Ive updated the code (its terribly repetetive and long but it works...kind of). I can get all channels on the first 3 addresses to display perfectly thruogh number 24 but when it comes to channel 4 it only displays the number 28 (which is the last screen) and skips 25-27. is there any modifications i need to do to have the final TCA only write to channels 0-3 (for numbers 25-28)? The adress is wired correctly and Ive verified that the SCL and SDA lines are connected correctly.
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
Adafruit_SSD1306 display_OLED_1(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
Adafruit_SSD1306 display_OLED_2(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
Adafruit_SSD1306 display_OLED_3(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
Adafruit_SSD1306 display_OLED_4(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
Adafruit_SSD1306 display_OLED_5(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
Adafruit_SSD1306 display_OLED_6(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
Adafruit_SSD1306 display_OLED_7(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
Adafruit_SSD1306 display_OLED_8(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
Adafruit_SSD1306 display_OLED_9(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
Adafruit_SSD1306 display_OLED_10(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
Adafruit_SSD1306 display_OLED_11(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
Adafruit_SSD1306 display_OLED_12(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
Adafruit_SSD1306 display_OLED_13(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
Adafruit_SSD1306 display_OLED_14(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
Adafruit_SSD1306 display_OLED_15(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
Adafruit_SSD1306 display_OLED_16(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
Adafruit_SSD1306 display_OLED_17(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
Adafruit_SSD1306 display_OLED_18(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
Adafruit_SSD1306 display_OLED_19(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
Adafruit_SSD1306 display_OLED_20(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
Adafruit_SSD1306 display_OLED_21(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
Adafruit_SSD1306 display_OLED_22(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
Adafruit_SSD1306 display_OLED_23(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
Adafruit_SSD1306 display_OLED_24(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
Adafruit_SSD1306 display_OLED_25(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
Adafruit_SSD1306 display_OLED_26(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
Adafruit_SSD1306 display_OLED_27(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
Adafruit_SSD1306 display_OLED_28(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
#define TCAADDR1 0x70
#define TCAADDR2 0x71
#define TCAADDR3 0x72
#define TCAADDR4 0x73
//Selects the channels and address of the TCA9548A for tcaselect1-4
void tcaselect1(uint8_t i) {
if (i > 7) return;
Wire.beginTransmission(TCAADDR1);
Wire.write(1 << i);
Wire.endTransmission();
void tcaselect2(uint8_t i) {
if (i > 7) return;
Wire.beginTransmission(TCAADDR2);
Wire.write(1 << i);
void tcaselect3(uint8_t i) {
if (i > 7) return;
Wire.beginTransmission(TCAADDR3);
Wire.write(1 << i);
void tcaselect4(uint8_t i) {
if (i > 7 ) return;
Wire.beginTransmission(TCAADDR4);
Wire.write(1<<1);
//Disables the channels and address of the TCA9548A for tcaselect1-4
void tcaselect1_DISABLE() {
Wire.write(0); // no channel selected
void tcaselect2_DISABLE() {
void tcaselect3_DISABLE() {
