TinyGPS wish to satellites
Hello everyone
I want to be able to read how many satellites are active right now.
Want to insert codes for satellites!
See mid-attempt below, which fails!
//Satellite Count
lcd.setCursor(0, 3;
lcd.print("satellites : ");
lcd.println(lat_val, 6);
Do you have a good suggestion for me to enter in my codes to be able to see many satellites?
My code
Look at the bottom of my codes...
#include <SoftwareSerial.h>
#include <TinyGPS.h>
SoftwareSerial serial_connection(19, 18);  //RX=pin 19, TX=pin 18
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 20, 4);
//long   lat,lon; // create variable for latitude and longitude object
float lat, lon;
TinyGPS gps;  // create gps object
  lcd.init();  // initialize the lcd
  lcd.init();
  lcd.backlight();
  Serial.begin(57600);  // connect serial
  Serial.println("The GPS Received Signal:");
  Serial1.begin(9600);  // connect gps sensor
  while (Serial1.available()) {      // check for gps data
    if (gps.encode(Serial1.read()))  // encode gps data
      gps.f_get_position(&lat, &lon);  // get latitude and longitude
      Serial.print("Position: ");
      //Latitude
      Serial.print("Latitude: ");
      Serial.print(lat, 6);
      Serial.print(",");
      //Longitude
      Serial.print("Longitude: ");
      Serial.println(lon, 6);
      //Longitude
      lcd.setCursor(0, 0);
      lcd.print("Latitude : ");
      lcd.print(lat, 5);
      lcd.setCursor(0, 1);
      lcd.print("Longitude: ");
      lcd.println(lon, 5);
      //**Satellite Count**
**       lcd.setCursor(0, 3;   **
**       lcd.print("satellites : ");**
**       lcd.println(lat_val, 6);**
In what specific way, does it fail? Did you forget a right parenthesis?
Try the more up to date TinyGPS++;
http://arduiniana.org/libraries/tinygpsplus/
Serial.println(gps.satellites.value()); // Number of satellites in use (u32)
I think for the older TinyGPS library its;
Serial.println(gps.satellites());
why init lcd twice...??
Hello everyone
Does anyone here have a code with TinyGPS++; So I can test my GPS device.
Preferably a single code version.
Whats a 'single code' version ?
The easy way to test a GPS is a simple echo program such as;
    Serial.write(Serial1.read());
  Serial.println("GPS_Echo_Hardware_Serial Starting");
