The story of my user (and current headache)
I've been using electronics for a few years now and have decided to make a fancy smart alarm clock with an ESP8266 Wi-Fi module to use for geolocation to set time based on time-zone and maybe integrate AI to make a home assistant. The rest is an arduino uno, adafruit screw shield, voltage splitter (for the ESP's 3.3v architecture), LCD shield, and RTC module for timekeeping. but I keep getting the error ESP not found! and I am struggling with finding the reason. my wiring looks like the picture added, and my code is below as well. Ideas?
#include <Wire.h>
#include <RTClib.h>
#include <LiquidCrystal.h>
#include <WiFiEsp.h>         // WiFi library for ESP8266 AT mode
#include <WiFiEspUdp.h>      // UDP for NTP
#include <NTPClient.h>       // NTP client
#include <ArduinoJson.h>     // JSON parsing for API response
// RTC setup
RTC_DS3231 rtc;
// LCD pins (standard for LCD Keypad Shield)
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
// Button pin (analog for keypad)
const int btnPin = A0;
// Alarm settings (change these)
int alarmHour = 8;  // 24-hour format
int alarmMinute = 30;
bool alarmSet = true;  // Alarm enabled by default
// Variables for time and state
int currentHour, currentMinute, currentSecond;
bool alarming = false;
bool settingTime = false;  // For RTC time adjustment mode
const int buzzerPin = 3;  // Changed to free pin (avoid conflict with LCD pin 9)
// ESP8266 setup (using hardware Serial on pins 0/1)
char ssid[] = "YOUR_WIFI_SSID";  // Replace with your WiFi SSID
char pass[] = "YOUR_WIFI_PASSWORD";  // Replace with your WiFi password
int wifiStatus = WL_IDLE_STATUS;
// NTP setup (UTC initially)
WiFiEspUDP ntpUDP;
NTPClient timeClient(ntpUDP, "pool.ntp.org", 0, 60000);  // Pool server, 0 offset (UTC), update every 60s
// Variables for location/timezone
String currentTimezone = "";
String currentCity = "";
String currentCountry = "";
long timezoneOffset = 0;
  lcd.begin(16, 2);
  lcd.print("Alarm Clock");
  delay(2000);
  lcd.clear();
  if (!rtc.begin()) {
    lcd.print("RTC not found!");
    while (1);
  // Set initial time if RTC lost power (uncomment and upload once)
  // rtc.adjust(DateTime(F("Jul 30 2025"), F("09:43:00")));
  pinMode(buzzerPin, OUTPUT);
  digitalWrite(buzzerPin, LOW);
  // Initialize ESP8266 WiFi on hardware Serial
  Serial.begin(115200);  // Hardware serial for ESP (test baud 115200)
  // Serial.begin(74880);  // Uncomment to try boot baud if 115200 fails
  delay(1000);  // Delay to let ESP stabilize
  sendAT("AT+RST");  // Reset ESP before init
  delay(3000);  // Longer wait for reset
  WiFi.init(&Serial);
  // To enable debug, edit WiFiEsp library debug.h and set DEBUG_LEVEL to 4, then restart IDE
  // Retry loop for initialization (tries 3 times)
  int retries = 0;
  while (WiFi.status() == WL_NO_SHIELD && retries < 3) {
    lcd.print("ESP init retry...");
    delay(2000);
    sendAT("AT");  // Test AT during retries
    retries++;
  if (WiFi.status() == WL_NO_SHIELD) {
    lcd.print("ESP not found!");
    while (1);
    lcd.print("ESP detected!");
    sendAT("AT");  // Basic test command
    delay(3000);
    lcd.clear();
  // Connect to WiFi
  while (wifiStatus != WL_CONNECTED) {
    lcd.setCursor(0, 1);
    lcd.print("Connecting WiFi...");
    wifiStatus = WiFi.begin(ssid, pass);
    delay(5000);
  lcd.clear();
  lcd.print("WiFi Connected");
  // Sync time and timezone on startup
  syncTimeAndTimezone();
  delay(2000);
  lcd.clear();
// Function to send AT commands and print responses for debugging
void sendAT(String command) {
  Serial.println(command);
  lcd.print("Sent: " + command.substring(0, 8));  // Show on LCD (limited space)
  delay(3000);  // Longer wait for response (increased from 1000)
  String response = "";
  while (Serial.available()) {
    response += (char)Serial.read();
  if (response.length() > 0) {
    lcd.clear();
    lcd.print("Resp: " + response.substring(0, 8));  // Show response snippet on LCD
  delay(2000);
  lcd.clear();
  DateTime now = rtc.now();
  currentHour = now.hour();
  currentMinute = now.minute();
  currentSecond = now.second();
  // Display time
  lcd.setCursor(0, 0);
  lcd.print("Time: ");
  if (currentHour < 10) lcd.print("0");
  lcd.print(currentHour);
  lcd.print(":");
  if (currentMinute < 10) lcd.print("0");
  lcd.print(currentMinute);
  lcd.print(":");
  if (currentSecond < 10) lcd.print("0");
  lcd.print(currentSecond);
  // Display alarm status
  lcd.print("Alarm: ");
