Thermal Printer not printing text in english
Hi, I am using thermal printer model: QR204 with arduino uno.
When I send print command to print some text in english. the printed output is in Chinese.
I have attached the code and the printed paper.
#include <SoftwareSerial.h>
#define TX_PIN 5
#define RX_PIN 6
SoftwareSerial mySerial(RX_PIN, TX_PIN);
  mySerial.begin(9600);
  // Test English printing
  mySerial.println("Hello, World! This should print in English.");
  delay(2000); // Wait before printing again
read manual, change code page.
There was no manual in the package
There is a chance that it works like other thermal printers from better suppliers:
I tried this manual however the result is the same.
Please can you suggest a better thermal printer which can be connected to arduino and write english characters
well google is your friend
https://www.google.com/search?as_q=thermal+printer+change+characterset+from+chinese+to+latin+characters
you can try Cancel chinese mode 0x1C + 0x2E Some cheap aliexpress BT printers are default in Chinese mode, characters > 127
connecting to arduino can be done with all printers that have a serial interface.
If the electrical specification is RS232 or RS422 or RS485 you just insert a interface.
You should not buy from Aliexpress or banggood or amazon
because these shops do not aalways support with a datasheet and a usermanual.
So whatever shop you find check if the shop or the manufacturer provides the user-manual really download the user-manual and read it before buying.
Hi, I wans trying to write the new code but just cant figur out how to write it.Please if you can send the edited snipt of the code.
thank you in advance
Why did you pick "great programmer" for your username?
You are asking for something that requires having a user-manual
but you wrote
If you don't have a user-manual for your printer.
You could give the code of a different printer a try it it might work with your printer
You have already been given a link to such another code.
So you yourself should take the effort to test this code with your printer.
The main thing how this forum works is:
user males an own attempt and asks questions.
This own attempt must go beyond simply writing
You should post your complete sketch as a code-section and post a description of what your code is doing and what reactions you get from your thermal printer.
Hi, hope you all are doing well. I found the solution which is theat the thermal printer is connected inversly ( pritner RX to Arduino TX , and Printer TX to arduino RX). The wring was correct however in the code it was not mentioned.According to SoftwareSerial Liberary when the connection is invers the pin defination should be as follows
SoftwareSerial mySerial(RX_PIN, TX_PIN, true);
insted of
here is the final solution.
thank you for your support
Best Regards,
Waleed Tariq
