I am trying to connect a seeduino lotus (https://www.seeedstudio.com/Seeeduino-Lotus-ATMega328-Board-with-Grove-Interface-p-1942.html) board to the Arduino IDE but I keep getting this error message:
Arduino: 1.8.12 (Windows Store 1.8.33.0) (Windows 10), Board: "Arduino Duemilanove or Diecimila, ATmega328P"
Sketch uses 4280 bytes (13%) of program storage space. Maximum is 30720 bytes.
Global variables use 233 bytes (11%) of dynamic memory, leaving 1815 bytes for local variables. Maximum is 2048 bytes.
C:\Users\tinaa\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\tinaa\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b57600 -D -Uflash:w:C:\Users\tinaa\AppData\Local\Temp\arduino_build_881287/Grove_EMG_detector_demo_code.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\tinaa\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
Invalid library found in C:\Users\tinaa\Documents\Arduino\libraries\LED_Bar.h: no headers files (.h) found in C:\Users\tinaa\Documents\Arduino\libraries\LED_Bar.h
option enabled in File -> Preferences.
I have the board set up according to this starter website Getting Started with Seeeduino | Seeed Studio Wiki
I am using code I downloaded form github and I'm trying to follow this process Grove - EMG Detector | Seeed Studio Wiki
