Hi, I am trying to control ESP32CAM's I/O pins and also getting view from camera.
For this purpose, I tried to edit CameraWebServer example like this:
#include "esp_camera.h"
#include <WiFi.h>
// WARNING!!! PSRAM IC required for UXGA resolution and high JPEG quality
// Ensure ESP32 Wrover Module or other board with PSRAM is selected
// Partial images will be transmitted if image exceeds buffer size
// Select camera model
//#define CAMERA_MODEL_WROVER_KIT // Has PSRAM
//#define CAMERA_MODEL_ESP_EYE // Has PSRAM
//#define CAMERA_MODEL_M5STACK_PSRAM // Has PSRAM
//#define CAMERA_MODEL_M5STACK_V2_PSRAM // M5Camera version B Has PSRAM
//#define CAMERA_MODEL_M5STACK_WIDE // Has PSRAM
//#define CAMERA_MODEL_M5STACK_ESP32CAM // No PSRAM
#define CAMERA_MODEL_AI_THINKER // Has PSRAM
//#define CAMERA_MODEL_TTGO_T_JOURNAL // No PSRAM
#include "camera_pins.h"
WiFiServer espServer(81);
String request;
const char* ssid = "VODAFONE_9D53";
const char* password = "fc1f1fff";
void startCameraServer();
Serial.setDebugOutput(true);
pinMode(12, OUTPUT);
pinMode(13, OUTPUT);
digitalWrite(4, LOW);
camera_config_t config;
config.ledc_channel = LEDC_CHANNEL_0;
config.ledc_timer = LEDC_TIMER_0;
config.pin_d0 = Y2_GPIO_NUM;
config.pin_d1 = Y3_GPIO_NUM;
config.pin_d2 = Y4_GPIO_NUM;
config.pin_d3 = Y5_GPIO_NUM;
config.pin_d4 = Y6_GPIO_NUM;
config.pin_d5 = Y7_GPIO_NUM;
config.pin_d6 = Y8_GPIO_NUM;
config.pin_d7 = Y9_GPIO_NUM;
config.pin_xclk = XCLK_GPIO_NUM;
config.pin_pclk = PCLK_GPIO_NUM;
config.pin_vsync = VSYNC_GPIO_NUM;
config.pin_href = HREF_GPIO_NUM;
config.pin_sscb_sda = SIOD_GPIO_NUM;
config.pin_sscb_scl = SIOC_GPIO_NUM;
config.pin_pwdn = PWDN_GPIO_NUM;
config.pin_reset = RESET_GPIO_NUM;
config.xclk_freq_hz = 20000000;
config.pixel_format = PIXFORMAT_JPEG;
// if PSRAM IC present, init with UXGA resolution and higher JPEG quality
// for larger pre-allocated frame buffer.
if(psramFound()){
config.frame_size = FRAMESIZE_UXGA;
config.jpeg_quality = 10;
config.fb_count = 2;
config.frame_size = FRAMESIZE_SVGA;
config.jpeg_quality = 12;
config.fb_count = 1;
#if defined(CAMERA_MODEL_ESP_EYE)
pinMode(13, INPUT_PULLUP);
pinMode(14, INPUT_PULLUP);
#endif
// camera init
esp_err_t err = esp_camera_init(&config);
if (err != ESP_OK) {
Serial.printf("Camera init failed with error 0x%x", err);
return;
sensor_t * s = esp_camera_sensor_get();
// initial sensors are flipped vertically and colors are a bit saturated
if (s->id.PID == OV3660_PID) {
s->set_vflip(s, 1); // flip it back
s->set_brightness(s, 1); // up the brightness just a bit
s->set_saturation(s, -2); // lower the saturation
// drop down frame size for higher initial frame rate
s->set_framesize(s, FRAMESIZE_QVGA);
#if defined(CAMERA_MODEL_M5STACK_WIDE) || defined(CAMERA_MODEL_M5STACK_ESP32CAM)
s->set_vflip(s, 1);
s->set_hmirror(s, 1);
#endif
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.print("Camera Ready! Use 'http://");
Serial.print(WiFi.localIP());
Serial.println("' to connect");
delay(2000);
espServer.begin();
WiFiClient client = espServer.available(); /* Check if a client is available */
if(!client)
return;
Serial.println("New Client!!!");
boolean currentLineIsBlank = true;
while (client.connected())
if (client.available())
char c = client.read();
request += c;
Serial.write(c);
if (c == '\n' && currentLineIsBlank)
if (request.indexOf("/GPIO12ON") != -1)
Serial.println("GPIO12 LED is ON");
digitalWrite(12, HIGH);
Serial.printf("12 HIGH");
if (request.indexOf("/GPIO12OFF") != -1)
Serial.println("GPIO12 LED is OFF");
digitalWrite(12, LOW);
Serial.printf("12 LOW");
if (request.indexOf("/GPIO13ON") != -1)
Serial.println("GPIO13 LED is ON");
digitalWrite(13, HIGH);
Serial.printf("13 HIGH");
if (request.indexOf("/GPIO13OFF") != -1)
Serial.println("GPIO13 LED is OFF");
digitalWrite(13, LOW);
Serial.printf("13 LOW");
client.println("Content-Type: text/html");
client.println("Connection: close");
client.println(); // IMPORTANT
if(c == '\n')
else if(c != '\r')
currentLineIsBlank = false;
//client.print("\n");
delay(1);
request = "";
//client.flush();
client.stop();
Serial.println("Client disconnected");
Serial.print("\n");
I did 81 port because i want to use camera and I/O control on ngrok. (I can only open 1 port on ngrok, stream URL is already on 81 port so i tried to move I/O control part to 81 port)
I can control I/O pins but i cant use camera on xxx.xxx.x.xx:81/stream URL. Can you help me ?
