Dear Sirs!
I got my Yun dead while reflashing the Linino image with U-boot. Please, don't ask why I did that...I mean "U-booting" - it seemed that was my mistake.
Now the usb-led is always on and it is possible to upload the YunSerialTerminal example but there is nothing can be seen in IDE Serial Terminal.
Holding the wifi reset button for more than 30 seconds gives nothing. So I believe that the image is corrupted...
I do realize that warranty is void but is there a way to overcome the issue I described above?
Your prompt reply will be highly appreciated.
Best regards.
sir:
i got the same problems as yours completely!
does anyone could solve the problems?
best regards!
icekot:
Dear Sirs!
Best regards.
could anybody show me how to find the programmer firmware of linino?Thanks a lot!!!
Hyman_Smith:
sir:i got the same problems as yours completely!
best regards!
icekot:
Dear Sirs!
Best regards.
I have the same problem. Uboot d'ont work. USB led is ON. Linino side d'ont work .
noblepepper:
[ 41.460000] fuse init (API version 7.20).
This is in the final steps of the boot process, if you are getting this far you missed failsafe mode.
You have to be VERY quick to interrupt the boot process, I do it this way:
- Upload YunSerialTerminal
- Open Serial Monitor
- Put an "f" in the box at the top of the Serial Monitor
- Push YunRST button by the leds
- Have the cursor over the "Send" button at the upper right of the Serial Monitor
- Click "Send" when "Press the [f] key and hit [enter] to enter failsafe mode" comes up
You should see this:
[ 5.290000] Error: Driver 'gpio-keys-polled' is already registered, aborting...
[ 5.330000] scsi 0:0:0:0: Direct-Access Multi Flash Reader 1.00 PQ: 0 ANSI: 0
- preinit -
f - failsafe -
/etc/preinit: line 1: telnetd: not found
BusyBox v1.19.4 (2013-08-07 16:16:02 CEST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
___ ___ ___ ___
/_\ ___ /_\ ___ /_\ /\ \
/:/ / /::_\ /:/|:| |__ /::_\ /:/|:| |__ /:/ :\ \
/:/__/ /:/// /
|:| /_\ /:/// /
|:| /_\ /:/__/ :_
:\ \ :_\ |::/ / :_\ |::/ / :/:/ /
:_\ // /:/ / // /:/ / ::/ /
_______ ________ __
| - || _ | -| || | | || || |
|_____|| |||||___||| |____|
|| W I R E L E S S F R E E D O M
root@(none):/#
Notice the boot counter has only gotten to [ 5.330000] when failsafe is available, the fuse init is at [ 41.460000] Make sure you are in failsafe with the `root@(none):/# `prompt, if you seeHit any key to stop autoboot: 4 3 0
ar7240>you are uboot, just press the YunRST again and wait for failsafe
Thanks for all, but it isn't possible to do. After pressing Yun Rst boot process don't initiates. I think boot flash is corrupted or erased.
How can I reload boot system if I haven't life on this side?
http://forum.arduino.cc/index.php?topic=214167.msg1569407#msg1569407
Plan B or Plan D.
