TMRpcm & ISR(TIMER1_CAPT_vect)
Saludos comunidad... Estoy luchando y no encuentro solución. La idea es unir la lectura de un SMPTE timecode y hacer play de algunos archivos en una SDCard
Al tratar de leer / escribir un vector que almacena el codigo de tiempo, el audio no se reproduce mas.
Aquí, parte del código compilado para Arduino UNO...
#define icpPin                8   // ICP input pin on arduino
#define one_time_max          600  // 600 these values are setup for NTSC video
#define one_time_min          300  // 400 PAL would be around 1000 for 0 and 500 for 1
#define zero_time_max         1200 // 1050 80 bits times 29.97 frames per sec
#define zero_time_min         700  // 950 equals 833 (divide by 8 clock pulses)
#define end_data_position      63
#define end_sync_position      77
#define end_smpte_position     80
#include <SD.h>               // need to include the SD library
#define SD_ChipSelectPin 10   //using digital pin 4 on arduino nano 328
#include <TMRpcm.h>           //  also need to include this library...
#include <SPI.h>
#include <SoftwareSerial.h>
#define CLR(x, y) (x &= (~(1<<y)))
#define SET(x, y) (x |= (1<<y))
#define d0 2
#define d1 9//3 // 3 es pata 5 - 9 que es pata 15
#define d2 4
#define in A0
#define inh1 A1
#define inh2 A2
#define inh3 A3
#define inh4 A4
#define Tx 7
#define Rx A5//8
volatile char timeCode[11];
volatile unsigned int bit_time;
volatile unsigned int bit_time_min = 1000;
volatile unsigned int bit_time_max = 0;
volatile boolean valid_tc_word;
volatile boolean ones_bit_count;
volatile boolean tc_sync;
volatile boolean write_tc_out;
volatile boolean drop_frame_flag;
volatile byte total_bits;
volatile byte current_bit;
volatile byte sync_count;
SoftwareSerial serie(Rx, Tx);
TMRpcm tmrpcm;
int  lastInput;
byte lastD0 = 0, lastD1 = 0;
  pinMode(icpPin, INPUT);                  // ICP pin (digital pin 8 on arduino) as input
  bit_time = 0;
  valid_tc_word = false;
  ones_bit_count = false;
  tc_sync = false;
  write_tc_out = false;
  drop_frame_flag = false;
  total_bits =  0;
  current_bit =  0;
  sync_count =  0;
  delay (200);
  TCCR1A = B00000000; // clear all
  TCCR1B = B11000010; // ICNC1 noise reduction + ICES1 start on rising edge + CS11 divide by 8
  TCCR1C = B00000000; // clear all
  TIMSK1 = B00100000; // ICIE1 enable the icp
  TCNT1 = 0; // clear timer1
  pinMode(d0, OUTPUT);
  pinMode(d1, OUTPUT);
  pinMode(d2, OUTPUT);
  pinMode(in, INPUT);
  pinMode(inh1, OUTPUT);
  pinMode(inh2, OUTPUT);
  pinMode(inh3, OUTPUT);
  pinMode(inh4, OUTPUT);
  tmrpcm.speakerPin = 3;
  serie.begin(115200);
  Serial.println("Finished setup... ");
  if (!SD.begin(SD_ChipSelectPin))
    Serial.println("SD fail");
  tmrpcm.play("UnoF.wav");
  tmrpcm.play("DosM.wav");
  tmrpcm.play("DosF.wav");
  if (write_tc_out)
    if (drop_frame_flag) Serial.print("TC DROP FRAME");
    if (!drop_frame_flag) Serial.print("TC NO DROP FRAME");
    Serial.print((char*)timeCode);
    Serial.print("\r\n");
    Serial.println("......");
    delay (40);
  if (lastInput != readInput())
    unsigned long inicio = millis();
      cli();sei();
    switch(readInput())
      case 1:
        lastInput = 1;
        player(1);
        serie.write(lastInput);
      case 2:
        lastInput = 2;
        player(2);
  if(serie.available()>0)
    byte dato[3];
    serie.readBytes(dato, 3);
    if(dato[0]<32 && dato[1]<32 && dato[2]<32)
      if(lastD0 != dato[0])
        lastD0 = dato[0];
        player(dato[0]);
      if(lastD1 != dato[1])
        lastD1 = dato[1];
        player(dato[1]+16);
int readInput()
  CLR(PORTC, 1) ;
  SET(PORTC, 2) ;
