TP4056 module will not stop charging
Hi there,
I seem to have some problems with the TP4056 module.
I have ordered 10 of these modules with a USB-C connector (Aliexpress) and i am trying to charge two 18650 batteries paralel connected. But i have problems with the first 3 i tried.
The first one charged to just under 4V and then the red led stay's lit and the blue led started flashing. So i thought this was a faulty one and moved on to the next.
The second one charged to 4,27V with the red led still on but no blue led. So i diconnected and drained the battery a bit for safety.
The third module has charged to 4,31V and still won't stop charging (red led on, no blue led).
Weird thing just hapened by the way...
The third module was charging as i am typing this message. I disconneted the power after finding out it was charged to 4,31V.
I just reconnected the power and now i do have a blue led on and the red one off...
It now reads 4,23V with and without the power connected.
Can i trust these modules or should i discard them all and go for a TP5100 charger or something different?
I only have the battery connected to the module.
Thans for any help
There are some module manufacturers that use a fake TP4056.
Check if the TP4056 and the manufacturer's logo are actually printed on the chip.
PS: As already informed by @sonofcy, these modules are for only one battery.
There are modules for 2, 3, 4 batteries.
Not from AliExpress, but there might be a couple of good ones in the batch of 10.
First step. STOP trying to charge in parallel without a full blown high-quality BMS, that is how explosions happen.
Now research charging circuits (I assume you are NOT charging in-circuit, because that requires a LOT more circuitry)
I checked the chips and they have no logo on them. Only text "TP4056" and "WN202346".
So i guess no original chips?!?
I do have some 1S BMS (also alixpress), should i use one per battery if i still want to use two batteries paralel? or should i forget about that and just use one and charge more often when in use?
As far as i could google information about this. Most i coud find that the 1S BMS would not be needed because the TP4056 has overcharge and overdischarge protection built in.
I'm not shure what you mean by "chargng in circuit"?
For now i'm in the testing fase and only have the TP4056 and a battery to test the charger before i will use it in my project.
Thanks for the replies so far
The TP4056 cannot properly charge a battery that is connected to a load. For reliable, well supported LiPo battery chargers, including ones that handle "load sharing", look on Adafruit.
FIRST, DO NOT connect in parallel. Use a series connection and a buck converter.
In Circuit means the battery is both discharging, i.e under load, while it is being charged. Sometimes called a UPS. That requires a lot more circuitry especially if solar charging.
Are the 18650's protected or not, are they LiFePO4 or not. What is the claimed mAh on the label.
See this kind products:
https://pt.aliexpress.com/item/1005002329107963.html
Thank you for explaining "in-circuit" (should have known that)...
But as i explained, i'm not using any load on the battery while charging.
The batties im using are salvaged from an e-bike battery. The only text on the batteries i could find was "UR18650AA T19A". As far as i can find these should be Sanjo batteries, 2250Mah when new. So probably a bit less now. They had 3,741V charge before using them.
About the BMS in the Aliexpress link provided, i have the small 1S version i could use. Not shure if this is the exact same model but they look very similar.
I'm thinking i should probably change to another charger module. I found the TP500 and TP5100 as posible alternatives, these are switching so less heat i guess would also be nice. Would this be a good alternative?
Thanks
Test the chargers on known good, single cell LiPo batteries
I'll see if can find a good single cell and try to charge that one. Thanks for the tip.
If you are re-charging 18650 out of circuit, Liitokala has very good, multi-cell, multi-form, multi-voltage, rechargers.
Well, things seem to get weirder, but in a good way (i hope)...
I have been discharging the battery with a small fan back to 4,12V.
I reconnected the charger (fan is disconnected), and it charged the battery up to 4,18V. Stopped charging and the bue led flipped on. Seems to work like it should now.
I will be doiing a few more tests, just to be shure.
I did hapen to read something about the DW01 chip being in shipping mode when first time connecting a battery, but that should only disconnect the output. Could it have been something like this that coused the first time not working properly?
TP4056 are built to charge @ 1A....i.e. 1*18650......
Trying to charge 2 cells in parallel will certainly throw up some odd results.
Would be willing to bet the usb supply would start to groan under discharged cell operation as well.
Well, you know, the TP4056 will charge at 1A no matter how many cells are in parallel. So the only difference is how long it takes to charge.
.....and just how does the charger differentiate between the two cell pd levels and work correctly.??
Op is obviously having problems getting the module to work so following the manufacturer design straight up would be a good start.
Just a thought about the first mailfunction of the tp4056 module.
As it seems to work fine now.
I checked the voltage every now and then during charging, measuring at the output connections.
As you have informed me that it is a bad idea to charge with a load on the outputs, could my multimeter have interfeared with the charging and cause the problems i had?
Unlikely.
Even better is the SkyRC M3000. Virtually all chemistries and all cylindrical sizes. HIGHLY RECOMMENDED.
Well i just finished another cycle of partial discharge and charging again.
The module seems to work fine now stopped at 4,17V (close enough).
Just to be shure i'll give it a few more cycles testing, but if it keeps working i'm happy.
Even though i still don't know why the first attempt failed, probably a fault on my end i guess.
Thank you all for trying to help me.
