I am trying to flash a DaVinci 1.0a 3D printer. I have installed Arduino and downloaded the GitHub files. Followed all the step as I understand them. However, I am recieving the following error:
'TimeTick_Configure' not declared in this scope.
Here is my current code:
This file is part of Repetier-Firmware.
Repetier-Firmware is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
Repetier-Firmware is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with Repetier-Firmware. If not, see <http://www.gnu.org/licenses/>.
This firmware is a nearly complete rewrite of the sprinter firmware
by kliment (https://github.com/kliment/Sprinter)
which based on Tonokip RepRap firmware rewrite based off of Hydra-mmm firmware.
Main author: repetier
Initial port of HAL to Arduino Due: John Silvia
This is the main Hardware Abstraction Layer (HAL).
To make the firmware work with different processors and toolchains,
all hardware related code should be packed into the hal files.
// You can set different sizes if you want, but with binary mode it does not get faster
#ifndef SERIAL_RX_BUFFER_SIZE
#define SERIAL_RX_BUFFER_SIZE 128
#endif
#ifndef HAL_H
#define HAL_H
#include <inttypes.h>
#include "pins.h"
#include "Print.h"
#include "fastio.h"
// Hack to make 84 MHz Due clock work without changes to pre-existing code
// which would otherwise have problems with int overflow.
#undef F_CPU
#define F_CPU 21000000 // should be factor of F_CPU_TRUE
#define F_CPU_TRUE 84000000 // actual CPU clock frequency
#define EEPROM_BYTES 4096 // bytes of eeprom we simulate
#define SUPPORT_64_BIT_MATH // Gives better results with high resultion deltas
// another hack to keep AVR code happy (i.e. SdFat.cpp)
#define SPR0 0
#define SPR1 1
// force SdFat to use HAL (whether or not using SW spi)
#undef SOFTWARE_SPI
#define TIMER0_PRESCALE 128
// Some structures assume no padding, need to add this attribute on ARM
#define PACK attribute ((packed))
#define INLINE attribute((always_inline))
// do not use program space memory with Due
#define PROGMEM
#define PGM_P const char *
typedef char prog_char;
#undef PSTR
#define PSTR(s) s
#undef pgm_read_byte_near
#define pgm_read_byte_near(x) ((int8_t)x)
#define pgm_read_byte(x) ((int8_t)x)
#undef pgm_read_float
#define pgm_read_float(addr) ((const float )(addr))
#undef pgm_read_word
//#define pgm_read_word(addr) ((const unsigned int )(addr))
#define pgm_read_word(addr) ((addr))
#undef pgm_read_word_near
#define pgm_read_word_near(addr) pgm_read_word(addr)
#undef pgm_read_dword
#define pgm_read_dword(addr) ((addr))
//#define pgm_read_dword(addr) (*(const unsigned long *)(addr))
#undef pgm_read_dword_near
#define pgm_read_dword_near(addr) pgm_read_dword(addr)
#define _BV(x) (1 << (x))
#define FSTRINGVALUE(var,value) const char var[] PROGMEM = value;
#define FSTRINGVAR(var) static const char var[] PROGMEM;
#define FSTRINGPARAM(var) PGM_P var
#define EXTRUDER_TIMER TC0
#define EXTRUDER_TIMER_CHANNEL 0
#define EXTRUDER_TIMER_IRQ ID_TC0
#define EXTRUDER_TIMER_VECTOR TC0_Handler
#define PWM_TIMER TC0
#define PWM_TIMER_CHANNEL 1
#define PWM_TIMER_IRQ ID_TC1
#define PWM_TIMER_VECTOR TC1_Handler
#define TIMER1_TIMER TC2
#define TIMER1_TIMER_CHANNEL 2
#define TIMER1_TIMER_IRQ ID_TC8
