Trouble with SD Card reader and TFT display
Hello all,
I am trying to send a bitmap image from an SD card to an external TFT display using Arduino Uno. Here's the display driver: RA8875 Driver Board for 40-pin TFT Touch Displays - 800x480 Max : ID 1590 : $39.95 : Adafruit Industries, Unique & fun DIY electronics and kits. I followed this guide: Arduino Code | RA8875 Touch Display Driver Board | Adafruit Learning System.
The first example programs run successfully ('buildtest' and 'textmode', as suggested in the guide), so I know that my display is working and wired correctly. However, when I try the 'ra8875_bitmap' example code, the display fails to initialize. Specifically, it reaches line 36 and gets stuck in the while loop:
  /* Initialize the display using 'RA8875_480x80', 'RA8875_480x128', 'RA8875_480x272' or 'RA8875_800x480' */
  if (!tft.begin(RA8875_800x480)) {
    Serial.println("RA8875 Not Found!");
    while (1);
The output from the serial monitor is:
initialization done.
RA8875 start
255
RA8875 Not Found!
When I tried to run the 'buildtest' code again, it failed to run as long as I had the SD card reader connected. Once I disconnected the SD card reader, it ran successfully. So, the SD card reader seems to be disrupting the TFT display somehow.
When I run the 'ra8875_bitmap' code with the SD card reader disconnected, the program fails on line 26 after outputting:
initialization failed!
I can also run the 'ra8875_bitmap' code with no issue if I disconnect the SD card reader and comment out everything related to the SD card reader.
From my understanding, both of these devices use the hardware SPI. I know I can use software SPI (maybe?), but I don't know how to do that. I spotted a line in the Adafruit guide about tri-state something, but I'm not sure what that means. Does anyone have any insight here?
Always post ALL the code. Snippets aren't much help, if the problem (as usual) is in the missing part.
Also post a wiring diagram (photo of a hand drawn diagram is preferred, with all pins and connections clearly labeled). You may have a wiring conflict.
#include <SPI.h>
#include <Wire.h>
#include <SD.h>
#include "Adafruit_RA8875.h"
#include "Adafruit_GFX.h"    // Core graphics library
#include <Adafruit_STMPE610.h>
#define sd_cs 8
// Library only supports hardware SPI at this time
// Connect SCLK to UNO Digital #13 (Hardware SPI clock)
// Connect MISO to UNO Digital #12 (Hardware SPI MISO)
// Connect MOSI to UNO Digital #11 (Hardware SPI MOSI)
#define RA8875_INT 3
#define RA8875_CS 10
#define RA8875_RESET 9
Adafruit_RA8875 tft = Adafruit_RA8875(RA8875_CS, RA8875_RESET);
void setup () {
  if (!SD.begin(sd_cs))
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
  Serial.println("RA8875 start");
    while (1);
  Serial.println("Found RA8875");
  tft.displayOn(true);
  tft.GPIOX(true);      // Enable TFT - display enable tied to GPIOX
  tft.PWM1config(true, RA8875_PWM_CLK_DIV1024); // PWM output for backlight
  tft.PWM1out(255);
  Serial.print("(");
  Serial.print(tft.width());
  Serial.print(", ");
  Serial.print(tft.height());
  Serial.println(")");
  tft.graphicsMode();                 // go back to graphics mode
  tft.fillScreen(RA8875_BLACK);
  tft.graphicsMode();
  bmpDraw("parrot.bmp", 0, 0);
// This function opens a Windows Bitmap (BMP) file and
// displays it at the given coordinates.  It's sped up
// by reading many pixels worth of data at a time
// (rather than pixel by pixel).  Increasing the buffer
// size takes more of the Arduino's precious RAM but
// makes loading a little faster.  20 pixels seems a
// good balance.
#define BUFFPIXEL 20
void bmpDraw(const char *filename, int x, int y) {
  File     bmpFile;
  int      bmpWidth, bmpHeight;   // W+H in pixels
  uint8_t  bmpDepth;              // Bit depth (currently must be 24)
  uint32_t bmpImageoffset;        // Start of image data in file
  uint32_t rowSize;               // Not always = bmpWidth; may have padding
  uint8_t  sdbuffer[3*BUFFPIXEL]; // pixel in buffer (R+G+B per pixel)
  uint16_t lcdbuffer[BUFFPIXEL];  // pixel out buffer (16-bit per pixel)
  uint8_t  buffidx = sizeof(sdbuffer); // Current position in sdbuffer
  boolean  goodBmp = false;       // Set to true on valid header parse
  boolean  flip    = true;        // BMP is stored bottom-to-top
  int      w, h, row, col;
  uint8_t  r, g, b;
  uint32_t pos = 0, startTime = millis();
  uint8_t  lcdidx = 0;
  if((x >= tft.width()) || (y >= tft.height())) return;
  Serial.print(F("Loading image '"));
  Serial.print(filename);
  Serial.println('\'');
  // Open requested file on SD card
  if ((bmpFile = SD.open(filename)) == false) {
    Serial.println(F("File not found"));
    return;
  // Parse BMP header
  if(read16(bmpFile) == 0x4D42) { // BMP signature
    Serial.println(F("File size: "));
    Serial.println(read32(bmpFile));
    (void)read32(bmpFile); // Read & ignore creator bytes
    bmpImageoffset = read32(bmpFile); // Start of image data
    Serial.print(F("Image Offset: "));
    Serial.println(bmpImageoffset, DEC);
    // Read DIB header
    Serial.print(F("Header size: "));
    bmpWidth  = read32(bmpFile);
    bmpHeight = read32(bmpFile);
    if(read16(bmpFile) == 1) { // # planes -- must be '1'
      bmpDepth = read16(bmpFile); // bits per pixel
      Serial.print(F("Bit Depth: "));
      Serial.println(bmpDepth);
      if((bmpDepth == 24) && (read32(bmpFile) == 0)) { // 0 = uncompressed
        goodBmp = true; // Supported BMP format -- proceed!
