Trouble with Software Serial on ATTiny85
Hello all,
I've been wrestling with a problem for a few weeks now and have come to a point where I don't know what to try next.
Long story short, I'm trying to smoothly control an WS2812 RGB LED through an ATTiny85 with an HC-06 bluetooth module using the Bluetooth Color Picker Android app.
The data output from the app is in the format "#:R,G,B"
Example:
0:200,0,0
0:199,0,0
0:198,0,0
etc
When inputting these commands manually in a terminal, they work fine, but the bluetooth color picker app sends the commands much faster and they don't register...maybe?
The problem I'm having is that I can't reliably detect the end of line character on the ATTiny85 using Software Serial, but the same code (using hardware serial instead) works perfectly fine on my Arduino MEGA.
#define PIN            2
#define NUMPIXELS      2
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
//#include <SoftwareSerial.h>
//SoftwareSerial mySerial(4,3); // (RX,TX) Sets physical pin 2 as TX and physical pin 4 as RX
  Serial.println("Software Serial On");
  pixels.begin(); //Initializes NeoPixel library
  //if some data is sent
  while(Serial.available() > 0){
    //Parse serial data into integers, separated by non-digit characters
    int pixel = Serial.parseInt();
    int red = Serial.parseInt();
    int green = Serial.parseInt();
    int blue = Serial.parseInt();
    //WORKS on MEGA but not ATTiny85. Software Serial vs Serial?
    if (Serial.read() == '\n'){ //if end of line seen (doesn't work all the time)
      pixels.setPixelColor(pixel, pixels.Color(red,green,blue)); // Should change color with app control
      pixels.show(); // This sends the updated pixel color to the hardware.
This code works perfectly on my MEGA, but changing everything to SoftwareSerial and trying it on my ATTiny85 does not work.
Any advice here would be GREATLY appreciated as I really have no idea what to try next.
Edit: I'm running the ATTiny85 at 8MHz, which I believe is necessary for SoftwareSerial.
Thank you,
Mike
