I have an off-brand Mega2560 that I've never been able to program. When powered on, it has LED near R18 lit solid and LED R17 blinking.
It does not show under Ports in Arduino Studio (running on OS X 10.11.5).
I have a Pololu AVR USB programmer. I've upgraded its firmware successfully and checked (under Windows) that its config is nominal (e.g. ISP Programming frequency 200kHz, default voltage limits, etc).
I have avrdude installed and for want of a better suggestion I am trying the commands given here.
The output looks like this:
$ avrdude -p m2560 -c avrispmkii -P /dev/cu.usbmodem00143251 -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xD8:m -Ulfuse:w:0xFF:m -e -v
avrdude: Version 6.3, compiled on Mar 15 2016 at 21:26:45
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/usr/local/Cellar/avrdude/6.3/etc/avrdude.conf"
User configuration file is "/Volumes/ElCap/Users/toby/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbmodem00143251
Using Programmer : avrispmkii
AVR Part : ATmega2560
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 4096 8 0 9000 9000 0x00 0x00
flash 65 10 256 0 yes 262144 256 1024 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500V2
Description : Atmel AVR ISP mkII
Programmer Model: STK500
Hardware Version: 15
Firmware Version Master : 2.10
Topcard : Unknown
Vtarget : 0.0 V
SCK period : 17.4 us
Varef : 0.0 V
Oscillator : 3.686 MHz
avrdude: stk500v2_command(): command failed
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude done. Thank you.
I'm really not sure what to try next.
