Hello,
It seems as though several people experienced the same problems that I encountered when I attempted to set up my Arduino DUE. Hopefully these steps will ease the set up for others.
Verify that you have a USB cable with data transmission. Some are charge only.
Go to Tools, Board, Boards Manager and add the Arduino DUE.
After adding the Arduino DUE then select Arduino DUE (Programming Port) from the board list.
Libraries must be installed with the board set to: Arduino DUE (Programming Port).
The LiquidCrystal_IC2 display needs only the LiquidCrystal_IC2 library installed and the right address & connection (0X27, 5V, GND, SDA, SCL)
It Works !
