TMP36 sensor reading goes down when temp goes up
Hello,
I'm traing to set up a temperature controlled fan. Got it from a video.
Link to video:
So I put everything together and now have a few problems.
The base temperature is around -2,6°C (27.27°F) and I dont know why or how to change it.
Also the reading goes down when I apply heat.
I'm pretty sure I got everything connected as instructed but I just don't know what to do about the problems. I'm not a programmer. To be honest, I can kinda read the code but couldn't write one myself.
Code:
//CONFIG =====================================================================================
#define aref_voltage 3.3         // we tie 3.3V to ARef and measure it with a multimeter!
//TMP36 Pin Variables
int tempPin = 0;        // TMP36 Center lead to Analog Pin [A1-A7] (Elegoo Nano v.3)
int tempReading;        // the analog reading from the sensor
//Relay Pin Variable
int relayPin = 2;       // Relay Singnal lead to Digital Pin [D2-D12] (Elegoo Nano v.3)
//Tempurature Range
// Its good to provide a buffer for efficiency, if the temp bounces from 79-81 constantly
// it will turn on and off the fan constantly. So set a minimum temperature that the fan
// can cool the are too before it starts checking for max temperature.
float maxTemperature = 40.00; // The Max Temperature allowed
float minTemperature = 35.00; // The Min Temperature allowed
  // We'll send debugging information via the Serial monitor
  // If you want to set the aref to something other than 5v
  analogReference(EXTERNAL); // Feed the 3.3v cable back into the AREF pin
  // Pin Setup/Register
  pinMode(relayPin, OUTPUT);
  float temperature = getTemperature();
  if (temperature >= maxTemperature) {
    powerOnRelay();
  } else if (temperature <= minTemperature) {
    powerOffRelay();
  delay(1000); // Check tempertature every second
void powerOnRelay() {
  digitalWrite(relayPin, HIGH);
  Serial.println("Relay On");
void powerOffRelay() {
  digitalWrite(relayPin, LOW);
  Serial.println("Relay Off");
float getTemperature() {
  tempReading = analogRead(tempPin);
  float voltage = tempReading * aref_voltage;
  voltage /= 1024.0;
  // now print out the temperature
  float temperatureC = (voltage - 0.5) * 100 ;  //converting from 10 mv per degree wit 500 mV offset to degrees ((volatge - 500mV) times 100)
  Serial.print(temperatureC); Serial.println(" degrees C"); // For debuging purpouses
  // now convert to Fahrenheight
  float temperatureF = (temperatureC * 9.0 / 5.0) + 32.0;
  // Serial.print(temperatureF); Serial.println(" degrees F");
  // Choose which tempurature you would like to use.
  //return temperatureF; //Fahrenheight
  return temperatureC; // Celcius
Can anyone help?
Get rid of the REF voltage stuff, you dont need it. That is whats messing your program up. Here is the altered code i did for you. I have tested this on an Arduino Uno and it works.
Make sure your Temp Sensor is connected correctly. Power pin to 5v, ground to ground and middle pin to A0.
int tempPin = A0;        // TMP36 Center lead to Analog Pin [A1-A7] (Elegoo Nano v.3)        // the analog reading from the sensor
//Tempurature Range
  //analogReference(EXTERNAL); // Feed the 3.3v cable back into the AREF pin
    powerOnRelay();
    powerOffRelay();
  int tempReading = analogRead(tempPin);
  float voltage = tempReading * 5.0;
  voltage /= 1024.0;
  float temperatureC = (voltage -.5) * 100;  //converting from 10 mv per degree wit 500 mV offset to degrees ((volatge - 500mV) times 100)
  //float temperatureF = (temperatureC * 9.0 / 5.0) + 32.0;
Thats so nice of you. I tried it. Disconnected the relay and reconnected the temp sensor on 5V, GRD and A1. The Offset went from -2.6 to +3.71°C (probably because of the change from 3.3 to 5 V). And when I heat up the sensor, the numbers go down still. Must be hardware a this point. Will try another TMP36 and see what happens.
Yes, you must have something connected incorrectly. When i get home tonight ill set up my uno again and test everything. When i simulate it on tinkercad everything works correctly.
