Displaying Bitmap Image from Micro SD on Adafruit TFT 1.8"
Hello!
I am pretty new to Arduino, Adafruit, and different projects, so I apologize if this is basic or has been asked before.
I am attempting to use a
1.8" Color TFT LCD display with MicroSD Card Breakout - ST7735R
with an
Arduino Uno Wifi Rev 2
I am attempting to follow the examples from Adafruit on how to display bitmaps from a SD Card on this TFT screen. I am using the example code from the Adafruit ImageReader Library called Breakout ST7735 - 160 x 128. However, all I get is a blank white screen.
Here is the tutorial I am following:
I have made edits to the code since my goal is to just get an image to appear on the screen. No looping or changing of imagery.
I got the wiring test to work eventually, so I believe my wiring is correct. I did have to make changes to the code to get this to work, so maybe I am missing something on bitmaps from an SD?
Here is the link to the wiring test:
Here is my code currently:
// Adafruit_ImageReader test for Adafruit ST7735 TFT Breakout for Arduino.
// Demonstrates loading images from SD card or flash memory to the screen,
// to RAM, and how to query image file dimensions.
// Requires three BMP files in root directory of SD card:
// parrot.bmp, miniwoof.bmp and wales.bmp.
// As written, this uses the microcontroller's SPI interface for the screen
// (not 'bitbang') and must be wired to specific pins (e.g. for Arduino Uno,
// MOSI = pin 11, MISO = 12, SCK = 13). Other pins are configurable below.
#include <Adafruit_GFX.h>         // Core graphics library
#include <Adafruit_ST7735.h>      // Hardware-specific library
#include <SdFat.h>                // SD card & FAT filesystem library
#include <Adafruit_ImageReader.h> // Image-reading functions
// Comment out the next line to load from SPI/QSPI flash instead of SD card:
#define USE_SD_CARD
// TFT display and SD card share the hardware SPI interface, using
// 'select' pins for each to identify the active device on the bus.
#define SD_CS    4 // SD card select pin
#define TFT_CS  10 // TFT select pin
#define TFT_DC   8 // TFT display/command pin
#define TFT_RST  -1 // Or set to -1 and connect to Arduino RESET pin
  SdFat                SD;         // SD card filesystem
  Adafruit_ImageReader reader(SD); // Image-reader object, pass in SD filesys
Adafruit_ST7735      tft    = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_RST);
Adafruit_Image       img;        // An image loaded into RAM
int32_t              width  = 160, // BMP image dimensions
                     height = 128;
void setup(void) {
  ImageReturnCode stat; // Status from image-reading functions
  // The Adafruit_ImageReader constructor call (above, before setup())
  // accepts an uninitialized SdFat or FatVolume object. This MUST
  // BE INITIALIZED before using any of the image reader functions!
  Serial.print(F("Initializing filesystem..."));
  // SD card is pretty straightforward, a single call...
  SD.begin(SD_CS, SD_SCK_MHZ(10)); { // Breakouts require 10 MHz limit due to longer wires
    Serial.println(F("SD begin() failed"));
    for(;;); // Fatal error, do not continue
  // Load full-screen BMP file 'parrot.bmp' at position (0,0) (top left).
  // Notice the 'reader' object performs this, with 'tft' as an argument.
  Serial.print(F("Loading parrot.bmp to screen..."));
  stat = reader.drawBMP("/parrot.bmp", tft, 0, 0);
  reader.printStatus(stat);   // How'd we do?
Any help is appreciated!
I am happy to upload a photo of my setup, or draw out a wiring diagram for anyone who can help.
Thanks!
Please do so.
Things to be aware of when using the Uno WiFi Rev2
I2C pins are not on A4 and A5
SPI pins are not on 11/12/13
Thanks for responding!
I made this in TinkerCad real quick. Sorry if this is a bad way to show what I am doing but I think this might be better than just a photo of my desk. If not, I can take a literal picture of the setup and post it.
To match to the TFT screen pinout here is the list:
Arduino Uno Wifi Rev3 to TFT 1.8" Pinout
GND : GND
5V : VCC
Reset : Reset
8 : D/C
4 : Card_CS
10 : TFT CS
11 : MOSI
13 : SCK
12 : MISO
5V : Lite
Basically, I have the GND of the TFT screen matched up with 16 on the breadboard and the pins run down the line.
