Hi guys,.. I have an ESP8266 D1 mini running the following code, I am using the latest version of the windows IDE V2.36, on a Win10 m/c.
I got the original library example code running ,. but then wanted to move forwarded with my specific MQTT server,.. so implemented the code changes to point to my server, changed the topic, I found references to entering my login credentials, for which I found the following docs.. My mqtt_account and passwd string are as shown and not contained within quotes.. and are verified correct as I use them on my Tasmota D1's.. and they work fine, and I can see their outputs with mqtt_explorer...
#### AsyncMqttClient& setCredentials(const char\* `username`, const char\* `password` = nullptr)
Set the username/password. Defaults to non-auth.
* **`username`**: Username
* **`password`**: Password
I have implemented this structure, I think,.. ( it compiles,.. ) but I am not sure I have done it correctly, as I can find no other examples of this structure in use etc,.. and I am am a little baffled, as to whether my implementation is correct,.. I have my doubts.
Can any one confirm, or offer corrective guidance on my possible coding errors.
Or is there a better MQTT wireless 8266 compatible library implementation
Many tx
FullyFeature_ESP8266.ino
AsyncMqttClient_Generic is a library for ESP32, ESP8266, Protenta_H7, STM32F7, etc. with current AsyncTCP support
Based on and modified from :
1) async-mqtt-client (https://github.com/marvinroger/async-mqtt-client)
Built by Khoi Hoang https://github.com/khoih-prog/AsyncMqttClient_Generic
https://github.com/khoih-prog/AsyncMQTT_Generic/tree/main/src
// Use ESP8266 core v2.7.4- for SSL as new cores don't use axtls anymore
// Use core v3.0.2+ for LwIP Ethernet W5500lwIP, W5100lwIP and ENC28J60lwIP libraries
// Must use KH forked ESPAsyncTCP library or compile error
#include "defines.h"
#include <ESP8266WiFi.h>
#include <Ticker.h>
#include <AsyncMqtt_Generic.h>
//#define MQTT_HOST IPAddress(192, 168, 2, 110)
#define MQTT_HOST IPAddress(192, 168, 3, 167) // Broker address
#define MQTT_PORT 1883
// const char *PubTopic = "async-mqtt/ESP8266_Pub"; // Topic to publish
const char* PubTopic = "discharge-cntrl/Battery"; // Topic to publish
AsyncMqttClient mqttClient;
Ticker mqttReconnectTimer;
WiFiEventHandler wifiConnectHandler;
WiFiEventHandler wifiDisconnectHandler;
Ticker wifiReconnectTimer;
void connectToWifi() {
Serial.println("Connecting to Wi-Fi...");
WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
void connectToMqtt() {
Serial.println("Connecting to MQTT...");
mqttClient.connect();
void onWifiConnect(const WiFiEventStationModeGotIP& event) {
(void)event;
Serial.print("Connected to Wi-Fi. IP address: ");
Serial.println("Trying to connect MQTT ln58");
connectToMqtt();
void onWifiDisconnect(const WiFiEventStationModeDisconnected& event) {
(void)event;
Serial.println("Disconnected from Wi-Fi.");
mqttReconnectTimer.detach(); // ensure we don't reconnect to MQTT while reconnecting to Wi-Fi
wifiReconnectTimer.once(2, connectToWifi);
AsyncMqttClient& setCredentials(const char* mqtt_login, const char* xxxxxxf = nullptr);
void printSeparationLine() {
Serial.println("************************************************");
void onMqttConnect(bool sessionPresent) {
Serial.print("Connected to MQTT broker: ");
Serial.print(MQTT_HOST);
Serial.print(", port: ");
Serial.println(MQTT_PORT);
Serial.print("PubTopic: ");
Serial.println(PubTopic);
printSeparationLine();
Serial.print("Session present: ");
Serial.println(sessionPresent);
uint16_t packetIdSub = mqttClient.subscribe(PubTopic, 2);
Serial.print("Subscribing at QoS 2, packetId: ");
Serial.println(packetIdSub);
mqttClient.publish(PubTopic, 0, true, "ESP8266 Test1");
Serial.println("Publishing at QoS 0");
uint16_t packetIdPub1 = mqttClient.publish(PubTopic, 1, true, "ESP8266 Test2");
Serial.print("Publishing at QoS 1, packetId: ");
Serial.println(packetIdPub1);
uint16_t packetIdPub2 = mqttClient.publish(PubTopic, 2, true, "ESP8266 Test3");
Serial.print("Publishing at QoS 2, packetId: ");
Serial.println(packetIdPub2);
void onMqttDisconnect(AsyncMqttClientDisconnectReason reason) {
(void)reason;
Serial.println("Disconnected from MQTT.");
if (WiFi.isConnected()) {
Serial.println("Wifi connected, so lets try MQTT");
mqttReconnectTimer.once(2, connectToMqtt);
void onMqttSubscribe(const uint16_t& packetId, const uint8_t& qos) {
Serial.println("Subscribe acknowledged.");
Serial.print(" packetId: ");
Serial.println(packetId);
Serial.print(" qos: ");
Serial.println(qos);
void onMqttUnsubscribe(const uint16_t& packetId) {
Serial.println("Unsubscribe acknowledged.");
void onMqttMessage(char* topic, char* payload, const AsyncMqttClientMessageProperties& properties,
const size_t& len, const size_t& index, const size_t& total) {
(void)payload;
Serial.println("Publish received.");
Serial.print(" topic: ");
Serial.println(topic);
Serial.println(properties.qos);
Serial.print(" dup: ");
Serial.println(properties.dup);
Serial.print(" retain: ");
Serial.println(properties.retain);
Serial.print(" len: ");
Serial.println(len);
Serial.print(" index: ");
Serial.println(index);
Serial.print(" total: ");
Serial.println(total);
void onMqttPublish(const uint16_t& packetId) {
Serial.println("Publish acknowledged.");
Serial.begin(57600);
while (!Serial && millis() < 5000)
delay(300);
Serial.print("\nStarting FullyFeature_ESP8266 on ");
Serial.println(ARDUINO_BOARD);
Serial.println(ASYNC_MQTT_GENERIC_VERSION);
wifiConnectHandler = WiFi.onStationModeGotIP(onWifiConnect);
wifiDisconnectHandler = WiFi.onStationModeDisconnected(onWifiDisconnect);
mqttClient.onConnect(onMqttConnect);
mqttClient.onDisconnect(onMqttDisconnect);
mqttClient.onSubscribe(onMqttSubscribe);
mqttClient.onUnsubscribe(onMqttUnsubscribe);
mqttClient.onMessage(onMqttMessage);
mqttClient.onPublish(onMqttPublish);
mqttClient.setServer(MQTT_HOST, MQTT_PORT);
connectToWifi();