#define TIMER1_COMPA_VECTOR TC8_Handler
#define SERVO_TIMER TC2
#define SERVO_TIMER_CHANNEL 0
#define SERVO_TIMER_IRQ ID_TC6
#define SERVO_COMPA_VECTOR TC6_Handler
#define BEEPER_TIMER TC1
#define BEEPER_TIMER_CHANNEL 0
#define BEEPER_TIMER_IRQ ID_TC3
#define BEEPER_TIMER_VECTOR TC3_Handler
#define DELAY_TIMER TC1
#define DELAY_TIMER_CHANNEL 1
#define DELAY_TIMER_IRQ ID_TC4 // IRQ not really used, needed for pmc id
#define DELAY_TIMER_CLOCK TC_CMR_TCCLKS_TIMER_CLOCK2
#define DELAY_TIMER_PRESCALE 8
//#define SERIAL_BUFFER_SIZE 1024
//#define SERIAL_PORT UART
//#define SERIAL_IRQ ID_UART
//#define SERIAL_PORT_VECTOR UART_Handler
// TWI1 if SDA pin = 20 TWI0 for pin = 70
#define TWI_INTERFACE TWI1
#define TWI_ID ID_TWI1
#define EXTRUDER_CLOCK_FREQ 60000 // extruder stepper interrupt frequency
#define PWM_CLOCK_FREQ 3906
#define TIMER1_CLOCK_FREQ 244
#define TIMER1_PRESCALE 2
#define SERVO_CLOCK_FREQ 1000
#define SERVO_PRESCALE 2 // Using TCLOCK1 therefore 2
#define SERVO2500US (((F_CPU_TRUE / SERVO_PRESCALE) / 1000000) * 2500)
#define SERVO5000US (((F_CPU_TRUE / SERVO_PRESCALE) / 1000000) * 5000)
#define AD_PRESCALE_FACTOR 84 // 500 kHz ADC clock
#define AD_TRACKING_CYCLES 4 // 0 - 15 + 1 adc clock cycles
#define AD_TRANSFER_CYCLES 1 // 0 - 3 * 2 + 3 adc clock cycles
#define ADC_ISR_EOC(channel) (0x1u << channel)
#define ENABLED_ADC_CHANNELS {TEMP_0_PIN, TEMP_1_PIN, TEMP_2_PIN}
#define PULLUP(IO,v) {pinMode(IO, (v!=LOW ? INPUT_PULLUP : INPUT)); }
// INTERVAL / (32Khz/128) = seconds
#define WATCHDOG_INTERVAL 1024u // 8sec (~16 seconds max)
#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"
#else
#include "WProgram.h"
#define COMPAT_PRE1
#endif
//#define READ(pin) PIO_Get(g_APinDescription[pin].pPort, PIO_INPUT, g_APinDescription[pin].ulPin)
#define READ_VAR(pin) (g_APinDescription[pin].pPort->PIO_PDSR & g_APinDescription[pin].ulPin ? 1 : 0) // does return 0 or pin value
#define _READ(pin) (DIO ## pin ## _PORT->PIO_PDSR & DIO ## pin ## _PIN ? 1 : 0) // does return 0 or pin value
#define READ(pin) _READ(pin)
//#define WRITE_VAR(pin, v) PIO_SetOutput(g_APinDescription[pin].pPort, g_APinDescription[pin].ulPin, v, 0, PIO_PULLUP)
#define WRITE_VAR(pin, v) do{if(v) {g_APinDescription[pin].pPort->PIO_SODR = g_APinDescription[pin].ulPin;} else {g_APinDescription[pin].pPort->PIO_CODR = g_APinDescription[pin].ulPin; }}while(0)
#define _WRITE(port, v) do { if (v) {DIO ## port ## _PORT -> PIO_SODR = DIO ## port ## _PIN; } else {DIO ## port ## _PORT->PIO_CODR = DIO ## port ## _PIN; }; } while (0)
#define WRITE(pin,v) _WRITE(pin,v)
#define SET_INPUT(pin) pmc_enable_periph_clk(g_APinDescription[pin].ulPeripheralId);
PIO_Configure(g_APinDescription[pin].pPort, PIO_INPUT, g_APinDescription[pin].ulPin, 0)
#define SET_OUTPUT(pin) PIO_Configure(g_APinDescription[pin].pPort, PIO_OUTPUT_1,
g_APinDescription[pin].ulPin, g_APinDescription[pin].ulPinConfiguration)
#define TOGGLE(pin) WRITE(pin,!READ(pin))
#define TOGGLE_VAR(pin) HAL::digitalWrite(pin,!HAL::digitalRead(pin))
#undef LOW
#define LOW 0
#undef HIGH
#define HIGH 1
// Protects a variable scope for interrupts. Uses RAII to force clearance of
// Interrupt block at the end resp. sets them to previous state.
