Hi all,
I am using a AI-Thinker ESP32-cam module with Arduino IDE ver 1.8.2. and the ESP32/Camera/CameraWebServer example. The code is using 4 tabs, the main tab looks like this:
#include "esp_camera.h"
#include <WiFi.h>
// WARNING!!! PSRAM IC required for UXGA resolution and high JPEG quality
// Ensure ESP32 Wrover Module or other board with PSRAM is selected
// Partial images will be transmitted if image exceeds buffer size
// Select camera model
#define CAMERA_MODEL_WROVER_KIT // Has PSRAM
//#define CAMERA_MODEL_ESP_EYE // Has PSRAM
//#define CAMERA_MODEL_M5STACK_PSRAM // Has PSRAM
//#define CAMERA_MODEL_M5STACK_V2_PSRAM // M5Camera version B Has PSRAM
//#define CAMERA_MODEL_M5STACK_WIDE // Has PSRAM
//#define CAMERA_MODEL_M5STACK_ESP32CAM // No PSRAM
//#define CAMERA_MODEL_AI_THINKER // Has PSRAM
//#define CAMERA_MODEL_TTGO_T_JOURNAL // No PSRAM
#include "camera_pins.h"
const char* ssid = "*********";
const char* password = "*********";
void startCameraServer();
Serial.setDebugOutput(true);
camera_config_t config;
config.ledc_channel = LEDC_CHANNEL_0;
config.ledc_timer = LEDC_TIMER_0;
config.pin_d0 = Y2_GPIO_NUM;
config.pin_d1 = Y3_GPIO_NUM;
config.pin_d2 = Y4_GPIO_NUM;
config.pin_d3 = Y5_GPIO_NUM;
config.pin_d4 = Y6_GPIO_NUM;
config.pin_d5 = Y7_GPIO_NUM;
config.pin_d6 = Y8_GPIO_NUM;
config.pin_d7 = Y9_GPIO_NUM;
config.pin_xclk = XCLK_GPIO_NUM;
config.pin_pclk = PCLK_GPIO_NUM;
config.pin_vsync = VSYNC_GPIO_NUM;
config.pin_href = HREF_GPIO_NUM;
config.pin_sscb_sda = SIOD_GPIO_NUM;
config.pin_sscb_scl = SIOC_GPIO_NUM;
config.pin_pwdn = PWDN_GPIO_NUM;
config.pin_reset = RESET_GPIO_NUM;
config.xclk_freq_hz = 20000000;
config.pixel_format = PIXFORMAT_JPEG;
// if PSRAM IC present, init with UXGA resolution and higher JPEG quality
// for larger pre-allocated frame buffer.
if(psramFound()){
config.frame_size = FRAMESIZE_UXGA;
config.jpeg_quality = 10;
config.fb_count = 2;
config.frame_size = FRAMESIZE_SVGA;
config.jpeg_quality = 12;
config.fb_count = 1;
#if defined(CAMERA_MODEL_ESP_EYE)
pinMode(13, INPUT_PULLUP);
pinMode(14, INPUT_PULLUP);
#endif
// camera init
esp_err_t err = esp_camera_init(&config);
if (err != ESP_OK) {
Serial.printf("Camera init failed with error 0x%x", err);
return;
sensor_t * s = esp_camera_sensor_get();
// initial sensors are flipped vertically and colors are a bit saturated
if (s->id.PID == OV3660_PID) {
s->set_vflip(s, 1); // flip it back
s->set_brightness(s, 1); // up the brightness just a bit
s->set_saturation(s, -2); // lower the saturation
// drop down frame size for higher initial frame rate
s->set_framesize(s, FRAMESIZE_QVGA);
#if defined(CAMERA_MODEL_M5STACK_WIDE) || defined(CAMERA_MODEL_M5STACK_ESP32CAM)
s->set_vflip(s, 1);
s->set_hmirror(s, 1);
#endif
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.print("Camera Ready! Use 'http://");
Serial.print(WiFi.localIP());
Serial.println("' to connect");
delay(10000);
}`Preformatted text`
It runs without any issues, so now I am planning for my next step to make some use of this.
I have already experimented a bit and added sleep mode and wake it up via a "HC12" 433 Mhz RF module that also provides one byte of command code to the ESP. Commands can be 1) "Snap a picture w/o turning wifi on, and save it to Littlefs, then go back to sleep" or 2) "Turn on wifi and the web server", so I can use the CameraWebServer user interface. This also works fine without issues.
The second tab ("app_httpd.cpp") contains the command that executes the camera and loads the image data to the "fb" frame buffer: fb = esp_camera_fb_get(); and that is what I am using for the remote controlled "Snap a picture..." command.
I save the picture like this:
void LITTLEFS_save() {
Serial.println("Saving to LITTLEFS: photo_0.jpg");
File file = LITTLEFS.open("/photo_0.jpg", "w"); // only latest picture
if (!file) {
Serial.println("LITTLEFS.open failed");
Serial.println("LITTLEFS.format");
LITTLEFS.format();
bytesWritten = file.write(fb->buf, fb->len);
if (bytesWritten == 0) {
Serial.println("file.write failed");
LITTLEFS.format();
Serial.print("LITTLEFS bytesWritten: ");
Serial.println(bytesWritten);
file.close();
I only need help with one missing thing: When I use "command 2" (wifi & user interface), I would like to write the image data from Littlefs back to the "fb" frame buffer before running the UI, because then I would see the last picture taken instead of a blank picture frame.
Any ideas how to read one image from Littlefs back to the "fb" frame buffer ?
Thanks
