Hello everyone,
I would like some help regarding a small project I am trying to build.
I have the following components:
- A 12V 12.5A power supply
- An Arduino Mega 2560 with Arduino Proto Shield
- A TMC2209 stepper motor driver
- A NEMA 17 stepper motor
What I am trying to understand is how to properly connect everything together so that the stepper motor can work correctly.
Do I connect the TMC2209 directly to the 12V power supply output?
Do I need to use any resistor in between?
Or should it be connected through the Arduino?
The NEMA 17 stepper motor has a rated voltage of 3.4V and a rated current of 1.0A.
I am quite new to electronics and I searched online, but I found conflicting information. Some people say that the 12V should be connected from the side of the board where the heatsink is located, while others suggest connecting from the pin side. I am not sure which is correct.
I will also attach a photo and the pinout diagram I found online, because I am not sure if it is accurate. I also cannot understand how a proper soldering or wiring connection is supposed to be made on the heatsink side, since there is almost no physical space there for any wires or soldering.
Additionally, since I am using an Arduino Mega 2560, I am not planning to use an Arduino Uno CNC shield, even though I have seen many people using it. From what I understand, it is easier to use, but I assume it is not directly compatible with the Mega due to different pinout layouts and I am not sure how to adapt it properly.
I have also seen some people connect CNC shields designed for the Arduino Uno onto a Mega 2560, but I do not understand how the pin mapping or wiring needs to be changed.
I would really appreciate any guidance on how to properly start this project, as this is the main point where I am currently stuck.
I would also like to ask if specific cable thickness is required for the connections, or if a standard 0.5 mm² wire is sufficient.
Any help or clear wiring explanation would be really appreciated.