Here is the original code from the example unedited in case that helps:
#include <Adafruit_SPIFlash.h>    // SPI / QSPI flash library
#define USE_SD_CARD
#define TFT_RST  9 // Or set to -1 and connect to Arduino RESET pin
#if defined(USE_SD_CARD)
#else
  // SPI or QSPI flash filesystem (i.e. CIRCUITPY drive)
  #if defined(__SAMD51__) || defined(NRF52840_XXAA)
    Adafruit_FlashTransport_QSPI flashTransport(PIN_QSPI_SCK, PIN_QSPI_CS,
      PIN_QSPI_IO0, PIN_QSPI_IO1, PIN_QSPI_IO2, PIN_QSPI_IO3);
  #else
    #if (SPI_INTERFACES_COUNT == 1)
      Adafruit_FlashTransport_SPI flashTransport(SS, &SPI);
    #else
      Adafruit_FlashTransport_SPI flashTransport(SS1, &SPI1);
    #endif
  #endif
  Adafruit_SPIFlash    flash(&flashTransport);
  FatVolume        filesys;
  Adafruit_ImageReader reader(filesys); // Image-reader, pass in flash filesys
#endif
int32_t              width  = 0, // BMP image dimensions
                     height = 0;
void setup(void) {
#if !defined(ESP32)
  while(!Serial);       // Wait for Serial Monitor before continuing
#endif
  tft.initR(INITR_BLACKTAB); // Initialize screen
  if(!SD.begin(SD_CS, SD_SCK_MHZ(10))) { // Breakouts require 10 MHz limit due to longer wires
#else
  // SPI or QSPI flash requires two steps, one to access the bare flash
  // memory itself, then the second to access the filesystem within...
  if(!flash.begin()) {
    Serial.println(F("flash begin() failed"));
    for(;;);
  if(!filesys.begin(&flash)) {
    Serial.println(F("filesys begin() failed"));
    for(;;);
#endif
  Serial.println(F("OK!"));
  // Fill screen blue. Not a required step, this just shows that we're
  // successfully communicating with the screen.
  tft.fillScreen(ST7735_BLUE);
  // Query the dimensions of image 'miniwoof.bmp' WITHOUT loading to screen:
  Serial.print(F("Querying miniwoof.bmp image size..."));
  stat = reader.bmpDimensions("/miniwoof.bmp", &width, &height);
  if(stat == IMAGE_SUCCESS) { // If it worked, print image size...
    Serial.print(F("Image dimensions: "));
    Serial.print(width);
    Serial.write('x');
    Serial.println(height);
  // Load small BMP 'wales.bmp' into a GFX canvas in RAM. This should fail
  // gracefully on Arduino Uno and other small devices, meaning the image
  // will not load, but this won't make the program stop or crash, it just
  // continues on without it. Should work on Arduino Mega, Zero, etc.
  Serial.print(F("Loading wales.bmp to canvas..."));
  stat = reader.loadBMP("/wales.bmp", img);
  delay(2000); // Pause 2 seconds before moving on to loop()
  for(int r=0; r<4; r++) { // For each of 4 rotations...
    tft.setRotation(r);    // Set rotation
    tft.fillScreen(0);     // and clear screen
    // Load 4 copies of the 'miniwoof.bmp' image to the screen, some
    // partially off screen edges to demonstrate clipping. Globals
    // 'width' and 'height' were set by bmpDimensions() call in setup().
    for(int i=0; i<4; i++) {
      reader.drawBMP("/miniwoof.bmp", tft,
        (tft.width()  * i / 3) - (width  / 2),
        (tft.height() * i / 3) - (height / 2));
    delay(1000); // Pause 1 sec.
    // Draw 50 Welsh dragon flags in random positions. This has no effect
    // on memory-constrained boards like the Arduino Uno, where the image
    // failed to load due to insufficient RAM, but it's NOT fatal.
    for(int i=0; i<50; i++) {
      // Rather than reader.drawBMP() (which works from SD card),
      // a different function is used for RAM-resident images:
      img.draw(tft,                                    // Pass in tft object
        (int16_t)random(-img.width() , tft.width()) ,  // Horiz pos.
        (int16_t)random(-img.height(), tft.height())); // Vert pos
      // Reiterating a prior point: img.draw() does nothing and returns
      // if the image failed to load. It's unfortunate but not disastrous.
    delay(2000); // Pause 2 sec.
Thanks again for the time.
See my earlier comment about the SPI pins that are not on pins 11/12/13. The SPI signals are only on the 6-pin header.
Thank you so much!
I actually researched this more and found another post that you commented on regarding this. I appreciate your time.
Finally got this to work!
Thanks!
