Upload fails: "avrdude: stk500_recv(): programmer is not responding"
Arduino: 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Board: "Arduino Uno"
Sketch uses 6352 bytes (19%) of program storage space. Maximum is 32256 bytes.
Global variables use 278 bytes (13%) of dynamic memory, leaving 1770 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avrdude -CC:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\Tudor11\AppData\Local\Temp\arduino_build_952069/6.2_Arduino_UNO.ino.hex:i
avrdude: Version 6.3-20190619
     Copyright (c) 2007-2014 Joerg Wunsch
     System wide configuration file is "C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf"
     Using Port                    : COM3
     Using Programmer              : arduino
     Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x91
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x91
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x91
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x91
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x91
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x91
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x91
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x91
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x91
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x91
avrdude done. Thank you.
Problem uploading to board. See https://support.arduino.cc/hc/en-us/sections/360003198300 for suggestions.
option enabled in File -> Preferences.
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\Tudor11\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0000_0000 -ide-version=10819 -build-path C:\Users\Tudor11\AppData\Local\Temp\arduino_build_952069 -warnings=none -build-cache C:\Users\Tudor11\AppData\Local\Temp\arduino_cache_616807 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr -verbose C:\Users\Tudor11\Downloads\ZYC0076-EN\ZYC0076-EN\2_Arduino_Code\6.2_Arduino_UNO\6.2_Arduino_UNO.ino
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\arduino-builder -compile -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\Tudor11\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0000_0000 -ide-version=10819 -build-path C:\Users\Tudor11\AppData\Local\Temp\arduino_build_952069 -warnings=none -build-cache C:\Users\Tudor11\AppData\Local\Temp\arduino_cache_616807 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr -verbose C:\Users\Tudor11\Downloads\ZYC0076-EN\ZYC0076-EN\2_Arduino_Code\6.2_Arduino_UNO\6.2_Arduino_UNO.ino
Using board 'uno' from platform in folder: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\arduino\avr
Detecting libraries used...
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\Tudor11\\AppData\\Local\\Temp\\arduino_build_952069\\sketch\\6.2_Arduino_UNO.ino.cpp" -o nul
Alternatives for Servo.h: [Servo@1.1.8]
ResolveLibrary(Servo.h)
  -> candidates: [Servo@1.1.8]
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\\libraries\\Servo\\src" "C:\\Users\\Tudor11\\AppData\\Local\\Temp\\arduino_build_952069\\sketch\\6.2_Arduino_UNO.ino.cpp" -o nul
Using cached library dependencies for file: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\libraries\Servo\src\avr\Servo.cpp
Using cached library dependencies for file: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\libraries\Servo\src\mbed\Servo.cpp
Using cached library dependencies for file: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\libraries\Servo\src\megaavr\Servo.cpp
Using cached library dependencies for file: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\libraries\Servo\src\nrf52\Servo.cpp
Using cached library dependencies for file: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\libraries\Servo\src\sam\Servo.cpp
Using cached library dependencies for file: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\libraries\Servo\src\samd\Servo.cpp
Using cached library dependencies for file: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\libraries\Servo\src\stm32f4\Servo.cpp
Generating function prototypes...
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\\libraries\\Servo\\src" "C:\\Users\\Tudor11\\AppData\\Local\\Temp\\arduino_build_952069\\sketch\\6.2_Arduino_UNO.ino.cpp" -o "C:\\Users\\Tudor11\\AppData\\Local\\Temp\\arduino_build_952069\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Tudor11\\AppData\\Local\\Temp\\arduino_build_952069\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\\libraries\\Servo\\src" "C:\\Users\\Tudor11\\AppData\\Local\\Temp\\arduino_build_952069\\sketch\\6.2_Arduino_UNO.ino.cpp" -o "C:\\Users\\Tudor11\\AppData\\Local\\Temp\\arduino_build_952069\\sketch\\6.2_Arduino_UNO.ino.cpp.o"
Compiling libraries...
