Trouble shooting TPIC6B595N
Edit: I must preface this by saying that I am very very new to these things and have never used a shift register before. I am just trying to get a basic situation working so I can study it further to understand what I am doing.
I am trying to get 8 LEDs to be controlled through the shift register TPIC6B595N, datasheet here:
www.sparkfun.com/datasheets/IC/TPIC6B595.pdf
My problem is that I can't get any lights to light up at all.
I have tried following the tutorials and posts here and here:
I have attached the Fritzing file and PNG of my project. Sorry, the red box represents the shift register with the notch on the casing being on the far left side (I couldn't figure out how to create your own component). The oddly placed LED is just there to show that the board is powered and working at a minimal level.
I have tried all of the source code on both of the tutorials / posts to no avail. All lights always stay turned off. To show where I left off trying, my code is as follows at the moment:
 Shift Register Example
 for TPIC6B595 shift register by Jens C Brynildsen
 This sketch turns reads serial input and uses it to set the pins
 of a TPIC6B595 shift register.
 Hardware:
 * TPIC6B595 shift register attached to pins 7, 8, 11 and 12 of the Arduino,
 as detailed below.
 * LEDs attached to each of the outputs of the shift register
 Based on the example created 23 Mar 2010 by Tom Igoe
10 = register clock / latch pin (RCK)
11 = shift register clear (SRCLR)
8 = serial in (SER IN)
5 = shift register clock(SRCK)
//Pin to clear the register
//const int clearPin = 7;
const int clearPin = 10;
//Pin connected to latch pin (ST_CP) of 74HC595
//const int latchPin = 8;
const int latchPin = 11;
//Pin connected to clock pin (SH_CP) of 74HC595
//const int clockPin = 12;
const int clockPin = 5;
////Pin connected to Data in (DS) of 74HC595
//const int dataPin = 11;
const int dataPin = 8;
int counter = 0;
int numLedsInUse = 24;
  //set pins to output because they are addressed in the main loop
  pinMode(clearPin, OUTPUT);
  pinMode(latchPin, OUTPUT);
  pinMode(dataPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
  Serial.println("*");
  // delay a little and then set
  delay(10);
  // Always start by sentting SRCLR high
  digitalWrite( clearPin, HIGH);
  // Display LED's running
  if( counter >= (numLedsInUse-1) ){
    counter = 0;
    counter++;
  // write to the shift register with the correct bit set high:
  registerWrite(counter, HIGH);
  delay( 10 );
// This method sends bits to the shift register:
void registerWrite(int whichPin, int whichState) {
  // the bits you want to send
  byte bitsToSend0 = 0;
  byte bitsToSend1 = 0;
  byte bitsToSend2 = 0;
  // turn off the output so the pins don't light up
  // while you're shifting bits:
  digitalWrite(latchPin, LOW);
  // Set bit pattern
  bitWrite(bitsToSend0, whichPin, whichState);
  if( whichPin > 7 ){
    bitWrite(bitsToSend1, whichPin-8, whichState);
  if( whichPin > 15 ){
    bitWrite(bitsToSend2, whichPin-16, whichState);
  // shift the bits out for all three registers. Note the opposite order.
  shiftOut(dataPin, clockPin, MSBFIRST, bitsToSend2);
  shiftOut(dataPin, clockPin, MSBFIRST, bitsToSend1);
  shiftOut(dataPin, clockPin, MSBFIRST, bitsToSend0);
  // turn on the output so the LEDs can light up:
  digitalWrite(latchPin, HIGH);
  // debug output
  Serial.print( counter );
  Serial.print( " - " );
  Serial.print( " bitsToSend0 " );
  Serial.print( bitsToSend0, BIN );
  Serial.print( " bitsToSend1 " );
  Serial.print( bitsToSend1, BIN );
  Serial.print( " bitsToSend2 " );
  Serial.println( bitsToSend2, BIN );
shift-register.fzz (9.38 KB)
This shifts out 3 bytes, if you only have 1 shift register the first 2 bytes will never be seen:
Do you have Master Clear pulled High, and OE/ connected to Gnd, or have PWM for controlling brightness?
My own 595 tutorial / example:
I don't see where you have Vcc connected to the chip.
Final edit: It seams that the issue was that the shift register wasn't sitting properly in the breadboard. If I hold it down into the board with my fingers then it works perfectly. Super annoying but yep, thats it. Thanks for the help and if anyone knows of a way to keep these in the board better that would be great!
The working code is here:
 Hardware:
 as detailed below.
const int clearPin = 11;
const int latchPin = 10;
int counter = 0;
int numLedsInUse = 8;
  delay(100);
    counter = 0;
    counter++;
  Serial.print("counter: ");
  Serial.println(counter);
  delay( 500 );
  // write number as bits
@Nick Gammon - I dont see in your tutorial the basic code for just 1 shift register to light up 1 LED at a time. I fixed the problem with not having the Acc connected, very very silly of me.
The nature of shift registers if you have to send 8 bits at once (or more if you connect multiple 595s). So to turn on one LED you have to shift out 8 bits.
As an example:
  digitalWrite (LATCH, LOW);
  SPI.transfer (0b00000001);    // turn on one LED
  digitalWrite (LATCH, HIGH);
  delay (1000);
  SPI.transfer (0b00000011);    // turn on a second one
The second transfer turns on another LED but it also has to send out again the first one.
