Trying to make a brushless dc motor controller with mosfets and arduino
I am trying to control a brushless dc motor- I have a h-bridge style mosfet circuit and am controlling the gates with an arduino. However I am trying to power the motor with a 7.4V lipo battery (which is required by that motor) - the mosfets are also high current rated so shouldnt be an issue (linked here https://4donline.ihs.com/images/VipMasterIC/IC/ONSM/ONSM-S-A0003584711/ONSM-S-A0003584470-1.pdf?hkey=6D3A4C79FDBF58556ACFDE234799DDF0 ). But when I connected the battery to the circuit it all started smoking- is there something obvious I'm missing- I hadnt started the arduino program yet so none of the mosfets should've been 'open' so no current should've been drawn. I am aware that a breadboard and breadboard wires probably arent suitable for the current levels but seeing as the motor wasnt connected at this point (was just trying to test the mosfet circuit) I don't see how that could've been the issue. On that note does anyone have any advice on how to test a higher current circuit like this if breadboards don't take that much current.
motor: https://www.amazon.co.uk/dp/B075731ZJM?psc=1&ref=ppx_yo2ov_dt_b_product_details
lipo battery: https://www.amazon.co.uk/dp/B08JCM7HBH?psc=1&ref=ppx_yo2ov_dt_b_product_details
The numbers in the picture are connected to arduino pins
I don't see any gate drive circuit in your diagram.
Those are not logic level mosfets, so not suitable to direcly drive the gates of the lower (GND) mosfets with a 5volt Arduino pin. They need 10-volt logic. The gates of the high-side mosfets must be driven with "battery voltage + 10volt". And then there is firing order, and shoot-through.
Not a beginner's task. Good luck.
Leo..
I see- on the datasheet the gate threshold voltage was labelled as 2-4V. A
m I just looking at the wrong thing here then?
That's the threshold voltage, or the point where the mosfet turns off (or barely starts conducting).
Rds(on), which is he next line in the datasheet, is specified at a Vgs of 10volt.
Leo..
Then you connected some of the MOSFETs in the wrong way.
For a first test add a resistor (~10k) between gate and source of each MOSFET and verify that then they all are off.
