pinMode(DETECT, INPUT)
pinMode(GATE, OUTPUT);
OCR1A = 5; //initialize the comparator A
OCR1B=7;//initialize the comparator B
TIMSK1 = 0x06; //enable comparator A and B
TCCR1A = 0x00; //timer control registers set for
TCCR1B = 0x00; //normal operation, timer disabled
// set up zero crossing interrupt
attachInterrupt(0,zeroCrossingInterrupt, RISING);
//Interrupt Service Routines
void zeroCrossingInterrupt(){ //zero cross detect
TCCR1B=0x05; //start timer with divide by 1024 input
TCNT1 = 0; //reset timer - count from zero
ISR(TIMER1_COMPA_vect){ //comparator match
PORTB = PORTB | 0b00000010; // Set Pin 8 HIGH
ISR(TIMER1_COMPB_vect){ //comparator match
PORTB = PORTB & 0b11111101; // Set Pin 8 LOW
TCCR1B = 0x00; // Disable Timer
void loop(){ // sample code to exercise the circuit
I can easily run above code with Timer 1 however when i use Timer 2 i can't be able to get it work.Any idea on this would be much appreciated.Clock is 16Mh with 1024 prescaler.
