Oreck Commercial Upright XL2100 Reviews: An Affordable Heavy-duty Option
Do you want to handle debris in large areas without spending too much money? Lets have a look at the Oreck Commercial Upright XL2100 - Picking the Best Vacuum Cleaner: Our Expert Recommendations
. It will surprise you with its powerful cleaning performances despite its competitive price.
Design
Made in the U.S., this Oreck commercial vacuum is an ideal solution for cleaning all types of debris in large areas. This slim upright model can deal with multiple kinds of floors in your office or residential houses.
The design of the XL2100 has a low profile, which lays almost flat, enabling the vacuum to work well under your furniture without a hitch. With a weight of just 8 lbs, you can move this Oreck model around your house, especially the walls, easily. It comes with disposable paper dust bags. This means you no longer need to deal with disgusting filters and dust cups. But remember to replace them often, even when theyre not full yet.
The side brushes, which not every vacuum has, make sure that you can clean along baseboards and corners efficiently.
A special feature of this vacuum is its helping handle. It is designed half-way down to make your cleaning process more comfortable and easier by eliminating twisting or bending of your wrist and the squeezing of the hand. You will have comfort while maneuvering the machine around your furniture. The Arthritis Foundation has acknowledged this effort in ergonomics from Oreck by awarding the Easy of Use certification.
Oreck offers multiple path nozzle sizes for you. With a 12-inch cleaning path version, the XL2100 can reduce the need to move back and forth a lot. As a result, cleaning large rooms is easily and quickly with the wider nozzles. But a narrower one can let you maneuver between tight spaces. So before choosing the right version, you should consider the buildings, floor plans, and furniture youre going to cleaning with this upright vacuum.
The sweeper of the vacuum has a non-marring, clear bumper, which can protect your furniture, baseboards, and walls from any damage caused while youre using this machine.
Suction Power
The suction of this Oreck vacuum cleaner is strong enough to take care of most debris in the first pass. It uses direct technology, making it powerful to handle dust not only on carpeted floors but also larger particles on your hardwood floors. This upright vacuum cleaner also works incredibly well with pet hair on those surfaces.
Oreck integrates a 12-inch brush roll in this model with the purpose of improving its efficiency and effectiveness. The machine can rotate at a speed of up to 6500 RPM, collecting dirt into its inlet suction. Compared to other commercial vacuums, the XL2100 needs a power of only 480 W. This is a notable reason why customers who want to reduce power consumption will love this machine.
Dirt Bags & Filtration System
As we have mentioned in this Oreck vacuum review, the XL2100 collects dust and dirt by using disposable bags.
Those bags have large capacities with three layers. You can have peace of mind when it comes to hygiene since the built-in Hypoallergenic system can deep-filter, removing the harmful allergens. Those hypoallergenic bags can prevent the growth of fungi or bacteria and the allergic reactions pretty well, thanks to an antimicrobial agent.
To make the step of changing bags easier for you, Oreck also introduces a unique bag-docking mechanism in the XL2100. Although you must buy them often, the bags are usually cheap. You can even order a bunch of them online in advance before you run out of them.
With its 8-quart capacity, the XL2100 is not just a suitable option for large houses but also an ideal choice for commercial needs.
Overall, the filtration system also has great performances. It can cut down on the mold, mold, and other kinds of allergens. Your house will now be free from those harmful particles. The state-of-the-art Filter Knit system will also reduce the number of large particles in the air.
❊❊❊ Visit This Site:
Best Vacuum Cleaners In The World: Discover the World's Highest Rated Vacuums
Usability
If your house has so many appliances or furniture, vacuuming is usually challenging, especially with tools that are not designed for this situation. But its not the case here.
The XL2100 possesses a low-profile design, which can get into low-height areas under tight spots. This creative choice lets the vacuum lay flat on the floors when you turn its handle sideways and bend it over. The machine now can go directly and deeply into those hidden areas. You may be surprised by how much debris has accumulated when this Oreck vacuum collects them all.
The power cord is 35 feet long, quite enough for even large areas. It is also removable, which you can take advantage of to store it with less space. This also makes the job of replacing damaged cords by wear and tear easier. The official store and other authorized resellers both provide the replacement power cords at a low price.
Performances
As you can see from other Oreck XL vacuum reviews, it can work well with carpeted surfaces, even your walls. It can keep your house free from sand, allergens, and other particles that can damage your carpets if you ignore them.
The motorized brush spins at a speed of 6500 RPM. With stiff bristles, it can dig deep in your carpet strands. This is the main reason making it a great tool for deep cleaning, including pet hair. If you dont rely on the swivel steering feature too much, it has no problem when it comes to maneuvering.
But if your house or office has a lot of upholstery and stairs to clean, its time to find another product. Being built as a dedicated floor cleaning machine, the XL2100 is heavy and doesnt have any mini motorized brush roll.
On hardwood floors, you may encounter the risk of damaging your floors since this machine does not have the ability to turn on or off the brush roll manually. Its stiff bristles keep running during the cleaning process, which can leave serious scratches behind. So if youre responsible mostly for hardwood surfaces, we recommend you to find another solution like the Dyson V6. Coming with a softer cleaning head, it has the edge over the Oreck model, posing no threat against your sensitive floors.
Pros and Cons
** Pros**
- Affordable
- Strong suction power
- Side brushes to protect your walls and baseboards
- An ideal solution for deep cleaning
- Long power cord
** Cons**
- No LED headlights
- No swivel steering
- Only capable of floor cleaning
- Short warranty period
Conclusion
The Oreck Commercial XL2100 is one of the
Best Vacuum Cleaners Review. This heavy-duty model is an ideal machine you can use to clean large areas, which most ordinary products may fail to satisfy you. The best part is that it wont cost you a lot despite its potential.
As long as you dont need too much versatility and high-end maneuverability technologies like swivel steering, this is a decent and affordable option for deep cleaning.