        Serial.print(F("Image size: "));
        Serial.print(bmpWidth);
        Serial.print('x');
        Serial.println(bmpHeight);
        // BMP rows are padded (if needed) to 4-byte boundary
        rowSize = (bmpWidth * 3 + 3) & ~3;
        // If bmpHeight is negative, image is in top-down order.
        // This is not canon but has been observed in the wild.
        if(bmpHeight < 0) {
          bmpHeight = -bmpHeight;
          flip      = false;
        // Crop area to be loaded
        w = bmpWidth;
        h = bmpHeight;
        if((x+w-1) >= tft.width())  w = tft.width()  - x;
        if((y+h-1) >= tft.height()) h = tft.height() - y;
        // Set TFT address window to clipped image bounds
        for (row=0; row<h; row++) { // For each scanline...
          // Seek to start of scan line.  It might seem labor-
          // intensive to be doing this on every line, but this
          // method covers a lot of gritty details like cropping
          // and scanline padding.  Also, the seek only takes
          // place if the file position actually needs to change
          // (avoids a lot of cluster math in SD library).
          if(flip) // Bitmap is stored bottom-to-top order (normal BMP)
            pos = bmpImageoffset + (bmpHeight - 1 - row) * rowSize;
          else     // Bitmap is stored top-to-bottom
          pos = bmpImageoffset + row * rowSize;
          if(bmpFile.position() != pos) { // Need seek?
            bmpFile.seek(pos);
            buffidx = sizeof(sdbuffer); // Force buffer reload
          for (col=0; col<w; col++) { // For each column...
            // Time to read more pixel data?
            if (buffidx >= sizeof(sdbuffer)) { // Indeed
              // Push LCD buffer to the display first
              if(lcdidx > 0) {
                tft.drawPixel(col+x, row+y, lcdbuffer[lcdidx]);
                lcdidx = 0;
              bmpFile.read(sdbuffer, sizeof(sdbuffer));
              buffidx = 0; // Set index to beginning
            // Convert pixel from BMP to TFT format
            b = sdbuffer[buffidx++];
            g = sdbuffer[buffidx++];
            r = sdbuffer[buffidx++];
            lcdbuffer[lcdidx] = color565(r,g,b);
          } // end pixel
        } // end scanline
        // Write any remaining data to LCD
        if(lcdidx > 0) {
        Serial.print(F("Loaded in "));
        Serial.print(millis() - startTime);
        Serial.println(" ms");
      } // end goodBmp
  bmpFile.close();
  if(!goodBmp) Serial.println(F("BMP format not recognized."));
// These read 16- and 32-bit types from the SD card file.
// BMP data is stored little-endian, Arduino is little-endian too.
// May need to reverse subscript order if porting elsewhere.
uint16_t read16(File f) {
  uint16_t result;
  ((uint8_t *)&result)[0] = f.read(); // LSB
  ((uint8_t *)&result)[1] = f.read(); // MSB
  return result;
uint32_t read32(File f) {
  uint32_t result;
  ((uint8_t *)&result)[2] = f.read();
  ((uint8_t *)&result)[3] = f.read(); // MSB
  return result;
uint16_t color565(uint8_t r, uint8_t g, uint8_t b) {
  return ((r & 0xF8) << 8) | ((g & 0xFC) << 3) | (b >> 3);
byte decToBcd(byte val){
  // Convert normal decimal numbers to binary coded decimal
  return ( (val/10*16) + (val%10) );
No obvious conflicts with the wiring.
You may be running out of memory. The SD card takes 1/4 of it, TFT displays can take another 1/2, etc.
Check whether that display requires a memory buffer on an Uno, and how large it is.
Edit: This is the problem, prominently announced on the Adafruit product page.
Please note! The RA8875 does not tri-state the MISO pin, it should not share that pin with any other SPI device (including an SD card reader) without the use of a 74HC125 or similar