// Uses ABSEPRI to allow higher level interrupts then the one changing firmware data
#if 1
class InterruptProtectedBlock {
public:
INLINE void protect() {
__disable_irq();
INLINE void unprotect() {
__enable_irq();
INLINE InterruptProtectedBlock(bool later = false) {
if (!later)
__disable_irq();
INLINE ~InterruptProtectedBlock() {
__enable_irq();
#else
uint32_t mask;
public:
inline void protect() {
mask = __get_PRIMASK();;
__disable_irq();
inline void unprotect() {
__set_PRIMASK(mask);
inline InterruptProtectedBlock(bool later = false) {
if (!later)
__disable_irq();
inline ~InterruptProtectedBlock() {
#endif
#define EEPROM_OFFSET 0
#define SECONDS_TO_TICKS(s) (unsigned long)(s*(float)F_CPU)
#define ANALOG_INPUT_SAMPLE 6
#define ANALOG_INPUT_MEDIAN 10
// Bits of the ADC converter
#define ANALOG_INPUT_BITS 12
#define ANALOG_REDUCE_BITS 0
#define ANALOG_REDUCE_FACTOR 1
// maximum available RAM
#define MAX_RAM 98303
#define bit_clear(x,y) x&= ~(1<<y) //cbi(x,y)
#define bit_set(x,y) x|= (1<<y)//sbi(x,y)
/** defines the data direction (reading from I2C device) in i2cStart(),i2cRepStart() /
#define I2C_READ 1
/* defines the data direction (writing to I2C device) in i2cStart(),i2cRepStart() */
#define I2C_WRITE 0
#ifndef DUE_SOFTWARE_SPI
extern int spiDueDividors[];
#endif
static uint32_t tone_pin;
/** Set max. frequency to 500000 Hz */
#define LIMIT_INTERVAL (F_CPU/500000)
typedef unsigned int speed_t;
typedef unsigned long ticks_t;
typedef unsigned long millis_t;
typedef unsigned int flag8_t;
typedef int fast8_t;
typedef unsigned int ufast8_t;
#ifndef RFSERIAL
#define RFSERIAL Serial // Programming port of the due
//#define RFSERIAL SerialUSB // Native USB Port of the due
#endif
#if defined(BLUETOOTH_SERIAL) && BLUETOOTH_SERIAL > 0
#if BLUETOOTH_SERIAL == 1
#define BT_SERIAL Serial1
#elif BLUETOOTH_SERIAL == 2
#define BT_SERIAL Serial2
#elif BLUETOOTH_SERIAL == 3
#define BT_SERIAL Serial3
#elif BLUETOOTH_SERIAL == 100
#elif BLUETOOTH_SERIAL == 101
#define BT_SERIAL SerialUSB
#endif
class RFDoubleSerial : public Print
public:
RFDoubleSerial();
void begin(unsigned long);
void end();
virtual int available(void);
virtual int peek(void);
virtual int read(void);
virtual void flush(void);
virtual size_t write(uint8_t);
using Print::write; // pull in write(str) and write(buf, size) from Print
extern RFDoubleSerial BTAdapter;
#endif
#define OUT_P_I(p,i) //Com::printF(PSTR(p),(int)(i))
#define OUT_P_I_LN(p,i) //Com::printFLN(PSTR(p),(int)(i))
#define OUT_P_L(p,i) //Com::printF(PSTR(p),(long)(i))
#define OUT_P_L_LN(p,i) //Com::printFLN(PSTR(p),(long)(i))
#define OUT_P_F(p,i) //Com::printF(PSTR(p),(float)(i))
#define OUT_P_F_LN(p,i) //Com::printFLN(PSTR(p),(float)(i))
#define OUT_P_FX(p,i,x) //Com::printF(PSTR(p),(float)(i),x)
#define OUT_P_FX_LN(p,i,x) //Com::printFLN(PSTR(p),(float)(i),x)
#define OUT_P(p) //Com::printF(PSTR(p))
#define OUT_P_LN(p) //Com::printFLN(PSTR(p))
#define OUT_ERROR_P(p) //Com::printErrorF(PSTR(p))
#define OUT_ERROR_P_LN(p) {//Com::printErrorF(PSTR(p));//Com::println();}
#define OUT(v) //Com::print(v)
#define OUT_LN //Com::println()
union eeval_t {
uint8_t b[4];
float f;
uint32_t i;
uint16_t s;
long l;
} PACK;
#if EEPROM_AVAILABLE == EEPROM_SDCARD
extern millis_t eprSyncTime;
#endif
class HAL
public:
// we use ram instead of eeprom, so reads are faster and safer. Writes store in real eeprom as well
// as long as hal eeprom functions are used.
