This sketch is part of a bigger thing, the rest works fine
This sketch stalls within the if statement as indicated and I can't see what is wrong. Can anybody see what is wrong?
if(lapCount>3){
lapCount=0;
Serial.println("Train slowing");
delay(dv);
digitalWrite(orangePin,HIGH);
digitalWrite(redPin,HIGH);
digitalWrite(bluePin,HIGH);
Serial.println("Train stopped");
delay(dv);
delay(StStop);
digitalWrite(bluePin,LOW);
                                      // sketch does not get past this point
Serial.print("Lap count = ");
Serial.println(lapCount);
delay(dv);
What makes you think that this is enough information for us to be able to find the problem?
Post the whole sketch.
Here is the whole thing :-
#include <LiquidCrystal.h>
int rs=7;
int en=8;
int d4=9;
int d5=10;
int d6=11;
int d7=12;
LiquidCrystal lcd(rs,en,d4,d5,d6,d7);
int lightPen=A0;
int lightVal;
int dv=2000;
int lival=450;
int j;
int lapCount;
int greenPin=2; //slow in zone B
int redPin=3; // Zone A stop
int bluePin=4; //Zone A slow
int greePin=5; //Zone A fast
int orangePin=6; //Zone B slow
int grePin=13; //Zone B fast
int dvl=500;
int dvs=2000;
int StStop=30000;
lcd.begin(16,2);
lapCount=0;
pinMode(lightPen,INPUT);
pinMode(redPin,OUTPUT);
pinMode(greenPin,OUTPUT);
pinMode(greePin,OUTPUT);
pinMode(grePin,OUTPUT);
pinMode(bluePin,OUTPUT);
pinMode(orangePin,OUTPUT);
lcd.setCursor(0,0);
lcd.print("Lap Count = ");
lcd.print(lapCount);
lightVal=analogRead(lightPen);
lcd.setCursor(0,2);
lcd.print("lightVal = ");
lcd.println(lightVal);
Serial.print("Lightval = ");
Serial.println(lightVal);
delay(dv);
if(lightVal<lival){
digitalWrite(orangePin,LOW); // ISO 1 & 3 closed - conducting current green
digitalWrite(redPin,LOW); // controller to fast in zone B green
digitalWrite(bluePin,LOW); // ISO 2 closed (current flow) green
lapCount=lapCount+1;
Serial.print("lapCount = ");
delay(dv);
if(lapCount>3){
Serial.println(" laps>3");
delay(dv);
digitalWrite(orangePin,HIGH); //Zone B slow, ISO 1 & 3 open (isolated) red
digitalWrite(redPin,HIGH); // Zone B slow - feed on slow red
digitalWrite(bluePin,HIGH); //Zone A stopped ISO 2 open (isolated) red
Serial.println("train stopped at station");
delay(dv);
delay(StStop); //station stop
digitalWrite(bluePin,LOW); //Zone A slow ISO 2 closed (current flow) green
lapCount=0;
delay(dv);
Serial.println("Moving out of station");
delay(dv);
Serial.println("Train cycling");
delay(dv);
Code in code tags, please.
And I think we might need to see a schematic. I don't know what your outputs are connected to and I'm wondering if one or more of them is behind the problem.
Add functional comments to the sketch to see what you want to happen during code processing.
Will this be a block controller for the model railway?
Using functional comments has found the dead end. The program is intended to stop at the station after 3 laps of the layout.
The outputs are to LEDs.
Rod
What is the application?
