TOF400F sensor help
Greetings,
I purchased a TOF400F distance sensor from Ali express. I had to speak with them to get documentation and example code which I have now managed to get running but it is not very accurate and give constant errors. I have emailed the supplier and await their response but I thought someone here may have had some experience and could give me some advice.
The serial output shows the distance +/- 5mm when fixed a constant distance from a solid surface this is not accurate but even worse randomly every 10-20 readings the sensor reports a distance 10 digits long and a distance in the millions of meters is clearly wrong.. I will add a serial monitor output shortly....
Here is the code 100% as is from the supplier:
Connection:    UNO         TOFxxxH
             5V/3.3V   ---  VIN
               GND     ---  GND
                2      ---  RXD
                3      ---  TXD
#include <MsTimer2.h>
#include <SoftwareSerial.h>
#include <Wire.h>
SoftwareSerial DT(3, 2); //TX--3  RX--2
/**********************************type类型定义**************************/
typedef signed char     int8;
typedef unsigned char   uint8;
typedef signed short    int16;
typedef unsigned short    uint16;
typedef signed long     int32;
typedef unsigned long   uint32;
typedef unsigned long long  uint64;
typedef signed long long  int64;
/**********************************time定时配置**************************/
uint32 timCount = 0;
void tim_isr(void)
  timCount++;
  timCount++;
uint32 tim_get_count(void)
  uint32 count;;
  do{
    count = timCount;
  }while(count != timCount);
  return count;
uint8 tim_check_timeout(uint32 start, uint32 now, uint32 invt)
  if((uint32)(start + invt) >= start)//未溢出
    if((now >= (uint32)(start + invt)) || (now < start))
      return 1;
  else//溢出
    if((now < start) && (now >= (uint32)(start + invt)))
      return 1;
  return 0;
/**********************************modbus set 配置**************************/
//modbus接收到正确数据帧回调函数
void modbus_recv_data(uint8 *p_data, uint16 len)
/*读命令响应
  deviceAddr = p_data[0];//响应的设备地址
  cmd = p_data[1];      //响应的命令,读03
  byteNum = p_data[2];  //返回读数据长
  readData = p_data[3]; //读回数据H
  readData <<= 8;
  readData |= p_data[4];//读回数据H
/*写命令响应
  cmd = p_data[1];      //响应的命令,写06
  regAddr = p_data[2];  //寄存器地址H
  regAddr <<= 8;
  regAddr |= p_data[3]; //寄存器地址L
  writeData = p_data[4];//写数据H
  writeData <<= 8;
  writeData |= p_data[5];//写数据L
  //Serial.write(p_data, len);
uint8 rxRdIndex = 0;
uint8 rxWrIndex = 0;
uint32 lastRxTimestamp = 0;
uint8 framTimeInvt = 4;
#define RX_BUF_LEN  80
#define TX_BUF_LEN  80
uint8 a_rxBuff[RX_BUF_LEN];
uint8 a_tempBuff[RX_BUF_LEN];
uint8 a_txBuff[TX_BUF_LEN];
static const uint8 a_crc16mTableHi[] = {
  0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81,
  0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0,
  0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01,
  0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41,
  0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81,
  0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0,
  0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01,
  0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
  0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0,
  0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
