The Deauther watch reprogrammed - SOLVED
Hello I bought the Deauther watch. Not for what it can do with Wifi. But the watch itself. I'm trying to reprogram the watch But I'm having problem with trying to get the screen working. I did findout it was using I2C and the esp8266-12f is the processor. But I can not get it working at all. One library I found online displayed a lot of garbage second one showed the same thing but there was a hissing noise coming from the watch. That doesn't seem good and I do not know what that is.
Has anyone gotten the watch to work, Can you please help me out? Pointing me to a good library.
Joseph
Did you try the library the original deauther sketch uses?
All i found was bin files all over for different versions no libraries.
Joseph
Please provide links to the details about this watch.
Mine I got from amazon it was cheap. Here It is. I only paid $19.99 it was on sale now it's like $33.00.
Joseph
The original deauther sketch (which I'm sure the sellers of that watch are using) uses this library:
It is available in Library Manager as "ESP8266 and ESP32 OLED driver for SSD1306 displays by ThingPulse, Fabrice Weinberg".
From What I have read mine is a sh1106 display?
Edit: It looks like a option for the 1106.
Joseph
Hello, I have tried the example sketch withe the ssd1306 and the sh1106 both nothing.
Here is whatr I have done for the sh1106
   The MIT License (MIT)
   Copyright (c) 2018 by ThingPulse, Daniel Eichhorn
   Copyright (c) 2018 by Fabrice Weinberg
   Permission is hereby granted, free of charge, to any person obtaining a copy
   of this software and associated documentation files (the "Software"), to deal
   in the Software without restriction, including without limitation the rights
   to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
   copies of the Software, and to permit persons to whom the Software is
   furnished to do so, subject to the following conditions:
   The above copyright notice and this permission notice shall be included in all
   copies or substantial portions of the Software.
   THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
   IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
   FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
   AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
   LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
   OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
   SOFTWARE.
   ThingPulse invests considerable time and money to develop these open source libraries.
   Please support us by buying our products (and not the clones) from
   https://thingpulse.com
// Include the correct display library
// For a connection via I2C using the Arduino Wire include:
#include <Wire.h>               // Only needed for Arduino 1.6.5 and earlier
//#include "SSD1306Wire.h"        // legacy: #include "SSD1306.h"
#include "SH1106Wire.h"   // legacy: #include "SH1106.h"
// For a connection via I2C using brzo_i2c (must be installed) include:
// #include <brzo_i2c.h>        // Only needed for Arduino 1.6.5 and earlier
// #include "SSD1306Brzo.h"
// OR #include "SH1106Brzo.h"
// For a connection via SPI include:
// #include <SPI.h>             // Only needed for Arduino 1.6.5 and earlier
// #include "SSD1306Spi.h"
// OR #include "SH1106SPi.h"
// Optionally include custom images
#include "images.h"
// Initialize the OLED display using Arduino Wire:
//SSD1306Wire display(0x3c, SDA, SCL);   // ADDRESS, SDA, SCL  -  SDA and SCL usually populate automatically based on your board's pins_arduino.h e.g. https://github.com/esp8266/Arduino/blob/master/variants/nodemcu/pins_arduino.h
// SSD1306Wire display(0x3c, D3, D5);  // ADDRESS, SDA, SCL  -  If not, they can be specified manually.
// SSD1306Wire display(0x3c, SDA, SCL, GEOMETRY_128_32);  // ADDRESS, SDA, SCL, OLEDDISPLAY_GEOMETRY  -  Extra param required for 128x32 displays.