static char virtualEeprom[EEPROM_BYTES];
static bool wdPinged;
HAL();
virtual ~HAL();
//Davinci Specific
#if FEATURE_BEEPER
static bool enablesound;
#endif //FEATURE_BEEPER
#if ENABLE_WIFI
static bool bwifion;
#endif //wifi feature
// do any hardware-specific initialization here
static inline void hwSetup(void)
#if !FEATURE_WATCHDOG
// Disable watchdog
WDT_Disable(WDT);
#endif
#if EEPROM_AVAILABLE == EEPROM_I2C || UI_DISPLAY_TYPE == 3 //init i2c when EEprom installed or using i2c display
HAL::i2cInit(TWI_CLOCK_FREQ);
#endif
// make debugging startup easier
//Serial.begin(115200);
TimeTick_Configure(F_CPU_TRUE);
// setup microsecond delay timer
pmc_enable_periph_clk(DELAY_TIMER_IRQ);
TC_Configure(DELAY_TIMER, DELAY_TIMER_CHANNEL, TC_CMR_WAVSEL_UP |
TC_CMR_WAVE | DELAY_TIMER_CLOCK);
TC_Start(DELAY_TIMER, DELAY_TIMER_CHANNEL);
#if EEPROM_AVAILABLE && EEPROM_MODE != EEPROM_NONE
// Copy eeprom to ram for faster access
int i;
for (i = 0; i < EEPROM_BYTES; i += 4) {
eeval_t v = eprGetValue(i, 4);
memcopy4(&virtualEeprom[i],&v.i);
#else
int i,n = 0;
memcopy4(&virtualEeprom[i],&n);
#endif
static uint32_t integer64Sqrt(uint64_t a);
// return val'val
static inline unsigned long U16SquaredToU32(unsigned int val)
return (unsigned long) val * (unsigned long) val;
static inline unsigned int ComputeV(long timer, long accel)
return static_cast<unsigned int>((static_cast<int64_t>(timer) * static_cast<int64_t>(accel)) >> 18);
//return ((timer>>8)*accel)>>10;
// Multiply two 16 bit values and return 32 bit result
static inline unsigned long mulu16xu16to32(unsigned int a, unsigned int b)
return (unsigned long) a * (unsigned long) b;
static inline unsigned int mulu6xu16shift16(unsigned int a, unsigned int b)
return ((unsigned long)a * (unsigned long)b) >> 16;
static inline unsigned int Div4U2U(unsigned long a, unsigned int b)
return ((unsigned long)a / (unsigned long)b);
static inline void digitalWrite(uint8_t pin, uint8_t value)
WRITE_VAR(pin, value);
static inline uint8_t digitalRead(uint8_t pin)
return READ_VAR(pin);
static inline void pinMode(uint8_t pin, uint8_t mode)
if (mode == INPUT) {
SET_INPUT(pin);
else SET_OUTPUT(pin);
static long CPUDivU2(speed_t divisor) {
return F_CPU / divisor;
static INLINE void delayMicroseconds(uint32_t usec)
{ //usec += 3;
uint32_t n = usec * (F_CPU_TRUE / 3000000);
asm volatile(
"L2_%=_delayMicroseconds:" "\n\t"
"subs %0, #1" "\n\t"
"bge L2_%=_delayMicroseconds" "\n"
: "+r" (n) :
static inline void delayMilliseconds(unsigned int delayMs)
unsigned int del;
while (delayMs > 0) {
del = delayMs > 100 ? 100 : delayMs;
delay(del);
delayMs -= del;
#if FEATURE_WATCHDOG
HAL::pingWatchdog();
#endif
static inline void tone(uint8_t pin, int frequency) {
// set up timer counter 1 channel 0 to generate interrupts for
// toggling output pin.