Thanks... Tom... :grinning: :+1: :coffee: :australia:
Here is the whole thing:-Use code tags to format code for the forum
//LOAD NANO FROM COM5
int rs = 7;
int en = 8;
int d4 = 9;
int d5 = 10;
int d6 = 11;
int d7 = 12;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
int lightPen = A0;
int lightVal;
int dv = 2000;
int lival = 450;
int j;
int lapCount;
int greenPin = 2;   //slow in zone B
int redPin = 3;     // Zone A stop
int bluePin = 4;    //Zone A slow
int greePin = 5;    //Zone A fast
int orangePin = 6;  //Zone B slow
int grePin = 13;    //Zone B fast
int dvl = 500;
int dvs = 2000;
int StStop = 30000;
  lcd.begin(16, 2);
  lapCount = 0;
  pinMode(lightPen, INPUT);
  pinMode(redPin, OUTPUT);
  pinMode(greenPin, OUTPUT);
  pinMode(greePin, OUTPUT);
  pinMode(grePin, OUTPUT);
  pinMode(bluePin, OUTPUT);
  pinMode(orangePin, OUTPUT);
  lcd.setCursor(0, 0);
  lightVal = analogRead(lightPen);
  lcd.setCursor(0, 2);
  delay(dv);
  if (lightVal < lival) {
    digitalWrite(orangePin, LOW);  // ISO 1 & 3 closed - conducting current green
    digitalWrite(redPin, LOW);     // controller to fast in zone B green
    digitalWrite(bluePin, LOW);    // ISO 2 closed (current flow) green
    lapCount = lapCount + 1;
    delay(dv);
    if (lapCount > 3) {
      delay(dv);
      digitalWrite(orangePin, HIGH);  //Zone B slow, ISO 1 & 3 open (isolated) red
      digitalWrite(redPin, HIGH);     // Zone B slow - feed on slow red
      digitalWrite(bluePin, HIGH);    //Zone A stopped ISO 2 open (isolated)  red
      delay(dv);
      digitalWrite(bluePin, LOW);  //Zone A slow ISO 2 closed  (current flow) green
      lapCount = 0;
      delay(dv);
    delay(dv);
  delay(dv);
}`Use code tags to format code for the forum`
StStopSchematic.pdf (363.3 KB)
HiTom,
Try this.
You only need to respond once with an answer, not once for each request.
Please post your images as jpg or png, then they will appear in you post.
Thanks for the schematic;
Where are the gnd connections to your relays?
How have you actually got the LDR connected?
Is it as a potential divider?
Please include how you have connected your LEDS.
Tom.. :grinning: :+1: :coffee: :australia:
Your code are simulated here:
"Trains-and-boats-and-plans - Wokwi ESP32, STM32, Arduino Simulator
When lapCount > 3 the delay is 30000, = 30 seconds, not a stall forever.
int StStop = 30000; delay(StStop); //station stop
Wait for 30 second and you see the program going ahead.
Hi Tom,
See attached photo. I have taken out the wires connecting the rails for clarity.
REgards
Rod
The sketch stalls past the next line of code :-
// the sketch stalls here
lapCount = 0;
Regards
Rod
Hi, @rodsadgrove
Can you please post a link to spec/data of the relays?
How much current do the relay coils consume?
You do not have back EMF protection diodes on the relay coils.
How are you powering your project?
Thanks.. Tom.. :grinning: :+1: :coffee: :australia:
It appears that your output pins are driving relays, not LEDs as you claimed. Are those SSRs, or are you driving inductive coils straight from an output pin without driving transistors or flyback diodes?
OK, I am driving LEDs thru the non latching relays. The green LEDs come on when the relay is not energised and the red LEDs are on when the relays are charged thru the output pins. When I get this sketch sorted out the LEDs will be replaced by other functions. The relays are Shrack PE014006.6VDC.
The relays are Shrack PE 014006 6VDC non latching.
I intend energising the relays thru the OUTPUT pins.
I have a 5V charger to power the NANO.
What do you suggest for EMF protection?
Rod
It doesn't matter what the relays are driving. The output pins are driving relay coils. Without a driving transistor. Without a flyback diode. Coils that require 34.8mA @ 6VDC to activate. From output pins that can supply 20mA @ 5VDC.
You are overloading the Nano's output pins. And those output pins are being damaged by the negative voltage spike generated whenever the coil switches off.