void tcaselect4_DISABLE() {
//Establish communications baud rate 115200
Wire.begin(); // Start I2C communication with the multiplexer
//IDK if this is actually needed TBD
tcaselect2_DISABLE(); //Disable TCAADDR2
tcaselect3_DISABLE(); //Disable TCAADDR3
tcaselect4_DISABLE(); //Disable TCAADDR4
//Channel 0 OLED_1 TCAADDR1
tcaselect1(0);
if (!display_OLED_1.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
Serial.println(F("display_OLED_1 allocation failed"));
//for (;;);
display_OLED_1.clearDisplay();
//Channel 1 OLED_2 TCAADDR1
tcaselect1(1);
if (!display_OLED_2.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
Serial.println(F("display_OLED_2 allocation failed"));
//for (;;);
display_OLED_2.clearDisplay();
//Channel 2 OLED_3 TCAADDR1
tcaselect1(2);
if (!display_OLED_3.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
Serial.println(F("display_OLED_3 allocation failed"));
//for (;;);
display_OLED_3.clearDisplay();
//Channel 3 OLED_4 TCAADDR1
tcaselect1(3);
if (!display_OLED_4.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
Serial.println(F("display_OLED_4 allocation failed"));
//for (;;);
display_OLED_4.clearDisplay();
//Channel 4 OLED_5 TCAADDR1
tcaselect1(4);
if (!display_OLED_5.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
Serial.println(F("display_OLED_5 allocation failed"));
//for (;;);
display_OLED_5.clearDisplay();
//Channel 5 OLED_6 TCAADDR1
tcaselect1(5);
if (!display_OLED_6.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
Serial.println(F("display_OLED_6 allocation failed"));
//for (;;);
display_OLED_6.clearDisplay();
//Channel 6 OLED_7 TCAADDR1
tcaselect1(6);
if (!display_OLED_7.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
Serial.println(F("display_OLED_7 allocation failed"));
//for (;;);
display_OLED_7.clearDisplay();
//Channel 7 OLED_8 TCAADDR1
tcaselect1(7);
if (!display_OLED_8.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
Serial.println(F("display_OLED_8 allocation failed"));
//for (;;);
display_OLED_8.clearDisplay();
tcaselect1(0);
display_OLED_1.setTextSize(8);
display_OLED_1.setTextColor(WHITE);
display_OLED_1.setCursor(45, 10);
display_OLED_1.println("1");
display_OLED_1.display();
tcaselect1(1);
display_OLED_2.setTextSize(8);
display_OLED_2.setTextColor(WHITE);
display_OLED_2.setCursor(45, 10);
display_OLED_2.println("2");
display_OLED_2.display();
tcaselect1(2);
display_OLED_3.setTextSize(8);
display_OLED_3.setTextColor(WHITE);
display_OLED_3.setCursor(45, 10);
display_OLED_3.println("3");
display_OLED_3.display();
tcaselect1(3);
display_OLED_4.setTextSize(8);
display_OLED_4.setTextColor(WHITE);
display_OLED_4.setCursor(45, 10);
display_OLED_4.println("4");
display_OLED_4.display();
tcaselect1(4);
display_OLED_5.setTextSize(8);
display_OLED_5.setTextColor(WHITE);
display_OLED_5.setCursor(45, 10);
display_OLED_5.println("5");
display_OLED_5.display();
tcaselect1(5);
display_OLED_6.setTextSize(8);
display_OLED_6.setTextColor(WHITE);
display_OLED_6.setCursor(45, 10);
display_OLED_6.println("6");
display_OLED_6.display();
tcaselect1(6);
display_OLED_7.setTextSize(8);
display_OLED_7.setTextColor(WHITE);
display_OLED_7.setCursor(45, 10);
display_OLED_7.println("7");
display_OLED_7.display();
tcaselect1(7);
display_OLED_8.setTextSize(8);
display_OLED_8.setTextColor(WHITE);
display_OLED_8.setCursor(45, 10);
display_OLED_8.println("8");
display_OLED_8.display();
tcaselect1_DISABLE();
//Channel 0 OLED_9 TCAADDR2
tcaselect2(0);
if (!display_OLED_9.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
Serial.println(F("display_OLED_9 allocation failed"));
//for (;;);
display_OLED_9.clearDisplay();
//Channel 1 OLED_10 TCAADDR2
tcaselect2(1);
if (!display_OLED_10.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
