Trouble with DS18b20 and LCD
I have pickup arduino in minimal configuration. Just Atmega168-20pu oscillator, two condensers and a lot of wires.
Upload a sketch with LCD & Dallas DS18b20.
It starts but in a few minuties appear garbage on the screen.
Do you have any ideas what can it be?
#include <Wire.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#include <LiquidCrystal.h>
// Data wire is plugged into pin 2 on the Arduino
#define ONE_WIRE_BUS 10
/*-----( Declare Constants )-----*/
/*-----( Declare objects )-----*/
// set the LCD address to 0x27 for a 20 chars 4 line display
// Set the pins on the I2C chip used for LCD connections:
//                    addr, en,rw,rs,d4,d5,d6,d7,bl,blpol
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);  // Set the LCD address
// Pass our oneWire reference to Dallas Temperature.
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
float Temp;
// degree c sybmol
byte degc[8] =
  B01000,
  B10100,
  B01000,
  B00011,
  B00100,
  B00100,
  B00011,
  B00000,
/*-----( Declare Variables )-----*/
//NONE
void setup()   /*----( SETUP: RUNS ONCE )----*/
  lcd.begin(16,2);   // initialize the lcd for 16 chars 2 lines, turn on backlight
//-------- Write characters on the display ------------------
// NOTE: Cursor Position: (CHAR, LINE) start at 0
  lcd.setCursor(0,0); //Start at character 4 on line 0
  lcd.print("MyMachine");
  lcd.setCursor(0,1);
  lcd.print("Temp IC Control");
  delay(4000);
  // Start up the library
  sensors.begin();
  // IC Default 9 bit. If you have troubles consider upping it 12.
  // Ups the delay giving the IC more time to process the temperature measurement
  lcd.createChar(0,degc);
}/*--(end setup )---*/
void loop()   /*----( LOOP: RUNS CONSTANTLY )----*/
sensors.requestTemperatures(); // Send the command to get temperatures
delay(200);
lcd.clear();
lcd.print("Temp for Dev1:");
lcd.setCursor(2,1);
Temp = sensors.getTempCByIndex(0);
lcd.print(Temp);
lcd.setCursor(8,1);
lcd.write((uint8_t)0);
lcd.write("    ");
}/* --(end main loop )-- */
/* ( THE END ) */
2 Moderator
I am not sure that is programming trouble.
This programm work well on Arduino UNO board.
I compiled your sketch using the Arduino 1.5.8 and it uses 1684 bytes of SRAM, so it seems that your sketch could experience overflow issues.
Try using the F() to store the text strings into Flash.
So convert instructions like:
in
lcd.print(F("Temp for Dev1:"));
and try again