//Davinci Specific
#if FEATURE_BEEPER
if (!enablesound)return;
#endif
SET_OUTPUT(pin);
tone_pin = pin;
pmc_set_writeprotect(false);
pmc_enable_periph_clk((uint32_t)BEEPER_TIMER_IRQ);
// set interrupt to lowest possible priority
NVIC_SetPriority((IRQn_Type)BEEPER_TIMER_IRQ, NVIC_EncodePriority(4, 6, 3));
TC_Configure(BEEPER_TIMER, BEEPER_TIMER_CHANNEL, TC_CMR_WAVE | TC_CMR_WAVSEL_UP_RC |
TC_CMR_TCCLKS_TIMER_CLOCK4); // TIMER_CLOCK4 -> 128 divisor
uint32_t rc = VARIANT_MCK / 128 / frequency;
TC_SetRA(BEEPER_TIMER, BEEPER_TIMER_CHANNEL, rc / 2); // 50% duty cycle
TC_SetRC(BEEPER_TIMER, BEEPER_TIMER_CHANNEL, rc);
TC_Start(BEEPER_TIMER, BEEPER_TIMER_CHANNEL);
BEEPER_TIMER->TC_CHANNEL[BEEPER_TIMER_CHANNEL].TC_IER = TC_IER_CPCS;
BEEPER_TIMER->TC_CHANNEL[BEEPER_TIMER_CHANNEL].TC_IDR = ~TC_IER_CPCS;
NVIC_EnableIRQ((IRQn_Type)BEEPER_TIMER_IRQ);
static inline void noTone(uint8_t pin) {
TC_Stop(TC1, 0);
WRITE_VAR(pin, LOW);
static void syncEEPROM(); // store to disk if changed
static void importEEPROM();
#endif
static inline void eprSetByte(unsigned int pos, uint8_t value)
eeval_t v;
v.b[0] = value;
eprBurnValue(pos, 1, v);
*(uint8_t*)&virtualEeprom[pos] = value;
static inline void eprSetInt16(unsigned int pos, int16_t value)
eeval_t v;
v.s = value;
eprBurnValue(pos, 2, v);
memcopy2(&virtualEeprom[pos],&value);
static inline void eprSetInt32(unsigned int pos, int32_t value)
eeval_t v;
v.i = value;
eprBurnValue(pos, 4, v);
memcopy4(&virtualEeprom[pos],&value);
static inline void eprSetLong(unsigned int pos, long value)
eeval_t v;
v.l = value;
eprBurnValue(pos, sizeof(long), v);
static inline void eprSetFloat(unsigned int pos, float value)
eeval_t v;
v.f = value;
eprBurnValue(pos, sizeof(float), v);
static inline uint8_t eprGetByte(unsigned int pos)
return *(uint8_t*)&virtualEeprom[pos];
static inline int16_t eprGetInt16(unsigned int pos)
int16_t v;
memcopy2(&v,&virtualEeprom[pos]);
return v;
static inline int32_t eprGetInt32(unsigned int pos)
int32_t v;
memcopy4(&v,&virtualEeprom[pos]);
return v;
static inline long eprGetLong(unsigned int pos)
int32_t v;
return v;
static inline float eprGetFloat(unsigned int pos) {
float v;
return v;
// Write any data type to EEPROM
static inline void eprBurnValue(unsigned int pos, int size, union eeval_t newvalue)
#if EEPROM_AVAILABLE == EEPROM_SPI_ALLIGATOR
uint8_t eeprom_temp[3];
/*write enable*/
eeprom_temp[0] = 6;//WREN
WRITE( SPI_EEPROM1_CS , LOW );
spiSend(SPI_CHAN_EEPROM1 , eeprom_temp , 1);
WRITE( SPI_EEPROM1_CS , HIGH );
delayMilliseconds(1);
/*write addr*/
eeprom_temp[0] = 2;//WRITE
eeprom_temp[1] = ((pos >> 8) & 0xFF); //addrH
eeprom_temp[2] = (pos & 0xFF); //addrL
spiSend(SPI_CHAN_EEPROM1 , eeprom_temp , 3);
spiSend(SPI_CHAN_EEPROM1 , &(newvalue.b[0]) , 1);
for (int i = 1; i < size; i++) {
pos++;
// writes cannot cross page boundary
if ((pos % EEPROM_PAGE_SIZE) == 0) {
// burn current page then address next one
delayMilliseconds(EEPROM_PAGE_WRITE_TIME);
/*write enable*/
