Troubleshooting Code Compatibility Between Uno and Mega 2560
Hi everyone,
I just tried to run the code below on my Mega 2560. The exact same code, using the same digital pins, works on my Uno but is not working on my Mega!!!
How can I fix this problem?
Many, many thanks, and have a lovely day!
Many thanks, and have a lovely day!
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1331.h>
#include <SPI.h>
// You can use any (4 or) 5 pins
#define sclk 13
#define mosi 11
#define cs   10
#define rst  9
#define dc   8
// Color definitions
#define	BLACK           0x0000
#define	BLUE            0x001F
#define	RED             0xF800
#define	GREEN           0x07E0
#define CYAN            0x07FF
#define MAGENTA         0xF81F
#define YELLOW          0xFFE0
#define WHITE           0xFFFF
// Option 1: use any pins but a little slower
//Adafruit_SSD1331 display = Adafruit_SSD1331(cs, dc, mosi, sclk, rst);
// Option 2: must use the hardware SPI pins
// (for UNO thats sclk = 13 and sid = 11) and pin 10 must be
// an output. This is much faster - also required if you want
// to use the microSD card (see the image drawing example)
Adafruit_SSD1331 display = Adafruit_SSD1331(&SPI, cs, dc, rst);
float p = 3.1415926;
void setup(void) {
  Serial.print("hello!");
  display.begin();
  Serial.println("init");
  uint16_t time = millis();
  display.fillScreen(BLACK);
  time = millis() - time;
  Serial.println(time, DEC);
  lcdTestPattern();
  display.setCursor(0,0);
  display.print("Lorem ipsum dolor sit amet, consectetur adipiscing elit. Curabitur adipiscing ante sed nibh tincidunt feugiat. Maecenas enim massa");
  // tft print function!
  tftPrintTest();
  delay(2000);
  //a single pixel
  display.drawPixel(display.width()/2, display.height()/2, GREEN);
  // line draw test
  testlines(YELLOW);
  // optimized lines
  testfastlines(RED, BLUE);
  testdrawrects(GREEN);
  testfillrects(YELLOW, MAGENTA);
  testfillcircles(10, BLUE);
  testdrawcircles(10, WHITE);
  testroundrects();
  testtriangles();
  Serial.println("done");
void testlines(uint16_t color) {
void testdrawtext(char *text, uint16_t color) {
void testfastlines(uint16_t color1, uint16_t color2) {
void testdrawrects(uint16_t color) {
 for (int16_t x=0; x < display.height()-1; x+=6) {
   display.drawRect((display.width()-1)/2 -x/2, (display.height()-1)/2 -x/2 , x, x, color);
void testfillrects(uint16_t color1, uint16_t color2) {
 for (int16_t x=display.height()-1; x > 6; x-=6) {
   display.fillRect((display.width()-1)/2 -x/2, (display.height()-1)/2 -x/2 , x, x, color1);
   display.drawRect((display.width()-1)/2 -x/2, (display.height()-1)/2 -x/2 , x, x, color2);
void testfillcircles(uint8_t radius, uint16_t color) {
  for (uint8_t x=radius; x < display.width()-1; x+=radius*2) {
    for (uint8_t y=radius; y < display.height()-1; y+=radius*2) {
      display.fillCircle(x, y, radius, color);
void testdrawcircles(uint8_t radius, uint16_t color) {
  for (int16_t x=0; x < display.width()-1+radius; x+=radius*2) {
    for (int16_t y=0; y < display.height()-1+radius; y+=radius*2) {
      display.drawCircle(x, y, radius, color);
void testtriangles() {
  int color = 0xF800;
  int t;
  int w = display.width()/2;
  int x = display.height();
  int y = 0;
  int z = display.width();
  for (t = 0 ; t <= 15; t+=1) {
    display.drawTriangle(w, y, y, x, z, x, color);
    x-=4;
    y+=4;
    z-=4;
    color+=100;
void testroundrects() {
  int color = 100;
  int i;
  int t;
  for(t = 0 ; t <= 4; t+=1) {
    int x = 0;
    int y = 0;
    int w = display.width();
    int h = display.height();
    for(i = 0 ; i <= 8; i+=1) {
      display.drawRoundRect(x, y, w, h, 5, color);
      x+=2;
      y+=3;
      w-=4;
      h-=6;
      color+=1100;
    color+=100;
void tftPrintTest() {
  display.setCursor(0, 5);
  display.setTextColor(RED);
  display.setTextSize(1);
  display.println("Hello World!");
  display.setTextColor(YELLOW, GREEN);
  display.setTextSize(2);
  display.print("Hello Wo");
  display.setTextColor(BLUE);
  display.setTextSize(3);
  display.print(1234.567);
  delay(1500);
  display.setTextColor(WHITE);
  display.setTextSize(0);
  display.setTextColor(GREEN);
  display.print(p, 5);
  display.println(" Want pi?");
  display.print(8675309, HEX); // print 8,675,309 out in HEX!