  0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81,
  0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0,
  0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
  0x40
static const uint8 a_crc16mTableLo[] = {
  0x00, 0xC0, 0xC1, 0x01, 0xC3, 0x03, 0x02, 0xC2, 0xC6, 0x06, 0x07, 0xC7, 0x05, 0xC5, 0xC4,
  0x04, 0xCC, 0x0C, 0x0D, 0xCD, 0x0F, 0xCF, 0xCE, 0x0E, 0x0A, 0xCA, 0xCB, 0x0B, 0xC9, 0x09,
  0x08, 0xC8, 0xD8, 0x18, 0x19, 0xD9, 0x1B, 0xDB, 0xDA, 0x1A, 0x1E, 0xDE, 0xDF, 0x1F, 0xDD,
  0x1D, 0x1C, 0xDC, 0x14, 0xD4, 0xD5, 0x15, 0xD7, 0x17, 0x16, 0xD6, 0xD2, 0x12, 0x13, 0xD3,
  0x11, 0xD1, 0xD0, 0x10, 0xF0, 0x30, 0x31, 0xF1, 0x33, 0xF3, 0xF2, 0x32, 0x36, 0xF6, 0xF7,
  0x37, 0xF5, 0x35, 0x34, 0xF4, 0x3C, 0xFC, 0xFD, 0x3D, 0xFF, 0x3F, 0x3E, 0xFE, 0xFA, 0x3A,
  0x3B, 0xFB, 0x39, 0xF9, 0xF8, 0x38, 0x28, 0xE8, 0xE9, 0x29, 0xEB, 0x2B, 0x2A, 0xEA, 0xEE,
  0x2E, 0x2F, 0xEF, 0x2D, 0xED, 0xEC, 0x2C, 0xE4, 0x24, 0x25, 0xE5, 0x27, 0xE7, 0xE6, 0x26,
  0x22, 0xE2, 0xE3, 0x23, 0xE1, 0x21, 0x20, 0xE0, 0xA0, 0x60, 0x61, 0xA1, 0x63, 0xA3, 0xA2,
  0x62, 0x66, 0xA6, 0xA7, 0x67, 0xA5, 0x65, 0x64, 0xA4, 0x6C, 0xAC, 0xAD, 0x6D, 0xAF, 0x6F,
  0x6E, 0xAE, 0xAA, 0x6A, 0x6B, 0xAB, 0x69, 0xA9, 0xA8, 0x68, 0x78, 0xB8, 0xB9, 0x79, 0xBB,
  0x7B, 0x7A, 0xBA, 0xBE, 0x7E, 0x7F, 0xBF, 0x7D, 0xBD, 0xBC, 0x7C, 0xB4, 0x74, 0x75, 0xB5,
  0x77, 0xB7, 0xB6, 0x76, 0x72, 0xB2, 0xB3, 0x73, 0xB1, 0x71, 0x70, 0xB0, 0x50, 0x90, 0x91,
  0x51, 0x93, 0x53, 0x52, 0x92, 0x96, 0x56, 0x57, 0x97, 0x55, 0x95, 0x94, 0x54, 0x9C, 0x5C,
  0x5D, 0x9D, 0x5F, 0x9F, 0x9E, 0x5E, 0x5A, 0x9A, 0x9B, 0x5B, 0x99, 0x59, 0x58, 0x98, 0x88,
  0x48, 0x49, 0x89, 0x4B, 0x8B, 0x8A, 0x4A, 0x4E, 0x8E, 0x8F, 0x4F, 0x8D, 0x4D, 0x4C, 0x8C,
  0x44, 0x84, 0x85, 0x45, 0x87, 0x47, 0x46, 0x86, 0x82, 0x42, 0x43, 0x83, 0x41, 0x81, 0x80,
  0x40
uint16 crc16_calculate_modbus(uint8 *p_data, uint16 len)
  uint8 crchi = 0xff;
  uint8 crclo = 0xff;
  uint16 index;
  while (len--)
    index = crclo ^ *p_data++;
    crclo = crchi ^ a_crc16mTableHi[index];
    crchi = a_crc16mTableLo[index];
  return (crchi << 8 | crclo);
uint16 uart_read_isr(uint8 channel, uint8 *p_buff)
  uint16 i = 0, wrIndex = 0;
  for(wrIndex=rxWrIndex; wrIndex!=rxRdIndex; rxRdIndex=(rxRdIndex+1)%RX_BUF_LEN,i++)
    p_buff[i] = a_rxBuff[rxRdIndex];
  return i;
uint8 uart_tpm_rx_isr(uint8 channel, uint8 data)
  if(rxRdIndex == ((rxWrIndex + 1) % RX_BUF_LEN))
    return 1;
    a_rxBuff[rxWrIndex] = data;
    rxWrIndex = (rxWrIndex+1)%RX_BUF_LEN;
  lastRxTimestamp = tim_get_count();
  return 0;
void uart_tpm_main(void)
  uint16 rxLen = 0;
  uint16 crc16 = 0;
  if(tim_check_timeout(lastRxTimestamp, tim_get_count(), framTimeInvt))
    rxLen = uart_read_isr(0, a_tempBuff);
    if(rxLen > 2)
      crc16 = a_tempBuff[rxLen-1];
      crc16 <<= 8;
      crc16 |= a_tempBuff[rxLen-2];
      if(crc16 == crc16_calculate_modbus(a_tempBuff, rxLen-2))
          modbus_recv_data(a_tempBuff, rxLen-2);
uint8 uart_tpm_tx_data(uint8 channel, uint8 *p_data, uint16 len)
  uint16 crc16 = 0;
  if(NULL == p_data || 0 == len ||
    len + 2 > TX_BUF_LEN)
    return 1;
  memcpy(a_txBuff, p_data, len);
  crc16 = crc16_calculate_modbus(a_txBuff, len);
  a_txBuff[len] = crc16;    //crc16l
  a_txBuff[len+1] = crc16>>8;   //crc16h
  //Serial.write(a_txBuff, len+2);
  DT.write(a_txBuff, len+2);
  return 1;
/**********************************test set 测试配置**************************/
