I am fairly new to Arduino and I am currently trying to get a stepper motor that I found to spin. I am using a Darlington Array (ULN2004A) and the code supplied in the example on the Arduino web site. The motor will shake a bit and the chip heats up very quickly. Not sure what I am doing wrong. Any advice would be greatly appreciated. Thanks!
* MotorKnob
* A stepper motor follows the turns of a potentiometer
* (or other sensor) on analog input 0.
* http://www.arduino.cc/en/Reference/Stepper
* This example code is in the public domain.
#include <Stepper.h>
// change this to the number of steps on your motor
#define STEPS 200
// create an instance of the stepper class, specifying
// the number of steps of the motor and the pins it's
// attached to
Stepper stepper(STEPS, 2, 3, 4, 5);
// the previous reading from the analog input
int previous = 0;
// set the speed of the motor to 30 RPMs
stepper.setSpeed(30);
// get the sensor value
int val = analogRead(0);
// move a number of steps equal to the change in the
// sensor reading
stepper.step(100);
// remember the previous value of the sensor
previous = val;
You need to provide a link to the datasheet for your stepper motor. I wonder if the motor requires more current than that chip can provide.
A photo of a pencil drawing of the wiring connections would be easier to follow than a photo of the hardware - though I must say your hardware is 100 times neater than mine would be.
This is a link to the manufacturers website. I haven't been able to find a datasheet and they don't have the exact model number listed but it looks like it should be between .4 and .5 amps.
Here is a representation of the way the hardware is stet up.
I also noticed that I had my pins labeled backward in the code...but it still didn't fix it.
* MotorKnob
#define STEPS 200
// attached to
Stepper stepper(STEPS, 5, 4, 3, 2);
int previous = 0;
// sensor reading
stepper.step(100);
previous = val;
Darlington drivers always get hot, they are woeful performers. But there's hot
and there's HOT(*).
IIRC those chips are rated for 0.5A max per pin, but a total of about 1A for all the pins.
(*) Many semiconductor devices will function upto a die temperature of 125 to 150C,
but that means the package will burn your fingers badly. Reliability is reduced too.
Aim for 50C as a practical maximum if you can. Datasheets often give a guide
as to the temperature rise per watt for various packages.
The model of the stepper is 17HD2002-03N (Moons'). The Arduino is being powered by the USB and the 9V powers only the stepper.
On the manufacturers web site the list the other similar models rated at .4 or .5 amps. It was just a guess that the one I have would be the same. It has been very difficult to find information on this particular model. I have emailed them requesting a data sheet...but we will see if they respond.
As I mentioned earlier those 9v batteries are useless for motors.
Also I suspect you need a much higher voltage. Looking at the 17HD1004-01 motor with a coil resistance of 25 ohms - that would require 12.5 volts to get the rated current of 0.5amps
I reckon you should be using a specialized stepper motor driver and maybe a 24v supply as explained in stepper motor basics.
Coltonchristensen1:
No, you cannot make that assumption, the same motor frame is nearly always available with
different winding configurations, you need to match the full motor part number to the relevent
datasheet / catalog to see what the winding is (or much more easily measure it).
Robin2:
Have you a link to your source? I could not find the data.
...R
Hi.
Neither I.
Google lies to me
I was searching for a Teco 4H4018X0701.
And at same time for this user ones.
The search was for "17HD2002" the result link to some pdf with 17HC2002 spec.
Just realized now, when searching for this pdf again:
arssant:
More like this one.. only 03N to 02N change.. revision for sure.
No, that part number difference could mean:
different shaft length or diameter or mechanical detail
different winding option (hence different current / resistance)
presence / absence of rear shaft for an encoder
different environmental rating (how water/dust proof).
Motors are not software, they seldom have revisions.
We need to know the winding resistance to judge what the
windings are, simple...
[ PS page 9 of that datasheet claims the last 2 digits are
mechanical variation, so perhaps we are talking a 2.3A
motor which explains the complete failure of a ULN2004! ]
Coltonchristensen1:
Look the winding resistance is something you canjust measure with a multimeter, the
power is the same for all motors of the same frame since its a thermal limit, so its
easy to get a good estimate of the current rating from these data.
I officially have to admit defeat with these stepper motors. I just received my Adafruit motor shield, hooked it up to a 12v bank of AA batteries and i get the same result. It looks like the steppers just take more power than my current hardware can dish up. They are too big for the project i want to build anyway...it was just one of those things were i was fixated on making them work, just because i have them :-).