 SH1106Wire display(0x3c, SDA, SCL);     // ADDRESS, SDA, SCL
// Initialize the OLED display using brzo_i2c:
// SSD1306Brzo display(0x3c, D3, D5);  // ADDRESS, SDA, SCL
// or
// SH1106Brzo display(0x3c, D3, D5);   // ADDRESS, SDA, SCL
// Initialize the OLED display using SPI:
// D5 -> CLK
// D7 -> MOSI (DOUT)
// D0 -> RES
// D2 -> DC
// D8 -> CS
// SSD1306Spi display(D0, D2, D8);  // RES, DC, CS
// or
// SH1106Spi display(D0, D2);       // RES, DC
#define DEMO_DURATION 3000
typedef void (*Demo)(void);
int demoMode = 0;
int counter = 1;
  // Initialising the UI will init the display too.
  display.init();
  display.flipScreenVertically();
  display.setFont(ArialMT_Plain_10);
void drawFontFaceDemo() {
  // Font Demo1
  // create more fonts at http://oleddisplay.squix.ch/
  display.setTextAlignment(TEXT_ALIGN_LEFT);
  display.drawString(0, 0, "Hello world");
  display.setFont(ArialMT_Plain_16);
  display.drawString(0, 10, "Hello world");
  display.setFont(ArialMT_Plain_24);
  display.drawString(0, 26, "Hello world");
void drawTextFlowDemo() {
  display.drawStringMaxWidth(0, 0, 128,
                             "Lorem ipsum\n dolor sit amet, consetetur sadipscing elitr, sed diam nonumy eirmod tempor invidunt ut labore." );
void drawTextAlignmentDemo() {
  // Text alignment demo
  // The coordinates define the left starting point of the text
  display.drawString(0, 10, "Left aligned (0,10)");
  // The coordinates define the center of the text
  display.setTextAlignment(TEXT_ALIGN_CENTER);
  display.drawString(64, 22, "Center aligned (64,22)");
  // The coordinates define the right end of the text
  display.setTextAlignment(TEXT_ALIGN_RIGHT);
  display.drawString(128, 33, "Right aligned (128,33)");
void drawRectDemo() {
  // Draw a pixel at given position
  for (int i = 0; i < 10; i++) {
    display.setPixel(i, i);
    display.setPixel(10 - i, i);
  display.drawRect(12, 12, 20, 20);
  // Fill the rectangle
  display.fillRect(14, 14, 17, 17);
  // Draw a line horizontally
  display.drawHorizontalLine(0, 40, 20);
  display.drawVerticalLine(40, 0, 20);
void drawCircleDemo() {
  for (int i = 1; i < 8; i++) {
    display.setColor(WHITE);
    display.drawCircle(32, 32, i * 3);
    if (i % 2 == 0) {
      display.setColor(BLACK);
    display.fillCircle(96, 32, 32 - i * 3);
void drawProgressBarDemo() {
  int progress = (counter / 5) % 100;
  // draw the progress bar
  display.drawProgressBar(0, 32, 120, 10, progress);
  // draw the percentage as String
  display.drawString(64, 15, String(progress) + "%");
void drawImageDemo() {
  // see http://blog.squix.org/2015/05/esp8266-nodemcu-how-to-create-xbm.html
  // on how to create xbm files
  display.drawXbm(34, 14, WiFi_Logo_width, WiFi_Logo_height, WiFi_Logo_bits);
Demo demos[] = {drawFontFaceDemo, drawTextFlowDemo, drawTextAlignmentDemo, drawRectDemo, drawCircleDemo, drawProgressBarDemo, drawImageDemo};
int demoLength = (sizeof(demos) / sizeof(Demo));
long timeSinceLastModeSwitch = 0;
  // clear the display
  display.clear();
  // draw the current demo method
  demos[demoMode]();
  display.drawString(128, 54, String(millis()));
  // write the buffer to the display
  display.display();
  if (millis() - timeSinceLastModeSwitch > DEMO_DURATION) {
    demoMode = (demoMode + 1)  % demoLength;
    timeSinceLastModeSwitch = millis();
  counter++;
  delay(10);
Joseph
The SH1106 might be using SPI communication instead of I2C. Try configuring the sketch to use that by commenting the SH1106Wire type instantiation line and uncommenting the SSD1306Spi one instead.
Same thing.
Joseph
I found this library and text show up. It is a i2c scanner on oled text. Here is a image. At least this will get me started.
Joseph