//led测试
void led_flash_main(void)
  static uint32 ledCount = 0;
  if(tim_check_timeout(ledCount, tim_get_count(), 50))
    digitalWrite(13, !digitalRead(13));
    ledCount = tim_get_count();
uint8 a_testBuff[20];
//读测量距离命令***********************read distance reg****************************************************************
#define REG_RD_ADDR  0x0010//测量结果寄存器
void read_cmd_test_main(void)
  static uint32 timStamp = 0;
  if(tim_check_timeout(timStamp, tim_get_count(), 500))//500ms发送一次读命令,改变尺寸可以定义多久读一次从机的测距值
    a_testBuff[0] = 0;//广播地址
    a_testBuff[1] = 3;//读命令码
    a_testBuff[2] = REG_RD_ADDR>>8;//regH
    a_testBuff[3] = REG_RD_ADDR;//regL
    a_testBuff[4] = 0;//numH 仅支持读单个寄存器
    a_testBuff[5] = 1;//numL
    uart_tpm_tx_data(0, a_testBuff, 6);
    timStamp = tim_get_count();
//写设置模块的寄存器********************************write reg*********************************************************************
#define REG_WR_ADDR  0x0005//连续输出控制寄存器
#define REG_WR_DATA  500//写入数据,0表示不连续输出,xx表示间隔xxmS从机自动输出测距值
void write_cmd_test_main(void)
  static uint8 flag = 1;
  if(tim_check_timeout(timStamp, tim_get_count(), 500))//500ms后只发送一次写命令
    if(flag)//只发送一次命令
      flag = 0;
      a_testBuff[1] = 6;//写命令码
      a_testBuff[2] = REG_WR_ADDR>>8;//regH
      a_testBuff[3] = REG_WR_ADDR;//regL
      a_testBuff[4] = REG_WR_DATA>>8;//dataH
      a_testBuff[5] = REG_WR_DATA;//dataL
//测试loop,测试写功能或者读功能**************************test loop******************************************************************
void cmd_test_main(void)
  //write_cmd_test_main();//发送写命令,设置测距模块是否连续输出以及连续输出的时间间隔
  read_cmd_test_main();//发送读命令,读模块的测距值
  pinMode(13, OUTPUT);
  DT.begin(115200);
  MsTimer2::set(2 ,tim_isr);
  MsTimer2::start();
  uart_tpm_main();
  led_flash_main();
  cmd_test_main();
  if (DT.available() > 6)
    char a = DT.read();
    if(a != 0x01)          //测距模块的首地址,若改变首地址这里要改对.默认01
      return;
    byte Buf[6];
    DT.readBytes(Buf, 6);
 /*   for (int i = 0; i < 6; i++)
      if (Buf[i] < 0x10)
        Serial.print("0x0");
        Serial.print("0x");
      Serial.print(Buf[i], HEX);
      Serial.print(" ");
    if (Buf[2] == 0xFF)
      Serial.print("Distance:");
      Serial.print("invalid");
    long distance = Buf[2] * 256 + Buf[3];
    Serial.print(distance);
    Serial.print("mm");
void serialEvent()
  //uart_tpm_rx_isr(0, (uint8)Serial.read());
  uart_tpm_rx_isr(0, (uint8)DT.read());
attach the datasheet to a posting.
I recommend buying these sensors
precision has its price
best regards Stefan
Have you tried changing the code to Ignore results out of device spec and those that makes no sense, and, taking several measurements and averaging the results?
I am not familiar with this specific device but I do tend to do such steps on devices I use where the library is not doing it or where the quality is poor.
T
TOF400H DATASHEET_20201027.pdf (2.3 MB)
hanks but I I prefer to try and use the sensor I have first as it is environmentally sealed. of course if it is useless then the environment doesn't matter and I will need to change the sensor for a more common one like you suggest.
thanks, I have not implemented this yet but it has crossed my mind to do it. I didn't want to hack the code before asking some questions because it seems to be the inefficient way to solve the problem.
