Hi Folks,
I just bought a MAX6675 Thermocouple module on ebay and i'm wondering if it's good for what i need.
I need to mensure the surface of an electrical resistence, But... there's no risk of a short circuit? I can touch the sensor on the surface?
You can try a contact-less IR temperature meter. They are a few dollars on Ebay and those are already very handy. Fluke has good quality meters of those.
You can get mineral insulated thermocouples. Unfortunately they are housed in a metal sleeve so, while the sensor is insulated from the sleeve the sleeve could still give a short circuit on something like a surface mount resistor.
I have seen thermocouples encapsulated in glass beads but they will be expensive. How about taking a bare thermocouple and encapsulating it yourself in a tiny drop of epoxy resin?
IR sensors have a wide field of view so may not be suitable.
Use a TO220 insulating sheet (rubbery grey heat resistant electrically insulating and
thermally conductive material)? Check the temperature range though.
Thanks for the tips!!
I researched those options... A contact-less sensor would be perfect, but I might not work on temperature lower than 350º (not sure).
Resistive wire at 350 degrees, I call that a toaster.
A thermocouple is not accurate to measure a room temperature, but it is the best option for high temperatures. Those mineral encapsulated ones still allow high temperatures.
I think you made the right choice.