Serial.println(F("display_OLED_10 allocation failed"));
//for (;;);
display_OLED_10.clearDisplay();
//Channel 2 OLED_11 TCAADDR2
tcaselect2(2);
if (!display_OLED_11.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
Serial.println(F("display_OLED_11 allocation failed"));
//for (;;);
display_OLED_11.clearDisplay();
//Channel 3 OLED_12 TCAADDR2
tcaselect2(3);
if (!display_OLED_12.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
Serial.println(F("display_OLED_12 allocation failed"));
//for (;;);
display_OLED_12.clearDisplay();
//Channel 4 OLED_13 TCAADDR2
tcaselect2(4);
if (!display_OLED_13.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
Serial.println(F("display_OLED_13 allocation failed"));
//for (;;);
display_OLED_13.clearDisplay();
//Channel 5 OLED_14 TCAADDR2
tcaselect2(5);
if (!display_OLED_14.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
Serial.println(F("display_OLED_14 allocation failed"));
//for (;;);
display_OLED_14.clearDisplay();
//Channel 6 OLED_15 TCAADDR2
tcaselect2(6);
if (!display_OLED_15.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
Serial.println(F("display_OLED_15 allocation failed"));
//for (;;);
display_OLED_15.clearDisplay();
//Channel 7 OLED_16 TCAADDR2
tcaselect2(7);
if (!display_OLED_16.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
Serial.println(F("display_OLED_16 allocation failed"));
//for (;;);
display_OLED_16.clearDisplay();
tcaselect2(0);
display_OLED_9.setTextSize(8);
display_OLED_9.setTextColor(WHITE);
display_OLED_9.setCursor(45, 10);
display_OLED_9.println("9");
display_OLED_9.display();
tcaselect2(1);
display_OLED_10.setTextSize(2);
display_OLED_10.setTextColor(WHITE);
display_OLED_10.setCursor(45, 10);
display_OLED_10.println("10");
display_OLED_10.display();
tcaselect2(2);
display_OLED_11.setTextSize(2);
display_OLED_11.setTextColor(WHITE);
display_OLED_11.setCursor(45, 10);
display_OLED_11.println("11");
display_OLED_11.display();
tcaselect2(3);
display_OLED_12.setTextSize(2);
display_OLED_12.setTextColor(WHITE);
display_OLED_12.setCursor(45, 10);
display_OLED_12.println("12");
display_OLED_12.display();
tcaselect2(4);
display_OLED_13.setTextSize(2);
display_OLED_13.setTextColor(WHITE);
display_OLED_13.setCursor(45, 10);
display_OLED_13.println("13");
display_OLED_13.display();
tcaselect2(5);
display_OLED_14.setTextSize(2);
display_OLED_14.setTextColor(WHITE);
display_OLED_14.setCursor(45, 10);
display_OLED_14.println("14");
display_OLED_14.display();
tcaselect2(6);
display_OLED_15.setTextSize(2);
display_OLED_15.setTextColor(WHITE);
display_OLED_15.setCursor(45, 10);
display_OLED_15.println("15");
display_OLED_15.display();
tcaselect2(7);
display_OLED_16.setTextSize(2);
display_OLED_16.setTextColor(WHITE);
display_OLED_16.setCursor(45, 10);
display_OLED_16.println("16");
display_OLED_16.display();
//Channel 0 OLED_17 TCAADDR3
tcaselect3(0);
if (!display_OLED_17.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
Serial.println(F("display_OLED_17 allocation failed"));
//for (;;);
display_OLED_17.clearDisplay();
//Channel 1 OLED_18 TCAADDR3
tcaselect3(1);
if (!display_OLED_18.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
Serial.println(F("display_OLED_18 allocation failed"));
//for (;;);
display_OLED_18.clearDisplay();
//Channel 2 OLED_19 TCAADDR3
tcaselect3(2);
if (!display_OLED_19.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
Serial.println(F("display_OLED_19 allocation failed"));
//for (;;);
display_OLED_19.clearDisplay();
//Channel 3 OLED_20 TCAADDR3
tcaselect3(3);
if (!display_OLED_20.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
Serial.println(F("display_OLED_20 allocation failed"));
//for (;;);
display_OLED_20.clearDisplay();
//Channel 4 OLED_21 TCAADDR3
