The most basic GET-request with an Ethernet Shield - HELP
I'm struggling for weeks now to get a basic GET-request with an Arduino UNO in combination with the Ethernet shield. I want to use this configuration due to the stability of a wired network. The Arduino kit talks to a computer which runs a lighting program and which can accept HTTP-requests. On a trigger input a sequence of requests (with acceptable delay between each request) is send to trigger a lightshow.
Important to mention that it is a basic HTTP request, https gives issues.
There is not authentication or anything.
The computer is set to a static IP, and so is the arduino set in the same range.
If I test the GET-requests with Postman, it works as supposed.
Somehow I can't get the GET-request working on Arduino.
I've removed the whole sequence to sort out why it isn't working and just send a single request after boot every second, but nothing happens.
Anyone with advise how to make this working?
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
EthernetClient client;
// const char server[] = "192.168.178.201";  // server address [on-site]
const char server[] = "172.16.1.5";  // server address [office]
const int port = 80;
  // You can use Ethernet.init(pin) to configure the CS pin
  //Ethernet.init(10);  // Most Arduino shields
  //Ethernet.init(5);   // MKR ETH shield
  //Ethernet.init(0);   // Teensy 2.0
  //Ethernet.init(20);  // Teensy++ 2.0
  //Ethernet.init(15);  // ESP8266 with Adafruit Featherwing Ethernet
  //Ethernet.init(33);  // ESP32 with Adafruit Featherwing Ethernet
  while (!Serial) {
    ;  // wait for serial port to connect. Needed for native USB port only
  // start the Ethernet connection:
  Serial.println("Initialize Ethernet with DHCP:");
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    // Check for Ethernet hardware present
    if (Ethernet.hardwareStatus() == EthernetNoHardware) {
      Serial.println("Ethernet shield was not found.  Sorry, can't run without hardware. :(");
      while (true) {
        delay(1);  // do nothing, no point running without Ethernet hardware
    if (Ethernet.linkStatus() == LinkOFF) {
      Serial.println("Ethernet cable is not connected.");
    Serial.print("  DHCP assigned IP ");
    Serial.println(Ethernet.localIP());
  // give the Ethernet shield a second to initialize:
  Serial.println("Sending request");
  client.println("GET /RemoteCommands?SetFadeTime=4 HTTP/1.1");
  client.println("Host: " + String(server));
  client.println("User-Agent: arduino-ethernet");
  client.println("Connection: close");
  // client.println("Connection: keep-alive");
  client.println();
  // if (client.connect(server, port)) {
  //   Serial.println("Sending request");
  //   client.println("GET /RemoteCommands?SetFadeTime=4 HTTP/1.1");
  //   client.println("Host: " + String(server));
  //   client.println("User-Agent: arduino-ethernet");
  //   // client.println("Connection: close");
  //   client.println();
without client.connect nothing will happen
Hi @Juraj, thank you for your response.
I've originally had connect included, which didn't work. Did a new test after your reply, also no luck.
#include <SPI.h>
const char server[] = { 172, 16, 1, 5 };  // server address [office]
byte ip[] = { 172, 16, 1, 3 };
  Ethernet.begin(mac, ip);
  if (client.connect(server, 80)) {
    Serial.println("connected");
    client.println("GET /RemoteCommands/?SetFadeTime=4 HTTP/1.0");
    client.println();
    Serial.println("connection failed");
    client.println("GET /RemoteCommands/?SetFadeTime=4 HTTP/1.1");
    client.println();
try to run the WebClient example as it is
That returns in connection failed, but that makes sense since the ethernet shield is connected to a computer which has it's adapter settings to static, so the shield won't reach google.com.
And of course that is how the configuration has to be, the commands to be used are not through internet but directly to the software it's webserver.
I moved your topic to an appropriate forum category @darthvader072.
In the future, please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
can you ping the shield with that static IP?
Yes, 172.16.1.3 is the Arduino, .5 is the computer.
Ping
Also in LAN scan I see the Arduino with MAC DE:AD:BE:EF:FE:ED
so the computer has IP 172.16.1.5 and there is a webserver running which listens on this IP address and port 80 and the firewall is open for that IP and port?
Yes, this is the software settings.
device
This is postman, doing a succesful and working request. Also returning 200.
try
IPAddress server(172, 16, 1, 5);
Hi @Juraj
Thank you, that works, almost!
The arduino is connected and the software receives the commands.
However, the software can't handle this request yet but logs it with "request without host in http header".
The GET-request is likely made as HTTPS-request. however the software wants a real basic http-request. I've seen this issue before when I worked on this.
your code from the first post:
Right, that works. Thank you again.
So I've tried to set a sequence already, but that gives issues. It seems like only the first request is handled. Do you know the reason why I can't sequence requests?
#include <SPI.h>
// const char server[] = { 172, 16, 1, 5 };  // server address [office]
    client.println();
    client.println();
    client.println("GET /RemoteCommands/?SetFadeTime=3 HTTP/1.1");
    client.println();
    client.println("GET /RemoteCommands/?SetFadeTime=2 HTTP/1.1");
    client.println();
    client.println("GET /RemoteCommands/?SetFadeTime=1 HTTP/1.1");
    client.println();
  delay(5000);
read the response
The response on the software side is that it sometimes still responds with "request without host in http header. "
All other requests (SetFadeTime=3/2/1) are ignored..
I've overcomplicated my code by doing this:
    client.println();
    client.println();
    client.println();
    client.println();
This works but it unstable, I sometimes get the same response again "request without host in http header. "
A delay with a second between each request should work. Network is also stable and reliable (it is a 25cm shielded cable between ethernet shield and computer)
If I fire a lot of requests with postman it works as supposed.
I think I'm doing something wrong with the header I guess?
try
client.print("Host:");
client.println(server);
Hmm basically responds the same. It works but it still responds sometimes with the same error. if you follow the timecode you can see that it is sometimes that the error occurs. Of course I see visibly that it works on the other moments.