spiSend(SPI_CHAN_EEPROM1 , &(newvalue.b[i]) , 1);
delayMilliseconds(EEPROM_PAGE_WRITE_TIME); // wait for page write to complete
#elif EEPROM_AVAILABLE == EEPROM_I2C
i2cStartAddr(EEPROM_SERIAL_ADDR << 1 | I2C_WRITE, pos);
i2cWrite(newvalue.b[0]); // write first byte
pos++;
i2cStop();
i2cStartAddr(EEPROM_SERIAL_ADDR << 1, pos);
while ( (TWI_INTERFACE->TWI_SR & TWI_SR_TXRDY) != TWI_SR_TXRDY);// wait for transmission register to empty
i2cWrite(newvalue.b[i]);
i2cStop(); // signal end of transaction
#elif EEPROM_AVAILABLE == EEPROM_SDCARD
eprSyncTime = HAL::timeInMilliseconds() | 1UL;
#endif
// Read any data type from EEPROM that was previously written by eprBurnValue
static inline union eeval_t eprGetValue(unsigned int pos, int size)
int i = 0;
eeval_t v;
size--;
eeprom_temp[0] = 3;//READ
for (i = 0; i < size; i++) {
// read an incomming byte
v.b[i] = spiReceive(SPI_CHAN_EEPROM1);
// read last byte
return v;
int i;
eeval_t v;
size--;
// set read location
i2cStartAddr(EEPROM_SERIAL_ADDR << 1 | I2C_READ, pos);
v.b[i] = i2cReadAck();
// read last byte
v.b[i] = i2cReadNak();
return v;
#else
eeval_t v;
int i;
v.b[i] = 0;
return v;
#endif //(MOTHERBOARD==500) || (MOTHERBOARD==501)
static inline void allowInterrupts()
//__enable_irq();
static inline void forbidInterrupts()
//__disable_irq();
static inline unsigned long timeInMilliseconds()
return millis();
static inline char readFlashByte(PGM_P ptr)
return pgm_read_byte(ptr);
static inline void serialSetBaudrate(long baud)
Serial.setInterruptPriority(1);
BTAdapter.begin(baud);
#else
//ESP8266 Specific
#if ENABLE_WIFI
WIFI_SERIAL.begin(baud);
#endif
RFSERIAL.begin(baud);
#endif
static inline bool serialByteAvailable()
return BTAdapter.available();
#else
//ESP8266 Specific
#if ENABLE_WIFI
if(HAL::bwifion) return WIFI_SERIAL.available();
#endif
return RFSERIAL.available();
#endif
static inline uint8_t serialReadByte()
return BTAdapter.read();
#else
//ESP8266 Specific
#if ENABLE_WIFI
if(HAL::bwifion) return WIFI_SERIAL.read();
#endif
return RFSERIAL.read();
#endif
static inline void serialWriteByte(char b)
BTAdapter.write(b);
#else
//ESP8266 Specific
#if ENABLE_WIFI
if (HAL::bwifion)
WIFI_SERIAL.write(b);
if (b=='\n')
HAL::delayMilliseconds(DELAY_BY_LINE);
#endif
RFSERIAL.write(b);
#endif
static inline void serialFlush()
BTAdapter.flush();
#else
//ESP8266 Specific
#if ENABLE_WIFI
if(HAL::bwifion) WIFI_SERIAL.flush();
#endif
RFSERIAL.flush();
#endif
static void setupTimer();
static void showStartReason();
static int getFreeRam();
static void resetHardware();
// SPI related functions
#ifdef DUE_SOFTWARE_SPI
// bitbanging transfer
// run at ~100KHz (necessary for init)
static uint8_t spiTransfer(uint8_t b) // using Mode 0
for (int bits = 0; bits < 8; bits++) {
if (b & 0x80) {
WRITE(MOSI_PIN, HIGH);
WRITE(MOSI_PIN, LOW);
b <<= 1;
WRITE(SCK_PIN, HIGH);
delayMicroseconds(5);
if (READ(MISO_PIN)) {
b |= 1;
WRITE(SCK_PIN, LOW);
return b;
static inline void spiBegin()
SET_OUTPUT(SDSS);
WRITE(SDSS, HIGH);
SET_OUTPUT(SCK_PIN);