tcaselect3(4);
if (!display_OLED_21.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
Serial.println(F("display_OLED_21 allocation failed"));
//for (;;);
display_OLED_21.clearDisplay();
//Channel 5 OLED_22 TCAADDR3
tcaselect3(5);
if (!display_OLED_22.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
Serial.println(F("display_OLED_22 allocation failed"));
//for (;;);
display_OLED_22.clearDisplay();
//Channel 6 OLED_23 TCAADDR3
tcaselect3(6);
if (!display_OLED_23.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
Serial.println(F("display_OLED_23 allocation failed"));
//for (;;);
display_OLED_23.clearDisplay();
//Channel 7 OLED_24 TCAADDR3
tcaselect3(7);
if (!display_OLED_24.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
Serial.println(F("display_OLED_24 allocation failed"));
//for (;;);
display_OLED_24.clearDisplay();
tcaselect3(0);
display_OLED_17.setTextSize(2);
display_OLED_17.setTextColor(WHITE);
display_OLED_17.setCursor(45, 10);
display_OLED_17.println("17");
display_OLED_17.display();
tcaselect3(1);
display_OLED_18.setTextSize(2);
display_OLED_18.setTextColor(WHITE);
display_OLED_18.setCursor(45, 10);
display_OLED_18.println("18");
display_OLED_18.display();
tcaselect3(2);
display_OLED_19.setTextSize(2);
display_OLED_19.setTextColor(WHITE);
display_OLED_19.setCursor(45, 10);
display_OLED_19.println("19");
display_OLED_19.display();
tcaselect3(3);
display_OLED_20.setTextSize(2);
display_OLED_20.setTextColor(WHITE);
display_OLED_20.setCursor(45, 10);
display_OLED_20.println("20");
display_OLED_20.display();
tcaselect3(4);
display_OLED_21.setTextSize(2);
display_OLED_21.setTextColor(WHITE);
display_OLED_21.setCursor(45, 10);
display_OLED_21.println("21");
display_OLED_21.display();
tcaselect3(5);
display_OLED_22.setTextSize(2);
display_OLED_22.setTextColor(WHITE);
display_OLED_22.setCursor(45, 10);
display_OLED_22.println("22");
display_OLED_22.display();
tcaselect3(6);
display_OLED_23.setTextSize(2);
display_OLED_23.setTextColor(WHITE);
display_OLED_23.setCursor(45, 10);
display_OLED_23.println("23");
display_OLED_23.display();
tcaselect3(7);
display_OLED_24.setTextSize(2);
display_OLED_24.setTextColor(WHITE);
display_OLED_24.setCursor(45, 10);
display_OLED_24.println("24");
display_OLED_24.display();
tcaselect4(0);
if (!display_OLED_25.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
Serial.println(F("display_OLED_25 allocation failed"));
//for (;;);
display_OLED_25.clearDisplay();
tcaselect4(1);
if (!display_OLED_26.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
Serial.println(F("display_OLED_26 allocation failed"));
//for (;;);
display_OLED_26.clearDisplay();
tcaselect4(2);
if (!display_OLED_27.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
Serial.println(F("display_OLED_27 allocation failed"));
//for (;;);
display_OLED_27.clearDisplay();
tcaselect4(3);
if (!display_OLED_28.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
Serial.println(F("display_OLED_28 allocation failed"));
//for (;;);
display_OLED_28.clearDisplay();
tcaselect4(0);
display_OLED_25.setTextSize(2);
display_OLED_25.setTextColor(WHITE);
display_OLED_25.setCursor(45, 10);
display_OLED_25.println("25");
display_OLED_25.display();
tcaselect4(1);
display_OLED_26.setTextSize(2);
display_OLED_26.setTextColor(WHITE);
display_OLED_26.setCursor(45, 10);
display_OLED_26.println("26");
display_OLED_26.display();
tcaselect4(2);
display_OLED_27.setTextSize(2);
display_OLED_27.setTextColor(WHITE);
display_OLED_27.setCursor(45, 10);
display_OLED_27.println("27");
display_OLED_27.display();
tcaselect4(3);
display_OLED_28.setTextSize(2);
display_OLED_28.setTextColor(WHITE);
display_OLED_28.setCursor(45, 10);
display_OLED_28.println("28");
display_OLED_28.display();