Here is an example of the serial output when i have an object fixed at about 80mm:
18:40:49.994 -> Distance:81mm
18:40:50.028 -> Distance:82mm
18:40:50.132 -> Distance:82mm
18:40:50.235 -> Distance:81mm
18:40:50.337 -> Distance:82mm
18:40:50.438 -> Distance:83mm
18:40:50.541 -> Distance:21496mm
18:40:50.644 -> Distance:81mm
18:40:50.747 -> Distance:82mm
18:40:50.850 -> Distance:82mm
18:40:50.988 -> Distance:42mm
18:40:51.092 -> Distance:4294934611mm
18:40:51.161 -> Distance:82mm
18:40:51.371 -> Distance:83mm
18:40:51.510 -> Distance:85mm
18:40:51.580 -> Distance:21880mm
18:40:51.685 -> Distance:85mm
18:40:51.926 -> Distance:21496mm
18:40:51.996 -> Distance:81mm
18:40:52.136 -> Distance:21880mm
18:40:52.206 -> Distance:83mm
18:40:52.310 -> Distance:85mm
18:40:52.449 -> Distance:83mm
18:40:52.519 -> Distance:83mm
18:40:52.519 -> Distance:85mm
18:40:52.624 -> Distance:83mm
18:40:52.763 -> Distance:84mm
18:40:52.972 -> Distance:42mm
18:40:53.006 -> Distance:87mm
18:40:53.146 -> Distance:22521mm
18:40:53.285 -> Distance:87mm
18:40:53.388 -> Distance:87mm
18:40:53.458 -> Distance:172mm
18:40:53.528 -> Distance:88mm
18:40:53.598 -> Distance:89mm
18:40:53.771 -> Distance:22072mm
it seems that software-serial does not work reliable on 115200 baud.
The demo-code has CRC-checksum does the code really use the CRC-checksum?
if the received data is not valid the CRC-Sum-check should show this.
The datasheet says that there is a command to change the baudrate.
or you switch over to I2C-communication
there is a I2C-library for the VL53L1-Chip (which is the ToF-Chip of the TOF400F-module
GitHub - pololu/vl53l1x-arduino: Pololu Arduino library for VL53L1X time-of-flight distance sensor
best regards Stefan
I tried to connect TOF400F via I2C but had no success. Even the I2C scanner can't find it.
I have checked the documentation of VL53L1X about I2C. But that was pretty sobering.
Do I really have to use Modbus running on 115200Baud to switch over to I2C mode?
My idea was to use an UNO as interface between a TOF400F and a modbus master system using RS485. The distance between the TOF400F and the master is about 30m. The UNO runs the serial comm via softwareserial with 9600Baud and that works perfect. But i don't know, if a second serial connection with 115200Baud using softwareserial would work. I didn't wanted to use the default serial connection as I'm using it for debug purposes.
Is there anyone who has experience with I2C with TOF400F?
Regards Dieter
How about spending 7€ and using a seeeduino XIAO which has a second hardware serial interface and with 48 MHz CPU-frequency is surely able to even use another software-serial at 115200 baud.
The seeeduino XIAO is programmable with the Arduino-IDE after installating the XIAO-board
If you want to keep the Arduino another way could be to the XIAO as a baud--reducing adapter from 1152000 baud to 9600 baud
best regards Stefan
Thanks, just ordered 2 of them for a test. Never heard of that board before, but seems to be pretty interesting.
Just for clarification, during startup I have to send a modbus command (write single register as documented in the specs) to switch TOF400F to I2C!?
Regards Dieter
modbus is a communication-protocol independent from the used hardware-interface to transmit the data the hardware-interfaces could be RS232, RS422, or in most cases RS485.
best regards Stefan
the compiler tells me, that SoftwareSerial only supports 20, 16 and 8Mhz CPUs. Any idea how i could change that for seeeduino xiao? The plan was to realize your proposal to use the xiao as baudrate reducer.
Regards Dieter
The Seeeduino-XIOA requires to install an additional board-defintion to the Arduino-IDE which is described here
After doing these steps
the first thing you have to do is adjust the board in the Arduino-IDE to Seeeduino XIAO.
For each microcontroller-type a different "core" is adjusted. As the user you choose the board and the IDE is doing all these detail adjustments.
The additional board-definition provides a modified version of SoftwareSerial that works with the Seeeduino-XIAO
This changes even which examples will appear.