  SET(PORTC, 3) ;
  SET(PORTC, 4) ;
  switch (switchIn())
    case 1: return 1; break;
    case 2: return 2; break;
    case 3: return 3; break;
    case 4: return 4; break;
int switchIn()
  CLR(PORTD, 2) ;
  CLR(PORTB, 1);//CLR(PORTD, 3) ;// Cambia por B1
  CLR(PORTD, 4) ;
  delay(1);
  if (digitalRead(in))  return 1;
  SET(PORTD, 2) ;
  CLR(PORTD, 4) ;
  delay(1);
void player(byte num)
  switch (num)
    case 1:
      tmrpcm.play("UnoM.wav");
      delay(10);
    case 2:
      delay(10);
  byte tc[8];
  int lastTime = 0;
  int time = micros();
  TCCR1B ^= _BV(ICES1);
  bit_time = ICR1;
  TCNT1 = 0;  //resetTimer1
  if(bit_time < bit_time_min && bit_time > one_time_min) bit_time_min = bit_time;
  if(bit_time > bit_time_max && bit_time < zero_time_max) bit_time_max = bit_time;
  if ((bit_time < one_time_min) || (bit_time > zero_time_max)) //
    total_bits = 0;
    if (ones_bit_count == true) ones_bit_count = false;
      if (bit_time > zero_time_min)
        current_bit = 0;
        sync_count = 0;
      else //if (bit_time < one_time_max)
        ones_bit_count = true;
        current_bit = 1;
        sync_count++;
        if (sync_count == 12)
          sync_count = 0;
          tc_sync = true;
          total_bits = end_sync_position;
      if (total_bits <= end_data_position) // timecode runs least to most so we need
      {                                    // to shift things around
        tc[0] = tc[0] >> 1;
        for(int n=1; n<8; n++)
          if(tc[n] & 1) tc[n-1] |= 0x80;
          tc[n] = tc[n] >> 1;
        if(current_bit == 1)tc[7] |= 0x80;
      total_bits++;
    if (total_bits == end_smpte_position)
      total_bits = 0;
      if (tc_sync)
        tc_sync = false;
        valid_tc_word = true;
        lastTime = time;
    if (valid_tc_word)
      timeCode[10] = (tc[0]&0x0F)+0x30;
      timeCode[9]  = (tc[1]&0x03)+0x30;
      timeCode[8]  =  ':';
      timeCode[7]  = (tc[2]&0x0F)+0x30;
      timeCode[6]  = (tc[3]&0x07)+0x30;
      timeCode[5]  =  ':';
      timeCode[4]  = (tc[4]&0x0F)+0x30;
      timeCode[3]  = (tc[5]&0x07)+0x30;
      timeCode[2]  = ':';
      timeCode[1]  = (tc[6]&0x0F)+0x30;
      timeCode[0]  = (tc[7]&0x03)+0x30;
      if(tc[1]&0x04) drop_frame_flag = true;
      else drop_frame_flag = false;
      write_tc_out = true;
Este es el código ... cuando hago algo con el array timeCode[XX] el sonido desaparece ...
Estoy perdido ... ¿Podrían darme una mano ???
Lee las Normas del foro.
Luego ve a More (abajo a la derecha), click, luego Modify y estas en modo EDICION.
Selecciona todo el código y click en </> arriba del emoticon
Cuando el código se lea debidamente te respondo.
ariel_ba:
Lo mismo digo yo.
Primero: si es un código de ejemplo, de dónde lo sacaste?
Segundo: ni me compila por lo siguiente:
    cli(); sei(); // WTF???
      case 1:
          lastInput = 1;
          player(1);
      case 2:
          lastInput = 2;
          player(2);
Esto debería sea una sentencia switch, pero... se compara qué con qué?
Cuatro razones por las cuales la reproducción con TMRpcm parece detenerse:
  • Intentar reproducir un archivo mientras se está reproduciendo otro.
  • Intentar acceder a un archivo de la tarjeta SD, mientras algo se está reproduciendo.
  • Intentar utilizar speakerPin para otros propósitos, sin haber llamado a disable anteriormente.
  • Alguna interrupción que tarde más que el periodo de la frecuencia de muestreo a la que se reproduce el archivo; aunque en teoría continúa una vez la interrupción acabe.
Todo gira en torno a esta librería de TMRh20 TMRpcm
Acá hay un código bastante similar con explicaciones.
