      case 'x':
        mode = 4;  //splash
      case 'X':
        mode = 4;  //splash
void splash() {
  ma = millis();
  const unsigned long maTime = 5000;
  if (ma - lastMa >= maTime) {
    lastMa = ma;
    Serial.println(F("\n  e to view evanmars Dialectic"));
    Serial.println(F("  h to view hallowed31 Contention\n"));
void twentyBlankLines() {
  for (int i = 0; i < 20; i++) {
Note that this was posted to the forum using the hallowed31 Contention.
Can't get out of setup() in Wokwi. :frowning:
Just need to learn how to use Wokwi
Everyone who have patiently contributed to the topic that this topic is dedicated, certainly deserve congratulations for keeping their cool. Frankly, I don't know why anyone bothered responding after it became obvious that OP was just being a troll and forum rules bar the kinds of rude responses that were warranted.
That OP appears to be a juvenile, only here to toy with the helpers for their own amusement. I wonder what advantage posting to the forum only through email gives them? Maybe a mod can comment on what advantage, if any, that gives a troll.
Some might find it more convenient to interact with the forum through email, but it doesn't give any advantages other than that convenience.
I strongly recommend using the forum's web interface to post instead of posting via email. The reason is that we can use the preview provided by the web interface to verify that the post is correctly formatted and will be rendered as intended when published on the forum.
I sometimes see people replying to the email notifications from the forum thinking they are engaging in a one-on-one conversation with the author of the post for which the notification was received, rather than understanding that they are participating in a forum thread. This can result in confusing or otherwise suboptimal communication with the forum community who are seeing those posts within the full context of the forum thread on the website.
Even though I think email is an excellent method of communication in general, I would disable the option to even use email to post to the forum if I could due to these problems. Unfortunately the forum framework doesn't offer that option.
Thanks for that clarification. I haven't used that method of forum interaction so I had no idea how it works.
Couldn't the setting reply_by_email_enabled (and/or pop3_polling_enabled) be set to false?
Yes, you are right. I see now from my notes that I found this setting, but decided to hold off on disabling it, as email might be the only way some forum members can interact with the forum after the upcoming loss of support for some outdated browsers (as discussed at Browser incompatibility).
Perhaps the outgoing email template can be customized to include a prominent explanation of the fact that the addressees are not engaged in a private email exchange?