Then go to file - examples - softwareSerial
There is an example two port receiving
best regards Stefan
I've buy one of this modules (TOF200F), looks like an internal MCU (probably an ST) connected to a VL53L0 (accordly their confused and almost useless datasheet) but can be an VL53L1. Serial connection is a nightmare, at any speed the device returns unreliable data from time to time. Connecting I2C is also a nightmare. The I2C scan shows at list 20 different devices randomly! After an accurate read of their stupid datasheet I discover that there's a command that disconnect the internal MCU from the sensor and must be sent ONLY by serial, not sure by MODBUS or by terminal, I suppose the last one. Command is : 01 06 00 09 00 01 98 08. Accordly datasheet this need a restart. I'm not sure if this parameter is maintained (I hope so!), I will do some experiment but my first attempt to connect module to a terminal caused buffer overflows since it sends tons of unreadable data trough serial and never stop.
I've managed how to enable I2C!
First, these cinese Datashit are wrong or almost useless.... This module has an 3v3 LDO onboard, connecting at 3.3v drive into problems (instability and parassite readouts). I have to connect at 5V, after that serial stops putting parasite data (but still able to send and receive at 3v3 digital signals). I have used the application TOF Ranging V2.1.1 and connected the module to a cheap USB->serial pen at 3v3 to access internal parameters (included in the their doc stuff).
Once inside, click settings tab and put 1 in Ban IIC (normally is 0 that means disabled).
Then I connect to my MCU (I'm actually using an ESP32), started I2C scan and BAM, I finally see just one address! With TOF Ranging V2.1.1 I've also managed to change the address as I want (Ive set 0x29). The top of the image shows 0x1, I've changed to 0x29.The baudrate at 0 means 115200 (0 means default accordly these weird people), the other data is something obscure, try reading datashit but I forget it, anyway driving by I2C means disconnect inside MCU so these parameters are useless.. I hope this will help to save hours of useless testings to someone. Tomorror I'll tell you my testing on the library that currently works with this damn device. This informations works with TOF50F,TOF200F,TOF400F. If someone need the application I can post somewhere...
Getting succesfully readings in I2C.
As I mentioned before inside this module there's a VL53L0X and NOT a VL53L1. I have used Adafruit_VL53L0X library and get reliable readings without the absurde mess of the cinese serial test program, at this point I have the feeling that this product is a fail since the internal MCU is almost unusable that is connected and suck current.
UPDATE
:thinking: After some days, bad news... Chip loosed settings and disabled I2C by itself, this created mulfunctions with other I2C chips in my prototype. This TOF series are totally useless except you want use with Serial (at the cost of dedicate a serial for it and get data not always reliable). Better buy a VL53L0X, cost less and works much better. Mine is already in the trash!
Greetings,
I scrapped the rubbish TOF sensors that I initially purchased and got some TOF400C modules that use the VL53L1X chip and the Adafruit library works perfectly with no complications.
Here is the link to the modules that I got:
here is the code that I have to light a string of WS2812B LEDS according to the distance measured by the sensor.
#include "Adafruit_VL53L0X.h"
#include <FastLED.h>
Adafruit_VL53L0X lox = Adafruit_VL53L0X();
//FASTLED
#define LEDstripPinTOP 2                          // WS2812 LED strip connected to PIN
#define LEDstripPinLHS 4                          // WS2812 LED strip connected to PIN
#define LEDstripPinRHS 5                          // WS2812 LED strip connected to PIN
#define LED_VOLTS 5                            // Usually 5 or 12
#define MAX_MILLIAMPS 3000                     // Careful with the amount of power here if running off USB port. My Power supply is 6A so keep under that.