  display.print(" Print HEX");
  display.println("Sketch has been");
  display.println("running for: ");
  display.setTextColor(MAGENTA);
  display.print(millis() / 1000);
  display.print(" seconds.");
void mediabuttons() {
 // play
  display.fillRoundRect(25, 10, 78, 60, 8, WHITE);
  display.fillTriangle(42, 20, 42, 60, 90, 40, RED);
  // pause
  display.fillRoundRect(25, 90, 78, 60, 8, WHITE);
  display.fillRoundRect(39, 98, 20, 45, 5, GREEN);
  display.fillRoundRect(69, 98, 20, 45, 5, GREEN);
  // play color
  display.fillTriangle(42, 20, 42, 60, 90, 40, BLUE);
  delay(50);
  // pause color
  display.fillRoundRect(39, 98, 20, 45, 5, RED);
  display.fillRoundRect(69, 98, 20, 45, 5, RED);
  // play color
  display.fillTriangle(42, 20, 42, 60, 90, 40, GREEN);
    @brief  Renders a simple test pattern on the LCD
void lcdTestPattern(void)
  uint8_t w,h;
  display.setAddrWindow(0, 0, 96, 64);
  for (h = 0; h < 64; h++) {
    for (w = 0; w < 96; w++) {
      if (w > 83) {
        display.writePixel(w, h, WHITE);
      } else if (w > 71) {
        display.writePixel(w, h, BLUE);
      } else if (w > 59) {
        display.writePixel(w, h, GREEN);
      } else if (w > 47) {
        display.writePixel(w, h, CYAN);
      } else if (w > 35) {
        display.writePixel(w, h, RED);
      } else if (w > 23) {
        display.writePixel(w, h, MAGENTA);
      } else if (w > 11) {
        display.writePixel(w, h, YELLOW);
        display.writePixel(w, h, BLACK);
  display.endWrite();
The Arduino Mega has the SPI bus on other pins.
Because in spite of these defines:
#define sclk 13
#define mosi 11
#define cs   10
#define rst  9
#define dc   8
Your code never actually uses sclk or mosi. What it does use is SPI
which directs the library to use the hardware SPI pins. Which on an UNO are indeed 13 for SCLK and 11 for MOSI. But on a Mega they're somewhere else. I'll leave you to look up a pinout diagram for the Mega to discover for yourself exactly where they are.
yeah - well let's document it for future readers...
Arduino UNO:
  • SPI Pins:
    • MOSI (Master Out Slave In): Pin 11
    • MISO (Master In Slave Out): Pin 12
    • SCK (Serial Clock): Pin 13
    • SS (Slave Select, also called Chip Select): Pin 10
Arduino Mega:
  • SPI Pins:
    • MOSI (Master Out Slave In): Pin 51
    • MISO (Master In Slave Out): Pin 50
    • SCK (Serial Clock): Pin 52
    • SS (Slave Select, also called Chip Select): Pins 53 (for the master)
EDIT: @Delta_G was faster :slight_smile:
Many thanks,
Are there any other pins available for MOSI, MISO, and SCK? I'm already using them for the RFID-RC522. Can I connect both of them to the same pin?
Best regards,
SPI is a bus - yes you can connect them in parallel, but you'll need a separate CS for each device.
Many, many thanks,
I just looked into the Mega pinouts, and what I found is that only pin 53 was designated as CS. Is there any other pin that I can use? I have two devices in total, a chip reader, and a display.
Best regards :slight_smile:
In general, as long as the library you're using allows you to specify a CS pin assignment, you can use any pin you like.
Those are also wired to the ICSP header for the atmega2560.
Many many thanks,
it works :smiley:
