Transisiton from "enum" to "enum class"
hey i am a newbie to arduino coding.
in my code i used enum and a switch case of the enum to cycle through different program states. this is the code:
enum BootSequence {
  bootPhase0,
  bootPhase1,
  bootPhase2,
  bootPhase3,
BootSequence WandStartSequence = bootPhase0;
bool PROGRAM_BOOTING() {
  switch (WandStartSequence) {
    case bootPhase0:
      PROGRAM_BOOT_BLINK_L();
    case bootPhase1:
      PROGRAMM_BOOT_KL();
    case bootPhase2:
      PROGRAM_Vent_bootUp();
    case bootPhase3:
      BLINK_FUNCTION_LED_OF_SEGMENT(BarGraph_Segment, 0);
  if(WandStartSequence == bootPhase3){
    Serial.println("Booted");
    return true;
  else{
    Serial.println("NOT Booted");
    return false;
and in the loop function for debugging this:
Serial.println(WandStartSequence);
Then i switched to the newer enum class. But I cannot print the current value neither as string nor as int. Do i have to convert them?
And another question is that i am also using a soundchip for playing music in my program. the soundchip plays the tracks according to the provided number as int.
i there a way that i can assign the tracknames as enum class like ambient = 1, idle = 5, ....
and the use this variables for better readability? like playSong(idle), instead of playSong(5)?
enum class BootSequence {
  bootPhase0,
  bootPhase1,
  bootPhase2,
  bootPhase3,
BootSequence WandStartSequence = BootSequence::bootPhase0;
//switch function with functions above
    case BootSequence::bootPhase0:
    case BootSequence::bootPhase1:
      PROGRAMM_BOOT_KL();
    case BootSequence::bootPhase2:
    case BootSequence::bootPhase3:
  if(WandStartSequence == BootSequence::bootPhase3){
    return true;
  else{
    return false;
  Serial.println(WandStartSequence); //-> not working
[... more code]
So in short:
  • How can I Serial print the current text value of my enum class.
  • Can i assign the enum class variables different ints like in the old enum?
  • Can I convert a class enum into an int
Why did you do this ?
Cast it to an int
Have you tried?
Why would you want to do that?
As I wrote the soundchip member functions take an int as input.
In this way I can organize my soundfiles on top of my scetch with readable names and when i want to play them later i assign the name to the memeberfunction which hopefully gets converted to an int, so that the function can play the corresponding track.
read about that it is saver to use the enum class, because of not messing up with namespaces for example. and i am just learning c++ so why not use the current stuff instead of older?
you need to cast the enumeration class, then you can print the value (or hand it over to another function).
    https://forum.arduino.cc/t/transisiton-from-enum-to-enum-class/1284063
  bootPhase0,
  bootPhase1,
  bootPhase2,
  bootPhase3,
void PROGRAM_BOOT_BLINK_L() {}
void PROGRAMM_BOOT_KL() {}
void PROGRAM_Vent_bootUp() {}
void BLINK_FUNCTION_LED_OF_SEGMENT(int a, int b){
  (void)a;
  (void)b;
int BarGraph_Segment;
      PROGRAMM_BOOT_KL();
  if (WandStartSequence == BootSequence::bootPhase3) {
    return true;
  else {
    return false;
  Serial.println((int)WandStartSequence); // cast to make it printable
P.S.: please always provide a full sketch - otherwise we can't put it in the IDE and make it working.
btw, I think there are better names like "phase 0 .. phase 3".
You are unable to print the enum class because there is no overload of the print class for the enum class.
Hey thank you.
Is there a fundamental difference between? your Version and static cast like:
  int temp_int = static_cast<int>(WandStartSequence);
  Serial.println(temp_int);
:slight_smile: any suggestions?
if you prefer the static_cast - use the static cast.
Doing so is a recognized C++ Best Practice.
On the why = in C++, an enum allows for implicit promotion to its underlying integral type, typically an int, for compatibility with C. This means that values of an enum type can be used interchangeably with integers in expressions, assignments, and function arguments without requiring an explicit cast.
However, an enum class (strongly-typed enumeration) introduced in C++11 does not allow such implicit promotion. Enum class values are strongly scoped and must be explicitly cast to their underlying type to be used as integers. This design choice was made to enhance type safety by preventing unintended conversions and limiting the scope of enumerators.
So your issue (as other explained) was that you did no longer benefit from the implicit promotion to an int which print would know how to handle.
well - the point is that you should not cast them.
if you want to print
  bootPhase0,
  bootPhase1,
  bootPhase2,
  bootPhase3,
then you write
void printBootSequence(BootSequence phase) {
  switch (phase) {
    case BootSequence::bootPhase0: Serial.print(F("bootPhase0")); break;
    case BootSequence::bootPhase1: Serial.print(F("bootPhase1")); break;
    case BootSequence::bootPhase2: Serial.print(F("bootPhase2")); break;
    case BootSequence::bootPhase3: Serial.print(F("bootPhase3")); break;
    default: Serial.print(F("Unknown BootSequence phase")); break;
so the function to print the enumerator is the "safe way" we should show :slight_smile:
if OP wants a cast then there is no point in using enum class, just sticking to plain old enum and implicit promotion is good enough.
enum class allows multiple enum types to use the duplicate member names without conflict. The same names can even have different underlying integer values in different enum classes.
I did forget that that is the reason why I use them :frowning:
True - but does the OP needs this?
(I like strongly typed languages and codes, so I won’t oppose advertising for it.)
yeah that's true.
But in thinking about why my code did not work i learned on how to use enum class.
So I can use this one for the switch case that does not need to be converted and maybe use the oldschool enum for the tracklist that i want to play which automatically gets converted to int.
btw I read about the enum class in the book "clean c++ 17" from stephan roth.
It’s always a good idea to explore and learn new things. Kudos for doing so.