  if (alarmHour < 10) lcd.print("0");
  lcd.print(alarmHour);
  lcd.print(":");
  if (alarmMinute < 10) lcd.print("0");
  lcd.print(alarmMinute);
  lcd.print(alarmSet ? " ON " : " OFF");
  // Check for alarm trigger
  if (alarmSet && currentHour == alarmHour && currentMinute == alarmMinute && currentSecond == 0) {
    alarming = true;
  if (alarming) {
    tone(buzzerPin, 1000);  // Beep at 1kHz
    noTone(buzzerPin);
  // Read buttons (thresholds: right<60, up<200, down<400, left<600, select<800)
  int btnValue = analogRead(btnPin);
  if (btnValue < 60) {  // Right: Stop alarm fully
    alarming = false;
    alarmSet = false;  // Disable after trigger (optional)
  } else if (btnValue < 200) {  // Up: Increase hour (alarm or current time)
    if (settingTime) {
      currentHour = (currentHour + 1) % 24;
      alarmHour = (alarmHour + 1) % 24;
  } else if (btnValue < 400) {  // Down: Decrease minute (alarm or current time)
    if (settingTime) {
      currentMinute = (currentMinute > 0) ? currentMinute - 1 : 59;
      alarmMinute = (alarmMinute > 0) ? alarmMinute - 1 : 59;
  } else if (btnValue < 600) {  // Left: Toggle alarm OR sync time if held
    delay(500);  // Check for long press
    if (analogRead(btnPin) < 600) {  // Held: Sync time/timezone
    } else {  // Short: Toggle alarm
      alarmSet = !alarmSet;
  } else if (btnValue < 800) {  // Select: Toggle time set mode or snooze alarm
    if (alarming) {
      alarming = false;  // Snooze: Add 5 min to alarm
      alarmMinute += 5;
      if (alarmMinute >= 60) {
        alarmMinute -= 60;
      settingTime = !settingTime;  // Enter/exit RTC time set mode
      if (!settingTime) {
        // Save adjusted time to RTC
        rtc.adjust(DateTime(now.year(), now.month(), now.day(), currentHour, currentMinute, 0));
  delay(100);  // Basic debounce
void syncTimeAndTimezone() {
  lcd.clear();
  lcd.print("Syncing Time...");
  // Get UTC from NTP
  timeClient.begin();
  if (timeClient.forceUpdate()) {  // Force immediate sync
    unsigned long utcEpoch = timeClient.getEpochTime();
    // Get timezone/location from API
    WiFiEspClient client;
    if (client.connect("ip-api.com", 80)) {
      client.println("GET /json?fields=timezone,offset,city,country HTTP/1.1");
      client.println("Host: ip-api.com");
      client.println("Connection: close");
      client.println();
      while (client.connected() || client.available()) {
        if (client.available()) {
          response += client.readString();
      client.stop();
      // Parse JSON (response includes headers; find { start)
      int jsonStart = response.indexOf("{");
      if (jsonStart != -1) {
        String jsonStr = response.substring(jsonStart);
        DynamicJsonDocument doc(512);
        DeserializationError error = deserializeJson(doc, jsonStr);
        if (!error) {
          currentTimezone = doc["timezone"].as<String>();
          timezoneOffset = doc["offset"];
          currentCity = doc["city"].as<String>();
          currentCountry = doc["country"].as<String>();
          // Adjust to local epoch and set RTC
          unsigned long localEpoch = utcEpoch + (timezoneOffset);
          rtc.adjust(DateTime(localEpoch));
          // Optional: Display location/timezone briefly
          lcd.clear();
          lcd.print(currentCity + ", " + currentCountry);
          lcd.print(currentTimezone);
          delay(3000);
          lcd.clear();
          lcd.print("JSON Parse Fail");
          delay(2000);
        lcd.print("API Response Fail");
        delay(2000);
      lcd.print("API Connect Fail");
      delay(2000);
    lcd.print("NTP Sync Fail");
    delay(2000);
Post the verbose error log in code tags. Also, take a photo of a hand-drawn wiring diagram. What you posted is not useful.
Welcome to the forum
You mention both an ESP8266 and a Uno but have posted only one sketch
Is it an ESP-01 or an ESP-01S
Nvm, missed read.
using the ESP8266 (pictured below) for geolocation, the uno is the board I am using
an ESP-01
I may have to use a whole different wifi module, turns out the ones I use are really finnicky.
From you picture it looks like you have all 8 pins connected to the Uno but there ar no pins defined in your code. What is CH_EN, Reset, GPIO-0 and 2 set to?
I think they are standardized to be connected to 3.3v (according to my sources)
Not what I asked.
If CH_EN and Reset are not set to HIGH and GPIOs disconnected if you are not using them, then the module will either never work or you may have sporadic operation.
