@blh64, does this teckel12 / Arduino New Tone / wiki / Home — Bitbucket works with microbit board? I have encountered error as follows:
/Users/terencebeh/Documents/Arduino/libraries/NewTone/NewTone.cpp: In function 'void NewTone(uint8_t, long unsigned int, long unsigned int)':
/Users/terencebeh/Documents/Arduino/libraries/NewTone/NewTone.cpp:15:27: error: 'CS10' was not declared in this scope
uint8_t prescaler = _BV(CS10); // Try using prescaler 1 first.
/Users/terencebeh/Documents/Arduino/libraries/NewTone/NewTone.cpp:15:31: error: '_BV' was not declared in this scope
/Users/terencebeh/Documents/Arduino/libraries/NewTone/NewTone.cpp:18:21: error: 'CS12' was not declared in this scope
prescaler = _BV(CS12); // Set the 256 prescaler bit.
/Users/terencebeh/Documents/Arduino/libraries/NewTone/NewTone.cpp:26:16: error: cannot convert 'volatile uint32_t* {aka volatile long unsigned int*}' to 'volatile uint8_t* {aka volatile unsigned char*}' in assignment
_pinOutput = portOutputRegister(digitalPinToPort(pin)); // Get the output port register for the pin.
/Users/terencebeh/Documents/Arduino/libraries/NewTone/NewTone.cpp:31:3: error: 'ICR1' was not declared in this scope
ICR1 = top; // Set the top.
/Users/terencebeh/Documents/Arduino/libraries/NewTone/NewTone.cpp:32:7: error: 'TCNT1' was not declared in this scope
if (TCNT1 > top) TCNT1 = top; // Counter over the top, put within range.
/Users/terencebeh/Documents/Arduino/libraries/NewTone/NewTone.cpp:33:3: error: 'TCCR1B' was not declared in this scope
TCCR1B = _BV(WGM13) | prescaler; // Set PWM, phase and frequency corrected (ICR1) and prescaler.
/Users/terencebeh/Documents/Arduino/libraries/NewTone/NewTone.cpp:33:17: error: 'WGM13' was not declared in this scope
/Users/terencebeh/Documents/Arduino/libraries/NewTone/NewTone.cpp:34:3: error: 'TCCR1A' was not declared in this scope
TCCR1A = _BV(COM1B0);
/Users/terencebeh/Documents/Arduino/libraries/NewTone/NewTone.cpp:34:17: error: 'COM1B0' was not declared in this scope
/Users/terencebeh/Documents/Arduino/libraries/NewTone/NewTone.cpp:35:3: error: 'TIMSK1' was not declared in this scope
TIMSK1 |= _BV(OCIE1A); // Activate the timer interrupt.
/Users/terencebeh/Documents/Arduino/libraries/NewTone/NewTone.cpp:35:17: error: 'OCIE1A' was not declared in this scope
/Users/terencebeh/Documents/Arduino/libraries/NewTone/NewTone.cpp: In function 'void noNewTone(uint8_t)':
/Users/terencebeh/Documents/Arduino/libraries/NewTone/NewTone.cpp:39:3: error: 'TIMSK1' was not declared in this scope
TIMSK1 &= ~_BV(OCIE1A); // Remove the timer interrupt.
/Users/terencebeh/Documents/Arduino/libraries/NewTone/NewTone.cpp:39:18: error: 'OCIE1A' was not declared in this scope
/Users/terencebeh/Documents/Arduino/libraries/NewTone/NewTone.cpp:39:24: error: '_BV' was not declared in this scope
/Users/terencebeh/Documents/Arduino/libraries/NewTone/NewTone.cpp:40:3: error: 'TCCR1B' was not declared in this scope
TCCR1B = _BV(CS11); // Default clock prescaler of 8.
/Users/terencebeh/Documents/Arduino/libraries/NewTone/NewTone.cpp:40:17: error: 'CS11' was not declared in this scope
/Users/terencebeh/Documents/Arduino/libraries/NewTone/NewTone.cpp:41:3: error: 'TCCR1A' was not declared in this scope
TCCR1A = _BV(WGM10); // Set to defaults so PWM can work like normal (PWM, phase corrected, 8bit).
/Users/terencebeh/Documents/Arduino/libraries/NewTone/NewTone.cpp:41:17: error: 'WGM10' was not declared in this scope
/Users/terencebeh/Documents/Arduino/libraries/NewTone/NewTone.cpp: At global scope:
/Users/terencebeh/Documents/Arduino/libraries/NewTone/NewTone.cpp:46:4: error: expected constructor, destructor, or type conversion before '(' token
ISR(TIMER1_COMPA_vect) { // Timer interrupt vector.
exit status 1
Error compiling for board BBC micro:bit.
