'timer' was not declared in scope
I am trying to make an IOT garden that goes through Blynk and thought I found an easy code that would work that I got on instructables. But I have had to do many changes to it. Remember I have done very little coding so I just put some stuff together that I had found online in order to get less error messages so there is most likely many problems with the code. I am currently stumped becuase no matter what I get 'timer' was not declared in scope. Thank you ahead of time. My code is shown below.
`#define BLYNK_PRINT Serial
#include "DHT.h"
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#define BLYNK_TEMPLATE_ID ""
#define BLYNK_DEVICE_NAME "IOT Garden"
//DHT sensor information
#define DHTTYPE DHT22 // DHT 22 (AM2302), AM2321
#define DHTPIN 27 // Digital pin connected to the DHT sensor
DHT dht(DHTPIN, DHTTYPE); // Initialize DHT sensor.
//define input pins and outputs
int soil_sensor = 34; //define analog input pin number connected to moisture sensor
int output_value ;//define as output
int moisturelevel;//define as output
int notified = 0; //define notifed as 0
int timedelay= 60000L; //set timer to run get data once every minute or 60,000 miliseconds
//set minimum values for plant
int min_moisture =20;
int min_temperature =75;
int min_humidity =60;
// You should get Auth Token in the Blynk App.
char auth[ ] = "";
// Your WiFi credentials.
char ssid[] = "";
char pass[] = "";
// This function sends Arduino's up time every second to Virtual Pin (5).
// In the app, Widget's reading frequency should be set to PUSH. This means
// that you define how often to send data to Blynk App.
void Sensors () //main function to read sensors and push to blynk
output_value = analogRead(soil_sensor);// Read analog signal from soil_sensor and define as output_value
//Map output_vlaue from min,max values to 100,0 and constrain between 0,100
//Use sample code and serial monitor to find min and max values for individual sensor and soil type for better calibration
moisturelevel = constrain ( map(output_value, 1000, 4095, 100, 0), 0, 100);
float h = dht.readHumidity(); // Read humidity
float t = dht.readTemperature(); // Read temperature as Celsius (the default)
float f = dht.readTemperature(true); // Read temperature as Fahrenheit (isFahrenheit = true)
// Compute heat index in Fahrenheit (the default)
float hif = dht.computeHeatIndex(f, h);
// Check if any reads failed and exit early (to try again).
if (isnan(h) || isnan(t) || isnan(f)) {
Serial.println(F("Failed to read from DHT sensor!"));
return;
//This connects vales to virtual pins defined in the widgets in the Blynk app
Blynk.virtualWrite(V5, moisturelevel );// Send moisture level to virtual pin 5
Blynk.virtualWrite(V6,f);// Send temperature to virtual pin 6
Blynk.virtualWrite(V7,h);// Send humidity to virtual pin 7
Blynk.virtualWrite(V8,hif);// Send heat index to virtual pin 8
if (notified==0)
if (moisturelevel <= min_moisture) // If moisturelevel is equal to or below min value
Blynk.email("Email_Here", "Plant Monitor", "Water Plant!"); // Send email to water plant
delay (15000); // Blynk emails must be 15 seconds apart. Delay 15000 millisecons
if (f <= min_temperature) // If temperature is equal to or below min value
Blynk.email("Email_Here", "Plant Monitor", "Temperature Low!"); // Send email that temperature is low
if (h <= min_humidity) // If humidity is equal to or below min value
Blynk.email("Emial_Here", "Plant Monitor", "Humidity Low!"); // Send email that humidity is low
notified = 1;
timer.setTimeout(timedelay *5, resetNotified); // multipy timedelay by number of minutes wanted between repeat warning emails
void resetNotified() //function called to reset email frequency
notified = 0;
int Blynk.begin;
int timer;
Serial.begin(9600); // Debug console
Blynk.begin(auth, ssid, pass); // connect to blynk
timer.setInterval(timedelay, Sensors); // Setup a function to be called every minute or what timedelay is set to
dht.begin(); //run DHT sensor
//Void loop should only contain blynk.run and timer
int Blynk.run;
int timer;
Blynk.run(); // Run blynk
timer.run(); // Initiates BlynkTimer
Welcome to the forum
Your topic was MOVED to its current forum category as it is more suitable than the original
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
When you posted your code without code tags did you receive a warning message ?
The compiler is telling you there is no timer because you have not declared one in your code. It is not just a simple int variable, but part of the Blynk library. This is a good tutorial: Using BlynkTimer or SimpleTimer - FAQ - Blynk Community
Your code also contains many, many errors. I would suggest starting much, much smaller and get that working and then continue to build/test/verify it works rather than throw a bunch of code snippets randomly found on the internet together and hope.