#define COLOR_ORDER    GRB                     // LED colour order
#define CHIPSET        WS2812B                 // LED type
// BUTTON INPUTS
#define ModeButtonPin 19
#define SENSOR_INPUT_PIN 13
const uint16_t NUM_LEDS_TOP = 70;                 // number of WS2812 LEDs on the strip. An operation involving an unsigned larger than a byte will get promoted to unsigned calculation if the size is large enough (16 bits will do)
const uint16_t NUM_LEDS_LHS = 57;
const uint16_t NUM_LEDS_RHS = 57;
int FadeOutRate = 240;
int distance = 0;
int distance_offset = 0;
int actual_distance = 0;
int max_distance = 400;
int LEDS_To_Light_LHS = 0;
int LEDS_To_Light_RHS = 0;
int LEDS_To_Light_TOP = 0;
int SensorValue = 0;
int Mode = 1;
CRGB LedStripTOP[NUM_LEDS_TOP];
CRGB LedStripLHS[NUM_LEDS_LHS];
CRGB LedStripRHS[NUM_LEDS_RHS];
  //pinMode(SENSOR_INPUT_PIN, INPUT);
  pinMode(LEDstripPinTOP, OUTPUT);
  pinMode(LEDstripPinLHS, OUTPUT);
  pinMode(LEDstripPinRHS, OUTPUT);
  pinMode(ModeButtonPin, INPUT_PULLUP);
  FastLED.addLeds<WS2812B, LEDstripPinTOP , GRB>(LedStripTOP, NUM_LEDS_TOP);
  FastLED.addLeds<WS2812B, LEDstripPinLHS , GRB>(LedStripLHS, NUM_LEDS_LHS);
  FastLED.addLeds<WS2812B, LEDstripPinRHS , GRB>(LedStripRHS, NUM_LEDS_RHS);
  FastLED.setMaxPowerInVoltsAndMilliamps(LED_VOLTS, MAX_MILLIAMPS);
  FastLED.setBrightness(255);
  attachInterrupt(digitalPinToInterrupt(ModeButtonPin), ChangeMode, FALLING);
  // wait until serial port opens for native USB devices
  while (! Serial) {
    delay(1);
  Serial.println("Adafruit VL53L0X test");
  if (!lox.begin()) {
    Serial.println(F("Failed to boot VL53L0X"));
    while(1);
  // power
  Serial.println(F("VL53L0X API Simple Ranging example\n\n"));
  VL53L0X_RangingMeasurementData_t measure;
  Serial.print("Reading a measurement... ");
  lox.rangingTest(&measure, false); // pass in 'true' to get debug data printout!
  if (measure.RangeStatus != 4) {  // phase failures have incorrect data
    distance = measure.RangeMilliMeter;
    Serial.print("Distance (mm): ");
    Serial.println(distance);
    Serial.println(" out of range ");
    distance = max_distance;
  CalculateOffset();
  MapSensorToLeds();
  LightSideLeds();
  LightTopLeds();
  ReadSensor() ;
  //delay(100);
void CalculateOffset(){
  actual_distance = distance - distance_offset;
  Serial.print("Actual Distance (mm): ");
  Serial.println(actual_distance);
void MapSensorToLeds(){
  LEDS_To_Light_LHS = map(actual_distance,0,max_distance,0,NUM_LEDS_LHS);
  LEDS_To_Light_RHS = map(actual_distance,0,max_distance,0,NUM_LEDS_RHS);
  Serial.print("Lights = ");
  Serial.println(LEDS_To_Light_LHS);
void LightSideLeds(){
  for (int i = 0; i <= LEDS_To_Light_LHS - 1; i++) {
    LedStripLHS[i] = CRGB::White;
    LedStripRHS[i] = CRGB::White;
    FastLED.show();
    for (int i = LEDS_To_Light_LHS; i <= NUM_LEDS_LHS - 1; i++) {
    LedStripLHS[i] = CRGB::Red;
    LedStripRHS[i] = CRGB::Red;
    //fadeToBlackBy( LedStripLHS, i, 100);
    //LedStripLHS[i].fadeToBlackBy(FadeOutRate);
    //LedStripRHS[i].fadeToBlackBy(FadeOutRate);
    FastLED.show();
void LightTopLeds(){
  for (int i = 0; i <= NUM_LEDS_TOP - 1; i++) {
    LedStripTOP[i] = CRGB::White;
    FastLED.show();
void ReadSensor(){
SensorValue = analogRead(SENSOR_INPUT_PIN);
Serial.print("Sensor Value = ");
Serial.println(SensorValue);
distance_offset = map(SensorValue,0,4095,0,255);
Serial.print("Mapped_Sensor Value = ");
Serial.println(distance_offset);
void ChangeMode(){
  Mode++ ;                                                          // incriment mode
  if (Mode > 10){
    Mode = 1;
  Serial.println("mode changed = ");
  Serial.println(Mode);
Hello sumotoxic,
I have the same problem with the TOF.
Where can I find the "TOF Ranging V2.1.1" application to configure it ?
Thanks, Ramiop.
This a link to download the RAR folder I got from the manufacturer when I ordered my TOF400F sensor. here you will get all the files for raspberry pi, arduino, esp32 etc and data sheets.
The link is still valid and the download still works as of today. They said I need a password but its not required as far as I can see.
Password: 678315
I gave up on this completely because the code examples for Arduino are erroneous and processor intensive and the replacement VL53L1X modules I got work flawlessly with the Adafruit library.
Thanks a lot, hope this helps set up the units I have.
I need it to work properly, I have more than 20 units ...
