Tlc5940 conflict with IRremote library
Have spent a long while getting all the separate components of my circuit working properly as little small circuits, but now that i'm joining them all together i've come across an issue, i have 2 Tlc5940's running 20 odd leds and they work fine till i add the code in for IRremote library (only using incoming IR signals not transmitting any) , then it stops working, i'm assuming that they are fighting over the same pins.
It especially happens when i add enableIRIn(); because i've been through the code uncommenting all the IR code one thing at a time to see when it all breaks, any idea how i can get around this ? is it just a simple reassignment of pins in one of the libraries or am i going to be forced to run one chip for the leds and another for the rest of the circuit once it comes down to PCB production time ?
My guess is that they are fighting over the same timer.
You need to rewrite one of the libraries.
Or use another chip for controlling the LEDs like the PCA9685
Thanks for the info , will take a look into the other chips , and run off the libraries to see which option is easiest, rewrite or a different chip