Compiling library "Servo"
Using previously compiled file: C:\Users\Tudor11\AppData\Local\Temp\arduino_build_952069\libraries\Servo\avr\Servo.cpp.o
Using previously compiled file: C:\Users\Tudor11\AppData\Local\Temp\arduino_build_952069\libraries\Servo\mbed\Servo.cpp.o
Using previously compiled file: C:\Users\Tudor11\AppData\Local\Temp\arduino_build_952069\libraries\Servo\megaavr\Servo.cpp.o
Using previously compiled file: C:\Users\Tudor11\AppData\Local\Temp\arduino_build_952069\libraries\Servo\nrf52\Servo.cpp.o
Using previously compiled file: C:\Users\Tudor11\AppData\Local\Temp\arduino_build_952069\libraries\Servo\sam\Servo.cpp.o
Using previously compiled file: C:\Users\Tudor11\AppData\Local\Temp\arduino_build_952069\libraries\Servo\samd\Servo.cpp.o
Using previously compiled file: C:\Users\Tudor11\AppData\Local\Temp\arduino_build_952069\libraries\Servo\stm32f4\Servo.cpp.o
Compiling core...
Using precompiled core: C:\Users\Tudor11\AppData\Local\Temp\arduino_cache_616807\core\core_arduino_avr_uno_7badb9d0d399766d9f906b5fb78ea16e.a
Linking everything together...
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\Tudor11\\AppData\\Local\\Temp\\arduino_build_952069/6.2_Arduino_UNO.ino.elf" "C:\\Users\\Tudor11\\AppData\\Local\\Temp\\arduino_build_952069\\sketch\\6.2_Arduino_UNO.ino.cpp.o" "C:\\Users\\Tudor11\\AppData\\Local\\Temp\\arduino_build_952069\\libraries\\Servo\\avr\\Servo.cpp.o" "C:\\Users\\Tudor11\\AppData\\Local\\Temp\\arduino_build_952069\\libraries\\Servo\\mbed\\Servo.cpp.o" "C:\\Users\\Tudor11\\AppData\\Local\\Temp\\arduino_build_952069\\libraries\\Servo\\megaavr\\Servo.cpp.o" "C:\\Users\\Tudor11\\AppData\\Local\\Temp\\arduino_build_952069\\libraries\\Servo\\nrf52\\Servo.cpp.o" "C:\\Users\\Tudor11\\AppData\\Local\\Temp\\arduino_build_952069\\libraries\\Servo\\sam\\Servo.cpp.o" "C:\\Users\\Tudor11\\AppData\\Local\\Temp\\arduino_build_952069\\libraries\\Servo\\samd\\Servo.cpp.o" "C:\\Users\\Tudor11\\AppData\\Local\\Temp\\arduino_build_952069\\libraries\\Servo\\stm32f4\\Servo.cpp.o" "C:\\Users\\Tudor11\\AppData\\Local\\Temp\\arduino_build_952069/..\\arduino_cache_616807\\core\\core_arduino_avr_uno_7badb9d0d399766d9f906b5fb78ea16e.a" "-LC:\\Users\\Tudor11\\AppData\\Local\\Temp\\arduino_build_952069" -lm
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\Tudor11\\AppData\\Local\\Temp\\arduino_build_952069/6.2_Arduino_UNO.ino.elf" "C:\\Users\\Tudor11\\AppData\\Local\\Temp\\arduino_build_952069/6.2_Arduino_UNO.ino.eep"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\Tudor11\\AppData\\Local\\Temp\\arduino_build_952069/6.2_Arduino_UNO.ino.elf" "C:\\Users\\Tudor11\\AppData\\Local\\Temp\\arduino_build_952069/6.2_Arduino_UNO.ino.hex"
Using library Servo at version 1.1.8 in folder: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\libraries\Servo
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-size" -A "C:\\Users\\Tudor11\\AppData\\Local\\Temp\\arduino_build_952069/6.2_Arduino_UNO.ino.elf"
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xfe
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xfe
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xfe
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xfe
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xfe
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xfe
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xfe
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xfe
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xfe
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xfe
         Using Port                    : COM3
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x1f
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x1f
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x1f
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x1f
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x1f
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x1f
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x1f
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x1f
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x1f
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x1f
Hi @tudorb_20cj. Please add a reply here on this forum thread to tell us which Arduino board you are using.
Please be as specific as possible as some Arduino boards with similar names have significant differences and the forum helpers can only provide effective assistance if we are aware of which one is being used.
If you aren't sure how to describe which board you are using, you can provide the link to the online product listing you bought the board from and we'll proceed based on the information found there.
I managed to install it by changing from COM 3 to COM 6. Thank you for your prompt answer. I just bought it and I am learning myself too how to install the software and so on.
Congratulations on finding a solution! I'm glad it is working now. Thank you for taking the time to post an update.
