Timer With Custom Image Project
We’re working on a project using an Arduino UNO Rev3, an SD Breakout Board, and a 3.5" TFT 320x480 Touchscreen Breakout Board with an HX8357D driver. The goal is to create a timer that displays a custom image uploaded via an SD card, which gradually unveils as the timer counts down (selectable at 45, 30, or 25 minutes).
Our main concern is whether the Arduino UNO has enough memory to support a program capable of decoding and displaying images in this setup. Has anyone encountered similar memory constraints or found ways to handle image decoding effectively on an UNO with limited resources?
Consider using a Nextion display.
There should be no need to “decode” the image, save it to the SD card in a format that is compatible with the display, then read it from the card as needed when sendng it to the display.
There are examples in some of the libraries for displaying correctly formatted bitmap images from SD card.
Can you point me to those libraries exactly?
I have been using the following libraries in an attempt to display images:
#include <Adafruit_GFX.h>
#include <Adafruit_HX8357.h>
#include <SD.h>
#include <SPI.h>
