Trying to Flash two separate LED's (RH & LH) with BLE
Control Board: Uno R4 Wifi
Code:
#include <ArduinoBLE.h>
// variables for buttons
const int RHbuttonPin = 2;
const int LHbuttonPin = 3;  // New button on pin 3
int RHoldButtonState = LOW;
int LHoldButtonState = LOW;  // State for LH button
  // configure the button pins as input
  pinMode(RHbuttonPin, INPUT_PULLUP);
  pinMode(LHbuttonPin, INPUT_PULLUP);  // Configure LH button pin
  if (!BLE.begin()) {
    Serial.println("BLE initialization failed!");
    while (1);  // Halt if BLE initialization fails
  Serial.println("Bluetooth® Low Energy Central - LED control");
  // Start scanning for peripherals advertising the service UUID
  BLE.scanForUuid("19b10000-e8f2-537e-4f6c-d104768a1214");
  BLEDevice peripheral = BLE.available();
  if (peripheral) {
    Serial.print("Found ");
    Serial.print(peripheral.address());
    Serial.print(" '");
    Serial.print(peripheral.localName());
    Serial.print("' ");
    Serial.print(peripheral.advertisedServiceUuid());
    if (peripheral.localName() != "LED") {
      return;
    // Stop scanning as we've found a matching peripheral
    BLE.stopScan();
    controlLed(peripheral);
    // After disconnecting, restart scanning for peripherals
void controlLed(BLEDevice peripheral) {
  Serial.println("Connecting...");
  if (peripheral.connect()) {
    Serial.println("Connected");
    Serial.println("Failed to connect!");
    return;
  // Discover attributes on the peripheral (LED characteristics)
  if (peripheral.discoverAttributes()) {
    Serial.println("Attributes discovered");
    Serial.println("Attribute discovery failed!");
    peripheral.disconnect();
    return;
  // Retrieve the LED characteristic (for both RH and LH)
  BLECharacteristic RHledCharacteristic = peripheral.characteristic("19b10001-e8f2-537e-4f6c-d104768a1214");
  BLECharacteristic LHledCharacteristic = peripheral.characteristic("19b10002-e8f2-537e-4f6c-d104768a1214");
  if (!RHledCharacteristic || !LHledCharacteristic) {
    Serial.println("Peripheral does not have LED characteristics!");
    return;
    Serial.println("LED characteristics found and valid.");
  while (peripheral.connected()) {
    int RHbuttonState = !digitalRead(RHbuttonPin);
    int LHbuttonState = !digitalRead(LHbuttonPin);
    if (RHoldButtonState != RHbuttonState) {
      RHoldButtonState = RHbuttonState;
      if (RHbuttonState) {
        Serial.println("RH Button pressed");
        RHledCharacteristic.writeValue((uint8_t)0x01);  // Turn ON RH LED
        RHledCharacteristic.writeValue((uint8_t)0x00);  // Turn OFF RH LED
    if (LHoldButtonState != LHbuttonState) {
      LHoldButtonState = LHbuttonState;
      if (LHbuttonState) {
        Serial.println("LH Button pressed");
        LHledCharacteristic.writeValue((uint8_t)0x01);  // Turn ON LH LED
        LHledCharacteristic.writeValue((uint8_t)0x00);  // Turn OFF LH LED
  Serial.println("Peripheral disconnected");
Peripheral Board: Nano33 BLE Rev 2
// Define the service and characteristic UUIDs
BLEService ledService("19b10000-e8f2-537e-4f6c-d104768a1214");  // LED Control Service
// Define two characteristics for controlling two LEDs
BLECharacteristic RHledCharacteristic("19b10001-e8f2-537e-4f6c-d104768a1214", BLERead | BLEWrite, 1);  // RH LED control
BLECharacteristic LHledCharacteristic("19b10002-e8f2-537e-4f6c-d104768a1214", BLERead | BLEWrite, 1);  // LH LED control
// Define the pins for the two LEDs
const int RHledPin = 2;  // RH LED pin
const int LHledPin = 3;  // LH LED pin
  // Start serial communication
  // Initialize BLE
  if (!BLE.begin()) {
    Serial.println("Starting BLE failed!");
    while (1);
  // Set up the LED pins
  pinMode(RHledPin, OUTPUT);
  pinMode(LHledPin, OUTPUT);
  digitalWrite(RHledPin, LOW);  // Initially turn off RH LED
  digitalWrite(LHledPin, LOW);  // Initially turn off LH LED
  // Add characteristics to the LED service
  ledService.addCharacteristic(RHledCharacteristic);
  ledService.addCharacteristic(LHledCharacteristic);
  // Add the service to BLE
  BLE.addService(ledService);
  // Start advertising the service
  BLE.advertise();
  Serial.println("Advertising BLE LED control service...");
  // Poll for BLE events (handle requests from central)
  BLE.poll();
  // If the RH LED characteristic is written to, change the RH LED state
  if (RHledCharacteristic.written()) {
    uint8_t RHledState = *(RHledCharacteristic.value());  // Dereference the pointer to get the byte value
    if (RHledState == 0x01) {
      digitalWrite(RHledPin, HIGH);  // Turn ON RH LED
      digitalWrite(RHledPin, LOW);   // Turn OFF RH LED
    Serial.print("RH LED State: ");
    Serial.println(RHledState == 0x01 ? "ON" : "OFF");
  // If the LH LED characteristic is written to, change the LH LED state
  if (LHledCharacteristic.written()) {
    uint8_t LHledState = *(LHledCharacteristic.value());  // Dereference the pointer to get the byte value
    if (LHledState == 0x01) {
      digitalWrite(LHledPin, HIGH);  // Turn ON LH LED
      digitalWrite(LHledPin, LOW);   // Turn OFF LH LED
    Serial.print("LH LED State: ");
    Serial.println(LHledState == 0x01 ? "ON" : "OFF");
I cannot get the boards to connect and the one time they did I bounced between on the control Serial
00:54:10.246 -> Found b2:78:90:04:4c:65 'LED' 19b10000-e8f2-537e-4f6c-d104768a1214
00:54:10.292 -> Connecting...
00:54:10.384 -> Connected
00:54:11.076 -> Attributes discovered
00:54:11.076 -> Peripheral does not have LED characteristics!
The Peripheral board kept saying:
00:51:10.075 -> Connected to central: c0:4e:30:12:94:99
00:51:10.813 -> Disconnected from central: c0:4e:30:12:94:99
This is my first Bluetooth project, please help!  Thanks!!
Describe what you observe and what you expect.
What example are you following? How are your buttons wired?
My buttons are wired between pin 2 or 3 to ground. I started with the ArduinoBLE example for a control device and the LED control sketch and the peripheral device LED sketch and have been modifying since then.
Your code finds this (above), disconnects and exits.
Hi xfpd, appreciate the help. As I said this is new to me. Do I even need those statements or can I delete them? Or should I break them into there own statement for each?
Thanks again!
Error checking is imperative (it is better for a system to shut down than to plough through and break the system).
Correct the error your code is showing. Find the source of the errors.
