The text on the screen writes from right to left, not left to right
I am trying to print text on UTFTLCD 3.5' screen with Arduino mega 2560. The screen is the screen in the video in this link.:
I installed the sample application on the screen and added some text.
The image on the screen is mirrored from right to left. The text I write is written from right to left. For example Hello - olleh. What should I do to normalize the image?
Only characters inverted or x/y axis as well? And characters are all good but just order is inverted?
Like when you print "TEST", is it draws that like "TƧƎT" or "TSET"?
When I write TEST it says TSET. All the writings are upside down. When I start x,y from 0,0, the text starts from the upper right corner of the screen. Not from the top left.
Show your sketch and your hardware. In the sketch we can see the libraries in use.
Are you using original kbv library or the one in the github repo you linked?
Also can you upload a photo of the problem and show the code you are using? Those things would fasten the things for us : )
I am using the original library. ı think.
File>Samples>UTFT>Arduino (AVR)>UTFT_DEmo_480x320
Arduino mega2560 + HUGA480x320 3.5' TFTLCD Shileded
Library: <UTFT.h>
I used sampeproject: File>Samples>UTFT>Arduino (AVR)>UTFT_DEmo_480x320
The solution in this link worked. Problem solved.
