Because it's delicate and and easy to fry, or another reason?
Because the 2N7000 is a "small signal" FET with an absolute maximum rating of 200 mA, not suitable for switching power.
Adequate I suppose for your relay at 33 mA, but not for anything over say, 120 mA or an apparently small motor which has a higher "stall" or starting current.
And as the datasheet mentions, an "on" resistance of 6 Ohms is not that great, losing 450 mV at 75 mA and nearly a Volt at 150 mA.
Fine, I'll add some BS170 on my next order. These little components are so cheap, im going to have bags of parts laying around I may never use:)
tsperry88:
Don't worry about it. Always buy more of cheap parts than you need, one day you will use at least some of them and be glad you have them. Get some small storage drawers or something to keep them in.
tsperry88:
I would not advise it! The BS170 is clearly not a logic-level device.
Paul__B:
Could you suggest one? Admittedly I assumed rather than researched that it was a suitable part, based on your previous post having a link to it.
Already suggested this list to you:
Examples of logic level MOSFETs.
https://forum.arduino.cc/index.php?action=dlattach;topic=690136.0;attach=368349
I dint see any through hole MOSFETs on your list that wouldn't take up considerably more board space than the TO92.
I have never seen a ‘reasonably low Rdson at 4-5v’ TO92 “Logic level” MOSFET.
Use “Logic Level” TO220 cases if you need a THD.
See post #716 and #714
https://forum.arduino.cc/index.php?topic=445951.msg4456512#msg4456512
Other Adapter SMD PCBs available on Ebay and Amazon.
tsperry88:
I drew up and had 5 little PCBs made...
tsperry88:
If you design your own boards, then it's high time you left the through-hole world behind.
There's nowadays a lot more choice in SMD, and at cheaper prices.
Soldering SMD is not as hard as you might think.
Leo..
This is my first board and I’m tired of this project, so I don’t want to redo the layout. I did order a kit of misc smd components and a board for practice. Haven’t recieved it yet though.
tsperry88:
I can't see a previous post here where I referenced a BS170. Sounds like BS to me! ![]()
And I cannot see any difficulty soldering a SOT23/ SOT224/ SOT89 device to a PCB (or "breakout" board). Only 3 pins, well spaced, you just need to either pre-glue it to the PCB (which is what "pick and place" machines do) or have a "finger" device to hold it down - as has been discussed here frequently in the past.
And depending on the arrangement, you can often solder a SOT-23 to the TO-92 pads.
Paul__B:
The "better transistor" will be a logic-level FET.Why are you not using one?
Click the link:) I'll practice up with SMD for next time.
Ah! You are right!
Well, there's a lesson there. ![]()
You can't believe everything you read, especially as it seems on an "Addicore" page! And I fear I did not check the datasheet. It shows the RDS(ON) - Static Drain-Source On-Resistance - as 1.2 Ω "typical" and 5 Ω maximum, but at 10 V, not 4 V, so it is clearly not a "logic-level" device.
Sorry about that! I was fooled by my too-quick search. ![]()
It's all good. I appreciate the help. Just going to stick with the bc547 on this project.
