TP 4056 - where's the out?
Help please! Where do I solder the output? The battery goes on bat+ bat-, but then what? Where's the output pins? I'm powering an old radio. Thanks
There is no out.
This model is battery charge only.
This type has out: Has IC to control battery charge and discharge.
Ok. Thanks for answering! So.. then How do I power the radio? Can i solder cables from the battery to the radio like this? (Sorry im a newbie)
What voltage does your old radio need?
The main chip CXA1019P/S can work between 2 volts and 8.5 volts. My battery is a 3.7 v 1500mah. Its a sony icf 18 radio.
Yes, if your radio works with +- 3.4V, but it is not recommended as there is no battery protection.
Are you connecting directly to the main chip?
Trying to do exactly this:
(Spanish)
But bought the tp4056 with no output. So my question is how do i correctly solder what in where. :sweat_smile:
It uses two 1.5V D batteries (3V).
Is it safe to connect a fully charged Li-ion battery (4.2V)?
Might damage the radio!
You can add this to your TP4056 to protect battery:
I don't know. All capacitors are above 6.2 v limit says the video...
Sorry I don't understand spanish.
Why don't you just buy the correct TP4056?
Yeah.. I'll see if the store has it. Thanks
Try this way:
How is it called? That component
How is it called? That component.
TP4056 with protection.
Nobody else has seen your lovely battery so nobody knows if it's "protected".
Fast-blow fuses aren't fancy, but they are effective.
Meaning what? You're chatting with a newbie. :sweat_smile:Thanks for answering. Can it catch fire?
