I’m having a problem using an H-Bridge to control two motors. The short version is that the logic pins on the H-Bridge seem to be at a higher voltage before I connect them to the arduino. Current doesn't flow when I set their IO pins to HIGH. Current does flow when I set their IO pins to LOW, but presumably it is flowing into the IO pin and not out of it.
The long version is this: I set everything up on the breadboard and it worked as it was supposed to. That is, one of the motors was connected to outputs 1 and 2. When the pin connected to input 1 is set to HIGH, but the pin connected to input 2 is LOW, the motor would spin one way. Switching the charges changed the direction of the motor.
Then I transferred it to perf board, thinking that everything was identical, but when I turned it on none of the motors moved. With some programs I got movement, but not exactly as I expected. As I was fiddling with it, I unplugged the logic pins and tried applying positive voltage to them individually and nothing happened. Then I got my big surprise. I could make the motors move by connecting the logic pins to ground.
I don’t understand why this is. It must be that those pins are already at a higher voltage. Connecting to ground lets the current flow, but in the direction opposite of what I expected. I can control both motors in both directions, but I have to invert everything in my program. For example, before, the motors moved fastest when I set PWM close to 255. Now they move fastest when PWM is set close to 0.
I’m using the TI L293 H-Bridge, and I tried to look at the schematics for it, but I’m new to this and I don’t understand the transistors well enough to find the problem. I can just rearrange the program and live with it, but I’m worried that I might be damaging something. I don’t know if I’ve created some short circuit or reverse polarity that will cause problems.
Does this sound familiar to anyone?