SET_INPUT(MISO_PIN);
SET_OUTPUT(MOSI_PIN);
static inline void spiInit(uint8_t spiClock)
WRITE(SDSS, HIGH);
static inline uint8_t spiReceive()
WRITE(SDSS, LOW);
uint8_t b = spiTransfer(0xff);
WRITE(SDSS, HIGH);
return b;
static inline void spiReadBlock(uint8_t*buf, uint16_t nbyte)
if (nbyte == 0) return;
WRITE(SDSS, LOW);
for (int i = 0; i < nbyte; i++)
buf[i] = spiTransfer(0xff);
WRITE(SDSS, HIGH);
static inline void spiSend(uint8_t b) {
WRITE(SDSS, LOW);
uint8_t response = spiTransfer(b);
WRITE(SDSS, HIGH);
static inline void spiSend(const uint8_t* buf , size_t n)
if (n == 0) return;
WRITE(SDSS, LOW);
for (uint16_t i = 0; i < n; i++) {
spiTransfer(buf[i]);
WRITE(SDSS, HIGH);
inline __attribute__((always_inline))
static void spiSendBlock(uint8_t token, const uint8_t* buf)
WRITE(SDSS, LOW);
spiTransfer(token);
for (uint16_t i = 0; i < 512; i++)
WRITE(SDSS, HIGH);
#else
// hardware SPI
static void spiBegin();
// spiClock is 0 to 6, relecting AVR clock dividers 2,4,8,16,32,64,128
// Due can only go as slow as AVR divider 32 -- slowest Due clock is 329,412 Hz
static void spiInit(uint8_t spiClock);
// Write single byte to SPI
static void spiSend(byte b);
static void spiSend(const uint8_t* buf , size_t n);
#if MOTHERBOARD == 500 || MOTHERBOARD == 501
static void spiSend(uint32_t chan , const uint8_t* buf , size_t n);
static void spiSend(uint32_t chan, byte b);
static uint8_t spiReceive(uint32_t chan);
#endif
// Read single byte from SPI
static uint8_t spiReceive();
// Read from SPI into buffer
static void spiReadBlock(uint8_t*buf, uint16_t nbyte);
// Write from buffer to SPI
static void spiSendBlock(uint8_t token, const uint8_t* buf);
#endif /DUE_SOFTWARE_SPI/
// I2C Support
static void i2cSetClockspeed(uint32_t clockSpeedHz);
static void i2cInit(unsigned long clockSpeedHz);
static void i2cStartWait(unsigned char address);
static uint8_t i2cStart(unsigned char address);
static void i2cStartAddr(unsigned char address, unsigned int pos);
static void i2cStop(void);
static void i2cStartBit(void);
static void i2cCompleted (void);
static void i2cTxFinished(void);
static void i2cWrite( uint8_t data );
static uint8_t i2cReadAck(void);
static uint8_t i2cReadNak(void);
// Watchdog support
inline static void startWatchdog() {
//Davinci Specific
uint32_t timeout = 8000 * 256 / 1000; //8000ms = 8s
if (timeout == 0) timeout = 1;
else if (timeout > 0xFFF) timeout = 0xFFF;
timeout = WDT_MR_WDRSTEN | WDT_MR_WDV(timeout) | WDT_MR_WDD(timeout);
WDT_Enable (WDT, timeout);
#endif
inline static void stopWatchdog() {WDT_Disable (WDT);}
inline static void pingWatchdog() {
wdPinged = true;
#endif
inline static float maxExtruderTimerFrequency() {
return (float)F_CPU_TRUE/32;
#if FEATURE_SERVO
static unsigned int servoTimings[4];
static void servoMicroseconds(uint8_t servo, int ms, uint16_t autoOff);
#endif
static void analogStart(void);
#if USE_ADVANCE
static void resetExtruderDirection();
#endif
static volatile uint8_t insideTimer1;
#endif // HAL_H
